CME errors - voice_reg_get_reg_expires_timer: no voice register pool found
davidfield
Level 3
Level 3
Hello All
I found the following errors now being experieinced on my 2911 CME install.  I'm having trouble trying to work out what is causing it.  There are SIP  and SCCP devices but no SIP trunks.  All outbound is PSTN.
I ran Debug ccsip and get the folloiwng which looks like something is hitting the dial peers but I can't work out what.
Can anyone point me to or shed some light on what is happeing?  The statement below contact address matches own address is a concern to me.
Dave
Failed FROM/TO Request check - IGNORE IF HAIRPIN CALL
                old_from:       <sip:00*@10.117.101.200>;tag=45A72C-2053
                old_to: <sip:00*@10.117.101.200>
                new_from:       <sip:00*@10.117.101.200>;tag=45A72C-2053
                new_to: <sip:00*@10.117.101.200>
*Nov 14 12:50:05.066: voice_reg_get_reg_expires_timer: no voice register pool found
*Nov 14 12:50:05.066: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table:
No entry found in sipCallID Table
*Nov 14 12:50:05.070: //3956/1E555E5C8602/SIP/Error/sipSPI_ipip_build_consolidated_header_list:
No headers associated with passthrulist tag: 0 and copylist tag: 0
*Nov 14 12:50:05.070: //3956/1E555E5C8602/SIP/Error/ccsip_spi_register_incoming_registration:
CCSIP_REGISTER:: contact address matches own ip address
*Nov 14 12:50:05.070: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_PassthruContentContainerFreeHelper:
Null ContentQ - Exit
*Nov 14 12:50:05.070: //3955/000000000000/SIP/Error/ccsip_api_register_result_ind:
Message Code Class 4xx Method Code 100 received for REGISTER
*Nov 14 12:50:05.070: //3955/000000000000/SIP/Error/sipSPIRegPthruProcessResponse:
Error NO RPCB
*Nov 14 12:50:05.070: //3958/000000000000/SIP/Error/sipSPICheckFromToRequest:
                old_from:       <sip:[1-9]......@10.117.101.200>;tag=45A730-FC1
                old_to: <sip:[1-9]......@10.117.101.200>
                new_from:       <sip:[1-9]......@10.117.101.200>;tag=45A730-FC1
                new_to: <sip:[1-9]......@10.117.101.200>
*Nov 14 12:50:05.074: voice_reg_get_reg_expires_timer: no voice register pool found
*Nov 14 12:50:05.074: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table:
*Nov 14 12:50:05.074: //3959/1E55FA848603/SIP/Error/sipSPI_ipip_build_consolidated_header_list:
*Nov 14 12:50:05.074: //3959/1E55FA848603/SIP/Error/ccsip_spi_register_incoming_registration:
*Nov 14 12:50:05.074: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_PassthruContentContainerFreeHelper:
*Nov 14 12:51:49.063: //3971/000000000000/SIP/Error/sipSPICheckFromToRequest:
                old_from:       <sip:0[1-8]*@10.117.101.200>;tag=4700DC-902
                old_to: <sip:0[1-8]*@10.117.101.200>
                new_from:       <sip:0[1-8]*@10.117.101.200>;tag=4700DC-902
                new_to: <sip:0[1-8]*@10.117.101.200>
*Nov 14 12:51:49.063: Parse Error: url_parseSipUrl: Received Bad Port
*Nov 14 12:51:53.063: //3971/000000000000/SIP/Error/act_sent_register_wait_100:
act_sent_register_wait_100: Out of retries
*Nov 14 12:51:53.063: //3971/000000000000/SIP/Error/ccsip_api_register_result_ind:
SIP Registration Retries Exhausted
*Nov 14 12:51:53.063: //3971/000000000000/SIP/Error/sipSPIRegPthruProcessResponse:
Error NO RPCB
*Nov 14 12:51:57.607: //3976/000000000000/SIP/Error/sipSPICheckFromToRequest:
*Nov 14 12:50:05.074: //3958/000000000000/SIP/Error/ccsip_api_register_result_ind:
*Nov 14 12:50:05.074: //3958/000000000000/SIP/Error/sipSPIRegPthruProcessResponse:
Error NO RPCB
*Nov 14 12:50:06.610: //0/000000000000/SIP/Error/ccsip_spi_asnl_notify_request:
Error getting message body from container
*Nov 14 12:50:06.618: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
There ar
0 Replies 0
