03-10-2016 11:31 AM - edited 03-17-2019 06:12 AM
I have a customer with CME who wants to present two different departmental numbers to the ISP (BT). They have two departments both served by a CME and want to present one set of extensions with their dept published number and another with a different published number. They do not want their individual extension numbers presented to the PSTN. The CME has a single E1 to the PSTN.
My question: is there a way to give each ephone dn its own external mask as it is on CUCM?
Many thanks, John.
Solved! Go to Solution.
03-10-2016 07:07 PM
I think the best way to achieve this will be using Translation Rules/Profiles to change the calling number for both the departments to the specific number you want based on the dial-plan you follow for your ephone DNs and then apply the same on the outgoing direction under the dial-peers going out to PSTN
Deepak
03-10-2016 07:07 PM
Deepak
03-11-2016 01:44 AM
Many thanks Deepak. I'll follow your advice as I can see what you mean.
I take it that there is no option to apply the mask at the ephone dn level?
Thanks again, John.
03-11-2016 01:53 AM
That is correct John, nothing on the DN level for EPNM as you have in CM.
Deepak
