09-07-2009 02:48 AM - edited 03-15-2019 07:39 PM
I have an ATA using SCCP connected to a doorphone on CME7. I'd like to program a PLAR to ring a huntgroup when the doorphone goes offhook but the only references that I can find to PLAR in the CME manual are for FXO ports. Does anyone know how to configure an ephone for PLAR?
Solved! Go to Solution.
09-08-2009 09:27 AM
09-07-2009 05:53 PM
Whoops - wrong forum - I'll repost in the correct place.
09-08-2009 09:27 AM
Try this command under the ephone:
ephone-dn 1
trunk 1234
-nick
09-11-2009 11:08 PM
That did the trick. Thanks for that. Now to find a doorphone that's not proprietary (and costs next to nothing ;)
09-12-2009 02:07 AM
You need a phone adapter to intercom, not any doorphone. They do good ones here, but might not work for you.
