08-15-2009 10:44 AM - edited 03-15-2019 07:22 PM
Can any one suggest how to implement the below requirement
1) Particular extensions should have option to dial 0 (zero) to call mobile and they should enter password when they dial the zero digit.
08-15-2009 12:28 PM
COR + FAC
FAC UC500
The other usual option is as Paolo mentions "use after-hours and PIN login"
Plenty of posts on the matter, if you require more info search NetPro.
java
if this helps, please rate
08-16-2009 03:46 AM
dont get it can you please post me the links that can help.
