Have fully function Cisco Call Manager Express, running 20 phones SCCP 7961 mainly.
Have purchased some new 8800 series phones 8861, 8821, and 8831.
Trying to get the 8861 registered with my CME.
My config is as follows:
voice service voip
ip address trusted list
ipv4 x.x.x.x
ipv4 y.y.y.y
cti csta mode basic
no cti shutdown
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server
voice register pool-type 8821
phoneload-support
reference-pooltype 9971
voice register global
mode cme
source-address internalIPAddr port 5060
max-dn 96
max-pool 24
load 8861 sip88xx.11-7-1-17.loads
load 8821 sip8821.11-0-3SR1-1.loads
create profile sync 0445144314544414
auto-register
password XXX
auto-assign 1001 to 1010
voice register dn 48
number 3333
voice register dn 49
number 3333
voice register pool 23
busy-trigger-per-button 2
id mac 0059.DCDE.036C
type 8861
number 1 dn 48
voice register pool 24
id mac 00A2.89FB.A3EA
type 8821
number 1 dn 49
IOS - Version
System image file is "flash:c2900-universalk9-mz.SPA.156-3.M1.bin"
Phone just sits saying Phone is Registering.
Status messages:
TFTP AppDialrules.xml
Error updating Network Locale
Error updating User Locale
VPN not configured
SEPXXXXX.cnf.xml
Phone version 8861:
Active Load sip88xx.11-7-1-17
What am I missing?
Delete the voice register config and amend as below for voice register global.
mode cme
max-dn 96
max-pool 24
tftp-path flash:
authenticate register
auto-register
password XXX
Do the same config for voice register dn and pool. Rest of the config seems to be fine.
After doing the config for voice register global, pool and dn, go back to voice register global and run the command for create profile.
Hope this helps.
Abhay
