Participant
CME Ephone PLAR
I have an ATA using SCCP connected to a doorphone on CME7. I'd like to program a PLAR to ring a huntgroup when the doorphone goes offhook but the only references that I can find to PLAR in the CME manual are for FXO ports. Does anyone know how to configure an ephone for PLAR?
2 REPLIES 2
Rising star
Re: CME Ephone PLAR
Hello Joe,
Have you tried using the intercom feature? Check out this doc:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeinter.html#wp1011632
Hope that helped, if so please rate.
Highlighted
Beginner
Re: CME Ephone PLAR
Kenneth,
Thank you very much. Your reference doc did the trick. I also had an analog door phone hooked up to an ATA an spent a bit of time trying to get a PLAR defined for that port so that pressing the doorphone button would autodial an internal hunt group. Problem is that you cannot specify voice-port x/x/x for a SCCP ATA.
The solution as Kenneth suggested is to use the intercom feature....."It's so simple, even a caveman (like me..) can do it...". It's in the doc anyway.
ephone-dn  11
number 4235
label doorphone
name doorphone
intercom 4444
ephone  11
mac-address 1C58.F93E.1401
button  1:11
That's it. One minor issue is that I notice the phones in the hunt group ring once AFTER they hang up. I'll chase that one down another day, for now, I'm happy. Thanks again Ken.
BDB
Content for Community-Ad
July's Community Spotlight Awards
