CME fax question
thr0237ab
For some reasons (maybe hw problem), the h323 config can not work on the fxs port for fax machine but working well with sccp. Does anyone try to configure a fxs port with sccp rather than h323? Any recommendation config or advise on it?
Many thanks
Tony Huynh
Level 4
Level 4
What type of gateway is this? H323 should work for fax on a CME.
The gateway model is 2821 with VIC-4FXS/DID.
