CME DND work with Feature ring?
victorchen
If my phone button assign wirh feature ring? Can I enable DND on phone as well?
Will DND work?
Victor
Rob Huffman
Hi Victor,
This setting is configuable
SCCP: Blocking Do Not Disturb
To block DND on phones that have buttons configured for feature ringing,  perform the following steps. DND is enabled by using the DND soft key  on Cisco Unified IP phones that support soft keys.
Prerequisites
Cisco Unified 3.2.1 or a later version.
Phone line must be configured for feature ring with the button f command.
Call-forwarding no-answer must be set for a phone to use DND to forward calls. For configuration information, see "Configuring Call Transfer and Forwarding". No other configuration is necessary for basic DND.
Restrictions
Phone  users cannot enable DND for a shared line in a hunt group. The soft key  displays in the idle and ringing states but does not enable DND for  shared lines in hunt groups.
SUMMARY STEPS
1. enable
2. configure terminal
3. ephone phone-tag
4. no dnd feature-ring
5. end
DETAILED STEPS
Command or Action
Purpose
Step 1
enable
Example:
Router> enable
Enables privileged EXEC mode.
Enter your password if prompted.
Step 2
configure terminal
Example:
Router# configure terminal
Enters global configuration mode.
Step 3
ephone phone-tag
Example:
Router(config)# ephone 10
Enters ephone configuration mode.
phone-tag—Unique sequence number that identifies the ephone to be configured.
Step 4
no dnd feature-ring
Example:
Router(config-ephone)# no dnd feature-ring
Enables ringing on phone buttons configured for feature ring when the phone is in DND mode.
Step 5
end
Example:
Router(config-ephone)# end
Returns to privileged EXEC mode.
Examples
In the following configuration example, when DND is activated on ephone 1  and ephone 2, button 1 will ring, but button 2 will not.
ephone-dn 1
number 1001
ephone-dn 2
number 1002
ephone-dn 10
number 1110
preference 0
no huntstop
ephone-dn 11
number 1111
preference 1
ephone 1
button 1f1
button 2o10,11
no dnd feature-ring
ephone 2
button 1f2
button 2o10,11
no dnd feature-ring
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmednd.html
Cheers!
Rob
"go easy...step lightly...stay free "
- The Clash
