CME configuration
pawelzwierzynski
Beginner
Beginner
I'm new in CME and I have to configure sip trunk. I cannot register to sip trunk (telephones works only locally), I'm not sure that I misconfigure something or there is a problem in provider site, mu config:
ip dhcp excluded-address 10.200.200.1 10.200.200.100
ip dhcp pool lan
   network 10.254.254.0 255.255.255.0
   default-router 10.254.254.1
   dns-server 8.8.8.8
ip dhcp pool voice
   network 10.200.200.0 255.255.255.0
   option 150 ip 10.200.200.1
   default-router 10.200.200.1
dns-server 8.8.8.8
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 h323
 sip
  registrar server expires max 1200 min 300
  localhost dns:sip.inea.com.pl
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
voice translation-rule 3
 rule 1 /^601/ /612228601/
 rule 8 /^6\(..$\)/ /6122286\1/
voice translation-rule 4
 rule 1 /^9\(.*\)/ /\1/
voice translation-rule 13
 rule 1 /612228601/ /601/
voice translation-profile FROMSIPINEA
 translate called 13
voice translation-profile TOSIPINEA
 translate calling 3
 translate called 4
voice-card 0
interface Loopback0
 description $FW_INSIDE$
 ip address 10.200.201.2 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
interface FastEthernet0/0
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
interface Integrated-Service-Engine0/0
 ip unnumbered Loopback0
 ip nat inside
 shutdown
 service-module ip address 10.200.201.1 255.255.255.0
 service-module ip default-gateway 10.200.201.2
interface FastEthernet0/1/0
interface FastEthernet0/1/1
 switchport voice vlan 100
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
interface Dot11Radio0/5/0
 no ip address
 shutdown
 speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
 station-role root
interface Vlan1
 ip address 10.254.254.1 255.255.255.0
 ip nat inside
interface Vlan100
 ip address 10.200.200.1 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list NAT interface FastEthernet0/0 overload
ip route 10.200.201.2 255.255.255.255 Integrated-Service-Engine0/0
ip access-list extended NAT
 permit ip 10.254.254.0 0.0.0.255 any
logging esm config
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin
tftp-server flash:/phones/50x-30x/spa50x-30x-7-4-8a.bin
tftp-server flash:/phones/7945_7965/apps45.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/cnu45.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/dsp45.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/SCCP45.8-5-4S.loads
tftp-server flash:/phones/7945_7965/term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads
tftp-server flash:/phones/7975/apps75.8-5-4TH1-6.sbn
tftp-server flash:/phones/7975/cnu75.8-5-4TH1-6.sbn
tftp-server flash:/phones/7975/cvm75sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7975/dsp75.8-5-4TH1-6.sbn
tftp-server flash:/phones/7975/jar75sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7975/SCCP75.8-5-4S.loads
tftp-server flash:/phones/7975/term75.default.loads
tftp-server flash:/Desktops/320x212x12/List.xml
tftp-server flash:/Desktops/320x212x12/List.xml.BAK
tftp-server flash:/Desktops/320x212x16
tftp-server flash:/Desktops/320x212x16/List.xml
tftp-server flash:/Desktops/320x212x16/List.xml.BAK
tftp-server flash:/Desktops/320x216x16
tftp-server flash:/Desktops/320x216x16/List.xml
tftp-server flash:/Desktops/320x216x16/List.xml.BAK
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:/bacdprompts/app-b-acd-3.0.0.2.tcl
tftp-server flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au
tftp-server flash:/ringtones/Analog1.raw
tftp-server flash:/ringtones/Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw
tftp-server flash:/ringtones/AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw
tftp-server flash:/ringtones/CallBack.raw
tftp-server flash:/ringtones/Chime.raw
tftp-server flash:/ringtones/Classic1.raw
tftp-server flash:/ringtones/Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml
tftp-server flash:/ringtones/Drums1.raw
tftp-server flash:/ringtones/Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw
tftp-server flash:/ringtones/Piano2.raw
tftp-server flash:/ringtones/Pop.raw
tftp-server flash:/ringtones/Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw
tftp-server flash:/ringtones/Ring2.raw
tftp-server flash:/ringtones/Ring3.raw
tftp-server flash:/ringtones/Ring4.raw
tftp-server flash:/ringtones/Ring5.raw
tftp-server flash:/ringtones/Ring6.raw
tftp-server flash:/ringtones/Ring7.raw
tftp-server flash:/ringtones/RingList.xml
tftp-server flash:/ringtones/Sax1.raw
tftp-server flash:/ringtones/Sax2.raw
tftp-server flash:/ringtones/Vibe.raw
tftp-server flash:/ringtones/RingList.xml.BAK
tftp-server flash:/ringtones/DistinctiveRingList.xml.BAK
tftp-server flash:/phones/525/spa525g-7-4-8.bin
control-plane
voice-port 0/0/0
 compand-type a-law
 cptone PL
 timeouts ringing infinity
 bearer-cap Speech
 station-id name FAX
 station-id number 39
 caller-id enable
voice-port 0/0/1
 station-id number 302
 caller-id enable
voice-port 0/0/2
 station-id number 303
 caller-id enable
voice-port 0/0/3
 station-id number 304
 caller-id enable
voice-port 0/1/0
 compand-type a-law
 bearer-cap Speech
voice-port 0/1/1
 compand-type a-law
 bearer-cap Speech
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/4/0
 auto-cut-through
 signal immediate
 input gain auto-control -15
 description Music On Hold Port
sccp local Loopback0
sccp ccm 10.200.200.1 identifier 1 version 3.1
sccp
dial-peer voice 2003 voip
 translation-profile outgoing TOSIPINEA
 max-conn 10
 destination-pattern 9T
 session protocol sipv2
 session target dns:sip.inea.com.pl
 voice-class codec 1
 dtmf-relay rtp-nte
dial-peer voice 2011 voip
 translation-profile incoming FROMSIPINEA
 incoming called-number .
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 2000 voip
 destination-pattern 55
 session target ipv4:10.200.201.2
 codec g711ulaw
 no vad
dial-peer voice 2002 voip
 destination-pattern 57
 codec g711ulaw
 no vad
sip-ua
 credentials username xxx password 7 xxx realm sip.inea.com.pl
 authentication username xxx password 7 xxx
 registrar dns:sip.inea.com.pl expires 3600
 sip-server dns:sip.inea.com.pl
telephony-service
 max-ephones 30
 max-dn 50
 ip source-address 10.200.200.1 port 2000
 max-redirect 20
 auto assign 10 to 19
 auto assign 5 to 8 type anl
 auto assign 1 to 50
 caller-id block code *1
 calling-number initiator
 timeouts interdigit 5
 url services http://10.200.201.1/voiceview/common/login.do
 url authentication http://10.200.201.2/CCMCIP/authenticate.asp
 cnf-file location flash:
 cnf-file perphone
 user-locale U1 PL
 network-locale U2
 load 7914 S00105000300
 load 7911 SCCP11.8-4-2S
 load 7912 CP7912080003SCCP070409A
 load 7960-7940 P00308000500
 load 7945 SCCP45.8-4-2S
 load 7961 SCCP41.8-4-2S
 load 7961GE SCCP41.8-4-2S
 load 7970 SCCP70.8-4-2S
 load 7975 SCCP75.8-4-2S
 load ata ATA030203SCCP051201A
 time-zone 23
 time-format 24
 date-format dd-mm-yy
 live-record 559
 voicemail 555
 max-conferences 8 gain -6
 call-forward pattern .T
 call-forward system redirecting-expanded
 moh music_on_hold.au
 multicast moh 239.10.16.16 port 2000
 web admin system name admin secret 5 $1$7beF$5XM6uSxKNjYO.L891qPP51
 dn-webedit
 time-webedit
 transfer-system full-consult dss
 transfer-pattern 9.T
 transfer-pattern .T
 secondary-dialtone 9
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
 number 601
 label zwierz-601
ephone-dn  3
 number 603
 label zwierz-komp603
ephone  1
 device-security-mode none
 mac-address BC16.F517.9069
 type 7945
 button  1:1
ephone  2
 mac-address A088.B400.4EC8
 button  1:3
line con 0
 no modem enable
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
line vty 0 4
 transport input all
end
Some debugs when calling outside:
ent:
INVITE sip:501430117@sip.inea.com.pl:5060 SIP/2.0
Via: SIP/2.0/UDP 46.238.91.217:5060;branch=z9hG4bKB8763
Remote-Party-ID: <sip:612228603@sip.inea.com.pl>;party=calling;screen=no;privacy=off
From: <sip:612228603@sip.inea.com.pl>;tag=C2DEBBC-1E02
To: <sip:501430117@sip.inea.com.pl>
Date: Mon, 08 Dec 2014 19:22:05 GMT
Call-ID: 542C04F3-7E4611E4-8C429A57-1420FF99@sip.inea.com.pl
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 1359491080-2118521316-2352847447-0337706905
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1418066525
Contact: <sip:612228603@46.238.91.217:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 286
v=0
o=CiscoSystemsSIP-GW-UserAgent 5815 9696 IN IP4 46.238.91.217
s=SIP Call
c=IN IP4 46.238.91.217
t=0 0
m=audio 19528 RTP/AVP 0 8 101 19
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
*Dec  8 19:22:05.441: //820/510830088C3D/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Forbidden
Via: SIP/2.0/UDP 46.238.91.217:5060;branch=z9hG4bKB8763;received=46.238.91.217
To: <sip:501430117@sip.inea.com.pl>;tag=as73746a2c
CSeq: 101 INVITE
User-Agent: Adescom CTM5000
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Max-Forwards: 70
Content-Length: 0
*Dec  8 19:22:05.449: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:501430117@sip.inea.com.pl:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
I'm thinking about message SIP/2.0 403 Forbidden - is that mean that regisrtat is rejecting?
Please help, thanks in advance.
Hello
Try this
voice service voip
ip address authenticate
(enter the ip of sip trunk)
sip
bind all source-interface <IP address of Interface>
sip-ua
registrar ipv4: (Enter the IP address of registrar server provided by service provider)
 sip-server ipv4: (Enter the IP address of registrar server provided by service provider)
credentials username XXXX password XXXX
7 Replies 7
j.huizinga
Frequent Contributor
Yes, contact provider. Because you get 403, it means you have contacted provider, but something is wrong.
JH
Thanks for replies.
Little progress:
*Dec 12 14:47:37.423: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:sip.inea.com.pl:5060 SIP/2.0
Via: SIP/2.0/UDP 46.238.91.217:5060;branch=z9hG4bK15B1CA9
To: <sip:601@sip.inea.com.pl>
Date: Fri, 12 Dec 2014 14:47:37 GMT
Call-ID: D7B949FE-7E3711E4-89759A57-1420FF99
Max-Forwards: 70
Timestamp: 1418395657
CSeq: 1861 REGISTER
Contact: <sip:601@46.238.91.217:5060>
Expires:  3600
Supported: path
Content-Length: 0
*Dec 12 14:47:37.431: //10449/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 404 Not found
Via: SIP/2.0/UDP 46.238.91.217:5060;branch=z9hG4bK15B1CA9;received=46.238.91.217
To: <sip:601@sip.inea.com.pl>;tag=as06e5c8aa
CSeq: 1861 REGISTER
Max-Forwards: 70
Content-Length: 0
*Dec 12 14:48:07.731: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 46.238.91.217:5060;branch=z9hG4bK15B2B14
To: <sip:603@sip.inea.com.pl>
Date: Fri, 12 Dec 2014 14:48:07 GMT
Call-ID: D7B9E626-7E3711E4-89779A57-1420FF99
Max-Forwards: 70
Timestamp: 1418395687
CSeq: 1861 REGISTER
Contact: <sip:603@46.238.91.217:5060>
Expires:  3600
Supported: path
Content-Length: 0
*Dec 12 14:48:07.735: //10450/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 46.238.91.217:5060;branch=z9hG4bK15B2B14;received=46.238.91.217
To: <sip:603@sip.inea.com.pl>;tag=as57ec6cf7
CSeq: 1861 REGISTER
Max-Forwards: 70
Content-Length: 0
*Dec 12 14:48:12.559: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:SIP_USERNAME@46.238.91.217:5060 SIP/2.0
Via: SIP/2.0/UDP 62.21.102.138:5060;branch=z9hG4bK4223c9d5;rport
From: "adescom" <sip:adescom@62.21.102.138>;tag=as6eae1f7d
To: <sip:SIP_USERNAME@46.238.91.217:5060>
Contact: <sip:adescom@62.21.102.138>
Call-ID: 2446f2825e1843252a78416a29f5f3af3016033896
CSeq: 102 OPTIONS
Max-Forwards: 70
Date: Fri, 12 Dec 2014 14:42:52 GMT
Content-Length: 0
*Dec 12 14:48:12.563: //10451/BB26B160BE89/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:SIP_USERNAME@46.238.91.217:5060>;tag=1FCC9CF0-1882
Date: Fri, 12 Dec 2014 14:48:12 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 102 OPTIONS
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIF        Y, INFO, REGISTER
Accept: application/sdp
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 8834 4637 IN IP4 46.238.91.217
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
My SIP_USERNAME now is registering but also local number 601, 603 want also register to sip. And I still can't call outside.
I found issue, everything is working correctly, both inciming and outgoing calls.
How did the issue got resolved? Please update
3 things:
- service provider gave me wrong password
- misconfiguration in sip-profiles
- Toll-Fraud Prevention
Good to hear that.
Please mark the question as answered and rate the useful posts.
Hello
Try this
voice service voip
sip
sip-ua
