13212
thisisshanky
Advisor
CME forced auth codes in 8.5/8.6
I m referring to this document (which doesnt seem to help me much)..so thought of posting at this forum....
Has any body successfully implemented FAC in CME..
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmefac.html
i have setup two LPCor groups one for end users and one for PSTN trunks..to test this functionality i put one ephone under the end users group and another ephone in the PSTN trunk group..and when you call from ephone 1 to 2...it asks for the username and password as programmed but then it hangs up the call...
i can post configs if needed...its pretty similar to whats in the document..
TIA..
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
50 REPLIES 50
I am trying to acheive FAC on CME 9. But i have doubt to get below matrix
                                 Local Call     LD Call        Intl Call
LOcal User  -->           NO FAC         FAC             FAC
LD Useer    -->            NO FAC         No FAC        FAC
Intl User    --->            NO FAC         NO FAC          NO FAC
How can i acheive this in LPcor policy and single E1 with many dialpeer pot for outgoing.
Thanks Saurabh
hi saurabh_om,
We are facing the same delema, got a few tries doing this scenario and come up with the same result, if you are using a single E1 Pri/Bri that has all the outgoing function, lpcor is not the solution for now, unless cisco will fix it and rescript it in the new IOS version. Because that's the biggest problem of using lpcor, its like we need to block the whole E1 Pri dedicated for authentication calls and must have another E1 Pri using non-authentication calls. Sounds stupid and costly but we have to live with for now ^_^
If you want you can try using the "acctfixedpin.tcl" script, it runs on dial-peers and can be controlled by typical corlists.  Though its unsupported tcl script by Cisco, but develop by a brilliant guy who seem to be knockout by LPCOR.. hahahah Goodluck ^_^
dennis,
I think you can achieve what you want by combining lpcor and cor.
Use cor to restrict which dial peers a line/phone can use.
for dial peers that require fac, point them to the trunk group with lpcor
for dial peers that don't require fac, point them to the voice-port itself instead of the trunk
I was able to achieve this using cor/lpcor for a customer that only required fac on ld/intl but also had fax machines that didn't need to use fac.
I don't have the config handy but it worked fine
Thank you for the quick reply, was able to try this configuration and I may be missing something out. ^_^ if you could provide additional assistance, it would be much appreciated.  I will retry this again and will give feedback.  Thanks.
Hello Dennis,
LPCOR and multiple auth code policy with single PRI line or POTS dial-peers.  with Voice Dial-pper, yes you can play with policies.
I found an alternative is to create translation patterns and match PSTN numbers with voice dial-pper first and then looping number back to CME itself.  Apply LPCOR policy on voice Dial-peer and take decision allow/restrict there itself.
Later make POTS dial-peer to reroute translated number to PSTN trunk.
Here is configuration :
Defines the name and number of LPCOR resource groups
voice lpcor custom
group 10 local                                             LPCOR group for Local Calls
group 11 ld                                                 LPCOR group for Long Distance Calls
group 12 isd                                                 LPCOR group for International Calls
Creates a LPCOR policy for a resource group
voice lpcor policy local                                       Service policy for local resource group
service fac                                                         Enable FAC Service for a routing endpoint
accept ld                                                             Accept calls from group without any FAC
accept isd
voice lpcor policy ld                                           Service policy for long distance resource group
service fac
accept local fac                                                 Accept calls from group with a valid FAC
accept isd
voice lpcor policy isd                                         Service policy for international resource group
service fac
accept local fac
accept ld fac
LPCOR for international numbers patterns:
voice translation-rule 2                         Voice translation rule translating international number
rule 1 /^000/ /654000/
voice translation-profile add654
translate called 2
dial-peer voice 311 voip
description international
translation-profile outgoing add654
destination-pattern 000T
lpcor outgoing isd
session target ipv4:10.220.2.2
dtmf-relay h245-alphanumeric h245-signal
codec g711ulaw
dial-peer voice 312 voip
incoming called-number 654000T
codec g711ulaw
dial-peer voice 310 pots
description # Dial-Peer to Dial ISD Numbers #
destination-pattern 654000T
port 0/0/0:15
prefix 00
LPCOR for Long Distance numbers patterns:
trunk group PRI-ACCESS                                             Define a trunk-group and associate an LPCOR policy
trunk group lpcor outgoing ld
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-5ess
isdn incoming-voice voice
isdn bchan-number-order ascending
trunk-group PRI-ACCESS                                                        Associate trunk-group to E1 PRI
no cdp enable
dial-peer voice 302 pots
trunkgroup PRI-ACCESS                                                          Associate trunk-group to longdistance dialpeer
description # Dial-Peer to Dial LD Mobile Numbers #
destination-pattern 00[7-9].........
forward-digits 11
*********** PLEASE RATE THE ANSWER IF YOU FIND IT HELPFUL *****************
Thanks Saurabh
saurabh_om,
The idea is very helpful and solved the configuration issue we encounter.  We limit the configuration of the dial-peers and translation though by controlling it by cor-list (Pots - Outgoing to PSTN) per IP Phone access, much simplier to control and maintain ^_^
voice-port 0/0/0:15
description ***** ISDN PRI *****
no vad
timeouts interdigit 3
timeouts call-disconnect 3
timeouts wait-release 1
bearer-cap Speech
trunk group Cust01-E1
hunt-scheme least-idle
lpcor incoming Cust01ISDNTrunks
lpcor outgoing Cust01ISDNTrunks
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
trunk-group Cust01-E1 timeslots 1-31 preference 1
dial-peer voice 103 pots
corlist outgoing Cust01localcalls --> Cor List access to Local Calls
description ***** Outgoing POTS Call Leg from CME
destination-pattern 9[1-9]T
port 0/0/0:15 --> Local PSTN Access pointing to ISDN port.
dial-peer voice 100 pots
trunkgroup Cust01-E1 --> Local PSTN Access pointing to ISDN Trunkgroup
corlist outgoing Cust01IDDcalls --> Cor List access to IDD Calls
destination-pattern 9[0][0]T
forward-digits 11
prefix 00
Thank you,
Dennis
omarcruz1
Beginner
Hi everybody,
All of you guys have a realy helpful information here but I have not gotten it. I am still trying to configure the FAC feature. The issue is that system is not validating neither the username nor password, because I dial number I want to reach then I receive recordings user&passwd prompt, I put them right or even wrong and the call is stablished. I have been looking out a lot of information of how to configure FAC, searching information about this issue but I can find nothing.
Im deplying over a 3945E ios 15.1(4)M4. CME 8.6
I will be thankful if anyone has any advice
Sincerely,
Omar Cruz
Hello Omar,
Can you share running configuration of CME.
Saurabh
Thanks Saurabh
Saurabh,
thanks alot for your fast answer, but finally I could get it!!!! the issue was that I had 2 Dail Peers (DP) A and B. I was only requesting FAC for A. I had not seen that I kept B, so all the trafic was traveling through B. I took it out and right away it worked. : D
thanks for your attention though and have a great weekend!!!
aldredbenedict
Beginner
Hey guys I know this might sound dumb but I need to confirm this issue
Can the forced authorization code support many usernames and passwords (username xxx password 0 1234)? Let's say I have 2 usernames : 1234 and 4321. Can I use both of them to authenticate the calls?
yes you can
Sankar Nair
Thanks hanky. Btw does anybody know how to include the FAC username/pin in the CDR?
@Omar, I'm using ios 15.2(4)M1 and CME version 9.1. I haven't tried restarting the router (as it is in production mode), but once I do, I will tell you the results
omarcruz1
Beginner
hi everybody,
I was implementing FAC on CME 8.6 with IOS 15.4M.3 all the functions are working good besides a little detail. I am facing with a command deleted called "trunk group lpcor outgoing " when I reloaded my CME. As I see you guys experienced this behavior before. the questions is Do you guys know the IOS version which is working properly?
thanks in advance
Alexandr Alakin
Beginner
I would like to know working IOS as well..
I have some odd behaviour with IOS 15.1(3)T3 (CME Version 8.5)
#sh voice lpcor policy
voice lpcor policy LP_2 (group 2)
  service fac is enabled
  ( accept     ) LP_2 (group 2)
  ( accept fac ) LP_3 (group 3)
voice lpcor policy LP_3 (group 3)
  ( accept fac ) LP_2 (group 2)
  ( accept     ) LP_3 (group 3)
ephone  2
lpcor type local
lpcor incoming LP_2
lpcor outgoing LP_2
ephone  3
lpcor type local
lpcor incoming LP_3
lpcor outgoing LP_3
I'm trying to enable FAC between 2002 (ephone 2) and 2003 (ephone 3).
Call 2003->2002 works fine, FAC is required in order to place a call (Debug shows: Source LPCOR is LP_3, Target LPCOR is LP_2)
Call 2002->2003 does not require FAC (Debug show that used LPCORs: Source LPCOR is LP_2, Target LPCOR is LP_2) until I add
conf t
accept LP_2 fac
I still cannot figure out why on earth the same LP_2 is used as both Source and Target??
Config and logs are attached
HTH Alexandr
Hi All
I'm trying to configure CME FAC also for customer requirement,
But still doesn't work. Any idea please?
my configuration
aaa new-model
aaa authentication login default local
aaa authentication login h323 local
aaa authorization exec default local
aaa authorization exec h323 local
aaa authorization network h323 local
trunk group TELKOM-E1
trunk group lpcor outgoing trunk
voice-card 0
voice lpcor enable
voice lpcor custom
group 10 user
group 11 trunk
voice lpcor policy user
service fac
accept user fac
accept trunk fac
voice lpcor policy trunk
service fac
accept user fac
accept trunk fac
application
package auth
  param passwd-prompt flash:en_bacd_welcome.au  --> should we put this file  en_bacd_welcome.au to flash?
  param abort-digit *
  param user-prompt flash:en_bacd_enter_dest.au --> should we put this file en_bacd_welcome.au to flash?
  param passwd 5555
  param term-digit #
  param max-digits 32
username 649 password 0 1258
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-30
trunk-group TELKOM-E1 timeslots 1-30
gw-accounting aaa
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn outgoing display-ie
no cdp enable
voice-port 0/0/0:15
dial-peer cor custom
name ALL
name LIMITED
dial-peer cor list ALL
member ALL
dial-peer cor list LIMITED
member LIMITED
dial-peer voice 1 pots
translation-profile incoming incoming
incoming called-number .
direct-inward-dial
dial-peer voice 15 pots
corlist outgoing ALL
translation-profile outgoing outgoing
destination-pattern 9T
port 0/0/0:15
dial-peer voice 16 pots
trunkgroup TELKOM-E1
lpcor outgoing trunk --> not yet configured, need this?
telephony-service
no auto-reg-ephone
max-ephones 100
max-dn 200
ip source-address 10.224.248.1 port 2000
system message CME
cnf-file location flash:
time-zone 40
date-format dd-mm-yy
max-conferences 8 gain -6
moh music-on-hold.au
multicast moh 239.1.1.1 port 2000 route 10.224.252.254
web admin system name unhcr password unhcr123
dn-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Dec 03 2013 13:00:40
ephone-template  1
lpcor type local
lpcor incoming user
lpcor outgoing user --> not yet configured, need this?
ephone-dn  13  dual-line
number 649
pickup-group 1101
label Server Room - 649
description Server Room - 649
name Server Room - 649
ephone  13
device-security-mode none
mac-address 0C68.03C1.79B8
ephone-template 1
type 7945
button  1:13
RTR-01#sh flash0:
-#- --length-- -----date/time------ path
1     68482708 Aug 13 2013 11:24:54 +07:00 c3900e-universalk9-mz.SPA.151-4.M5.bin
239       2464 Aug 13 2013 11:37:14 +07:00 home.shtml
240          0 Nov 30 2013 16:38:02 +07:00 its
241          0 Nov 30 2013 16:38:02 +07:00 its/vrf1
242         60 Nov 30 2013 16:38:06 +07:00 its/SEPDEFAULT.cnf
243       3239 Nov 30 2013 16:38:06 +07:00 its/vrf1/XMLDefault.cnf.xml
244        517 Nov 30 2013 16:38:08 +07:00 its/vrf1/XMLDefault7902.cnf.xml
245        970 Nov 30 2013 16:38:08 +07:00 its/vrf1/XMLDefault7905.cnf.xml
246       1260 Nov 30 2013 17:52:16 +07:00 its/vrf1/XMLDefault7906.cnf.xml
247        603 Nov 30 2013 16:38:08 +07:00 its/vrf1/XMLDefault7910.cnf.xml
248       1260 Nov 30 2013 17:52:18 +07:00 its/vrf1/XMLDefault7911.cnf.xml
249        970 Nov 30 2013 16:38:10 +07:00 its/vrf1/XMLDefault7912.cnf.xml
250        970 Nov 30 2013 16:38:10 +07:00 its/vrf1/XMLDefault7920.cnf.xml
251       1186 Nov 30 2013 17:52:18 +07:00 its/vrf1/XMLDefault7921.cnf.xml
252       1222 Nov 30 2013 17:52:18 +07:00 its/vrf1/XMLDefault7925.cnf.xml
253       1260 Nov 30 2013 17:52:18 +07:00 its/vrf1/XMLDefault7931.cnf.xml
254        550 Nov 30 2013 16:38:12 +07:00 its/vrf1/XMLDefault7935.cnf.xml
255        550 Nov 30 2013 16:38:12 +07:00 its/vrf1/XMLDefault7936.cnf.xml
256       1260 Nov 30 2013 17:52:18 +07:00 its/vrf1/XMLDefault7937.cnf.xml
257       1065 Nov 30 2013 16:38:14 +07:00 its/vrf1/XMLDefault7940.cnf.xml
258       1227 Nov 30 2013 16:38:14 +07:00 its/vrf1/XMLDefault7940-7914-1.cnf.xml
259       1227 Nov 30 2013 16:38:14 +07:00 its/vrf1/XMLDefault7940-7915-12-1.cnf.xml
260       1227 Nov 30 2013 16:38:14 +07:00 its/vrf1/XMLDefault7940-7915-24-1.cnf.xml
261       1227 Nov 30 2013 16:38:14 +07:00 its/vrf1/XMLDefault7940-7916-12-1.cnf.xml
262       1227 Nov 30 2013 16:38:16 +07:00 its/vrf1/XMLDefault7940-7916-24-1.cnf.xml
263       1358 Nov 30 2013 16:38:16 +07:00 its/vrf1/XMLDefault7940-7914-2.cnf.xml
264       1358 Nov 30 2013 16:38:16 +07:00 its/vrf1/XMLDefault7940-7915-12-2.cnf.xml
265       1358 Nov 30 2013 16:38:16 +07:00 its/vrf1/XMLDefault7940-7915-24-2.cnf.xml
266       1358 Nov 30 2013 16:38:18 +07:00 its/vrf1/XMLDefault7940-7916-12-2.cnf.xml
267       1358 Nov 30 2013 16:38:18 +07:00 its/vrf1/XMLDefault7940-7916-24-2.cnf.xml
268       1260 Nov 30 2013 17:52:20 +07:00 its/vrf1/XMLDefault7941.cnf.xml
269       1262 Nov 30 2013 17:52:20 +07:00 its/vrf1/XMLDefault7941GE.cnf.xml
270       1260 Nov 30 2013 17:52:20 +07:00 its/vrf1/XMLDefault7942.cnf.xml
271       1260 Nov 30 2013 17:52:20 +07:00 its/vrf1/XMLDefault7945.cnf.xml
272       1065 Nov 30 2013 16:38:20 +07:00 its/vrf1/XMLDefault7960.cnf.xml
273       1227 Nov 30 2013 16:38:20 +07:00 its/vrf1/XMLDefault7960-7914-1.cnf.xml
274       1227 Nov 30 2013 16:38:20 +07:00 its/vrf1/XMLDefault7960-7915-12-1.cnf.xml
275       1227 Nov 30 2013 16:38:22 +07:00 its/vrf1/XMLDefault7960-7915-24-1.cnf.xml
276       1227 Nov 30 2013 16:38:22 +07:00 its/vrf1/XMLDefault7960-7916-12-1.cnf.xml
277       1227 Nov 30 2013 16:38:22 +07:00 its/vrf1/XMLDefault7960-7916-24-1.cnf.xml
278       1358 Nov 30 2013 16:38:22 +07:00 its/vrf1/XMLDefault7960-7914-2.cnf.xml
279       1358 Nov 30 2013 16:38:24 +07:00 its/vrf1/XMLDefault7960-7915-12-2.cnf.xml
280       1358 Nov 30 2013 16:38:24 +07:00 its/vrf1/XMLDefault7960-7915-24-2.cnf.xml
281       1358 Nov 30 2013 16:38:24 +07:00 its/vrf1/XMLDefault7960-7916-12-2.cnf.xml
282       1358 Nov 30 2013 16:38:24 +07:00 its/vrf1/XMLDefault7960-7916-24-2.cnf.xml
283       1260 Nov 30 2013 17:52:22 +07:00 its/vrf1/XMLDefault7961.cnf.xml
284       1422 Nov 30 2013 17:52:22 +07:00 its/vrf1/XMLDefault7961-7914-1.cnf.xml
285       1422 Nov 30 2013 17:52:22 +07:00 its/vrf1/XMLDefault7961-7915-12-1.cnf.xml
286       1422 Nov 30 2013 17:52:22 +07:00 its/vrf1/XMLDefault7961-7915-24-1.cnf.xml
287       1422 Nov 30 2013 17:52:22 +07:00 its/vrf1/XMLDefault7961-7916-12-1.cnf.xml
288       1422 Nov 30 2013 17:52:24 +07:00 its/vrf1/XMLDefault7961-7916-24-1.cnf.xml
289       1553 Nov 30 2013 17:52:24 +07:00 its/vrf1/XMLDefault7961-7914-2.cnf.xml
290       1553 Nov 30 2013 17:52:24 +07:00 its/vrf1/XMLDefault7961-7915-12-2.cnf.xml
291       1553 Nov 30 2013 17:52:24 +07:00 its/vrf1/XMLDefault7961-7915-24-2.cnf.xml
292       1553 Nov 30 2013 17:52:24 +07:00 its/vrf1/XMLDefault7961-7916-12-2.cnf.xml
293       1553 Nov 30 2013 17:52:26 +07:00 its/vrf1/XMLDefault7961-7916-24-2.cnf.xml
294       1262 Nov 30 2013 17:52:26 +07:00 its/vrf1/XMLDefault7961GE.cnf.xml
295       1424 Nov 30 2013 17:52:26 +07:00 its/vrf1/XMLDefault7961GE-7914-1.cnf.xml
296       1424 Nov 30 2013 17:52:26 +07:00 its/vrf1/XMLDefault7961GE-7915-12-1.cnf.xml
297       1424 Nov 30 2013 17:52:28 +07:00 its/vrf1/XMLDefault7961GE-7915-24-1.cnf.xml
298       1424 Nov 30 2013 17:52:28 +07:00 its/vrf1/XMLDefault7961GE-7916-12-1.cnf.xml
299       1424 Nov 30 2013 17:52:28 +07:00 its/vrf1/XMLDefault7961GE-7916-24-1.cnf.xml
300       1555 Nov 30 2013 17:52:28 +07:00 its/vrf1/XMLDefault7961GE-7914-2.cnf.xml
301       1555 Nov 30 2013 17:52:28 +07:00 its/vrf1/XMLDefault7961GE-7915-12-2.cnf.xml
302       1555 Nov 30 2013 17:52:30 +07:00 its/vrf1/XMLDefault7961GE-7915-24-2.cnf.xml
303       1555 Nov 30 2013 17:52:30 +07:00 its/vrf1/XMLDefault7961GE-7916-12-2.cnf.xml
304       1555 Nov 30 2013 17:52:30 +07:00 its/vrf1/XMLDefault7961GE-7916-24-2.cnf.xml
305       1260 Nov 30 2013 17:52:30 +07:00 its/vrf1/XMLDefault7962.cnf.xml
306       1422 Nov 30 2013 17:52:30 +07:00 its/vrf1/XMLDefault7962-7914-1.cnf.xml
307       1422 Nov 30 2013 17:52:32 +07:00 its/vrf1/XMLDefault7962-7915-12-1.cnf.xml
308       1422 Nov 30 2013 17:52:32 +07:00 its/vrf1/XMLDefault7962-7915-24-1.cnf.xml
309       1422 Nov 30 2013 17:52:32 +07:00 its/vrf1/XMLDefault7962-7916-12-1.cnf.xml
310       1422 Nov 30 2013 17:52:32 +07:00 its/vrf1/XMLDefault7962-7916-24-1.cnf.xml
311       1553 Nov 30 2013 17:52:32 +07:00 its/vrf1/XMLDefault7962-7914-2.cnf.xml
312       1553 Nov 30 2013 17:52:32 +07:00 its/vrf1/XMLDefault7962-7915-12-2.cnf.xml
313       1553 Nov 30 2013 17:52:34 +07:00 its/vrf1/XMLDefault7962-7915-24-2.cnf.xml
314       1553 Nov 30 2013 17:52:34 +07:00 its/vrf1/XMLDefault7962-7916-12-2.cnf.xml
315       1553 Nov 30 2013 17:52:34 +07:00 its/vrf1/XMLDefault7962-7916-24-2.cnf.xml
316       1260 Nov 30 2013 17:52:34 +07:00 its/vrf1/XMLDefault7965.cnf.xml
317       1422 Nov 30 2013 17:52:34 +07:00 its/vrf1/XMLDefault7965-7914-1.cnf.xml
318       1422 Nov 30 2013 17:52:34 +07:00 its/vrf1/XMLDefault7965-7915-12-1.cnf.xml
319       1422 Nov 30 2013 17:52:36 +07:00 its/vrf1/XMLDefault7965-7915-24-1.cnf.xml
320       1422 Nov 30 2013 17:52:36 +07:00 its/vrf1/XMLDefault7965-7916-12-1.cnf.xml
321       1422 Nov 30 2013 17:52:36 +07:00 its/vrf1/XMLDefault7965-7916-24-1.cnf.xml
322       1553 Nov 30 2013 17:52:36 +07:00 its/vrf1/XMLDefault7965-7914-2.cnf.xml
323       1553 Nov 30 2013 17:52:36 +07:00 its/vrf1/XMLDefault7965-7915-12-2.cnf.xml
324       1553 Nov 30 2013 17:52:36 +07:00 its/vrf1/XMLDefault7965-7915-24-2.cnf.xml
325       1553 Nov 30 2013 17:52:38 +07:00 its/vrf1/XMLDefault7965-7916-12-2.cnf.xml
326       1553 Nov 30 2013 17:52:38 +07:00 its/vrf1/XMLDefault7965-7916-24-2.cnf.xml
327       1260 Nov 30 2013 17:52:38 +07:00 its/vrf1/XMLDefault7970.cnf.xml
328       1422 Nov 30 2013 17:52:38 +07:00 its/vrf1/XMLDefault7970-7914-1.cnf.xml
329       1422 Nov 30 2013 17:52:38 +07:00 its/vrf1/XMLDefault7970-7915-12-1.cnf.xml
330       1422 Nov 30 2013 17:52:38 +07:00 its/vrf1/XMLDefault7970-7915-24-1.cnf.xml
331       1422 Nov 30 2013 17:52:40 +07:00 its/vrf1/XMLDefault7970-7916-12-1.cnf.xml
332       1422 Nov 30 2013 17:52:40 +07:00 its/vrf1/XMLDefault7970-7916-24-1.cnf.xml
333       1553 Nov 30 2013 17:52:40 +07:00 its/vrf1/XMLDefault7970-7914-2.cnf.xml
334       1553 Nov 30 2013 17:52:40 +07:00 its/vrf1/XMLDefault7970-7915-12-2.cnf.xml
335       1553 Nov 30 2013 17:52:40 +07:00 its/vrf1/XMLDefault7970-7915-24-2.cnf.xml
336       1553 Nov 30 2013 17:52:40 +07:00 its/vrf1/XMLDefault7970-7916-12-2.cnf.xml
337       1553 Nov 30 2013 17:52:42 +07:00 its/vrf1/XMLDefault7970-7916-24-2.cnf.xml
338       1260 Nov 30 2013 17:52:42 +07:00 its/vrf1/XMLDefault7971.cnf.xml
339       1422 Nov 30 2013 17:52:42 +07:00 its/vrf1/XMLDefault7971-7914-1.cnf.xml
340       1422 Nov 30 2013 17:52:42 +07:00 its/vrf1/XMLDefault7971-7915-12-1.cnf.xml
341       1422 Nov 30 2013 17:52:42 +07:00 its/vrf1/XMLDefault7971-7915-24-1.cnf.xml
342       1422 Nov 30 2013 17:52:42 +07:00 its/vrf1/XMLDefault7971-7916-12-1.cnf.xml
343       1422 Nov 30 2013 17:52:44 +07:00 its/vrf1/XMLDefault7971-7916-24-1.cnf.xml
344       1553 Nov 30 2013 17:52:44 +07:00 its/vrf1/XMLDefault7971-7914-2.cnf.xml
345       1553 Nov 30 2013 17:52:44 +07:00 its/vrf1/XMLDefault7971-7915-12-2.cnf.xml
346       1553 Nov 30 2013 17:52:44 +07:00 its/vrf1/XMLDefault7971-7915-24-2.cnf.xml
347       1553 Nov 30 2013 17:52:44 +07:00 its/vrf1/XMLDefault7971-7916-12-2.cnf.xml
348       1553 Nov 30 2013 17:52:44 +07:00 its/vrf1/XMLDefault7971-7916-24-2.cnf.xml
349       1260 Nov 30 2013 17:52:46 +07:00 its/vrf1/XMLDefault7975.cnf.xml
350       1422 Nov 30 2013 17:52:46 +07:00 its/vrf1/XMLDefault7975-7914-1.cnf.xml
351       1422 Nov 30 2013 17:52:46 +07:00 its/vrf1/XMLDefault7975-7915-12-1.cnf.xml
352       1422 Nov 30 2013 17:52:46 +07:00 its/vrf1/XMLDefault7975-7915-24-1.cnf.xml
353       1422 Nov 30 2013 17:52:46 +07:00 its/vrf1/XMLDefault7975-7916-12-1.cnf.xml
354       1422 Nov 30 2013 17:52:46 +07:00 its/vrf1/XMLDefault7975-7916-24-1.cnf.xml
355       1553 Nov 30 2013 17:52:48 +07:00 its/vrf1/XMLDefault7975-7914-2.cnf.xml
356       1553 Nov 30 2013 17:52:48 +07:00 its/vrf1/XMLDefault7975-7915-12-2.cnf.xml
357       1553 Nov 30 2013 17:52:48 +07:00 its/vrf1/XMLDefault7975-7915-24-2.cnf.xml
358       1553 Nov 30 2013 17:52:48 +07:00 its/vrf1/XMLDefault7975-7916-12-2.cnf.xml
359       1553 Nov 30 2013 17:52:48 +07:00 its/vrf1/XMLDefault7975-7916-24-2.cnf.xml
360       1260 Nov 30 2013 17:52:48 +07:00 its/vrf1/XMLDefault7985.cnf.xml
361        404 Nov 30 2013 16:39:02 +07:00 its/vrf1/ATADefault.cnf.xml
362       1224 Nov 30 2013 17:52:50 +07:00 its/vrf1/XMLDefaultCIPC.cnf.xml
363       1353 Nov 30 2013 17:52:50 +07:00 its/vrf1/XMLDefault6921.cnf.xml
364       1353 Nov 30 2013 17:52:50 +07:00 its/vrf1/XMLDefault6941.cnf.xml
365       1353 Nov 30 2013 17:52:50 +07:00 its/vrf1/XMLDefault6961.cnf.xml
366       1260 Nov 30 2013 17:52:50 +07:00 its/vrf1/XMLDefault6901.cnf.xml
367       1260 Nov 30 2013 17:52:50 +07:00 its/vrf1/XMLDefault6911.cnf.xml
368       1222 Nov 30 2013 17:52:52 +07:00 its/vrf1/XMLDefault7926.cnf.xml
369        903 Nov 30 2013 16:39:06 +07:00 its/united_states_7960-tones.xml
370       8777 Nov 30 2013 16:39:06 +07:00 its/united_states_7960-font.xml
371       1313 Nov 30 2013 16:39:06 +07:00 its/united_states_7960-kate.xml
372      19750 Nov 30 2013 16:39:06 +07:00 its/united_states_7960-dictionary.xml
373       2740 Nov 30 2013 16:39:08 +07:00 its/united_states_SCCP-dictionary.xml
374     496521 Dec 3 2013 12:38:48 +07:00 music-on-hold.au
375      55599 Dec 3 2013 17:23:12 +07:00 app-b-acd-aa-3.0.0.2.tcl
376    1030860 Dec 3 2013 17:44:44 +07:00 en_bacd_welcome.au
377          0 Dec 5 2013 14:10:12 +07:00 gui
378     828928 Dec 5 2013 14:20:14 +07:00 gui.tar
379       4118 Dec 5 2013 14:21:30 +07:00 gui/admin_user.html
380     677820 Dec 5 2013 14:21:32 +07:00 gui/admin_user.js
381       1029 Dec 5 2013 14:21:32 +07:00 gui/CiscoLogo.gif
382        639 Dec 5 2013 14:21:32 +07:00 gui/CME_GUI_README.TXT
383        953 Dec 5 2013 14:21:32 +07:00 gui/Delete.gif
384      16344 Dec 5 2013 14:21:32 +07:00 gui/dom.js
385        864 Dec 5 2013 14:21:34 +07:00 gui/downarrow.gif
386       6315 Dec 5 2013 14:21:34 +07:00 gui/ephone_admin.html
387       4558 Dec 5 2013 14:21:34 +07:00 gui/logohome.gif
388       3978 Dec 5 2013 14:21:34 +07:00 gui/normal_user.html
389      78428 Dec 5 2013 14:21:36 +07:00 gui/normal_user.js
390       1347 Dec 5 2013 14:21:36 +07:00 gui/Plus.gif
391        843 Dec 5 2013 14:21:36 +07:00 gui/sxiconad.gif
392        174 Dec 5 2013 14:21:36 +07:00 gui/Tab.gif
393       2496 Dec 5 2013 14:21:36 +07:00 gui/telephony_service.html
394        870 Dec 5 2013 14:21:38 +07:00 gui/uparrow.gif
395      10230 Dec 5 2013 14:21:38 +07:00 gui/xml-test.html
396       3412 Dec 5 2013 14:21:38 +07:00 gui/xml.template
397       2910 Dec 5 2013 15:33:52 +07:00 RingList.xml
398       2823 Dec 5 2013 14:41:20 +07:00 DistinctiveRingList.xml
399     326144 Dec 5 2013 14:46:50 +07:00 ringtones.tar
400          0 Dec 5 2013 14:47:18 +07:00 ringtones
401       8160 Dec 5 2013 14:47:18 +07:00 ringtones/Analog1.raw
402       8160 Dec 5 2013 14:47:18 +07:00 ringtones/Analog2.raw
403       5280 Dec 5 2013 14:47:18 +07:00 ringtones/AreYouThere.raw
404       5040 Dec 5 2013 14:47:20 +07:00 ringtones/AreYouThereF.raw
405       8160 Dec 5 2013 14:47:20 +07:00 ringtones/Bass.raw
406      12240 Dec 5 2013 14:47:20 +07:00 ringtones/CallBack.raw
407      16040 Dec 5 2013 14:47:20 +07:00 ringtones/Chime.raw
408       8160 Dec 5 2013 14:47:22 +07:00 ringtones/Classic1.raw
409      16080 Dec 5 2013 14:47:22 +07:00 ringtones/Classic2.raw
410      10800 Dec 5 2013 14:47:22 +07:00 ringtones/ClockShop.raw
411       2823 Dec 5 2013 14:47:22 +07:00 ringtones/DistinctiveRingList.xml
412       9600 Dec 5 2013 14:47:22 +07:00 ringtones/Drums1.raw
413      13440 Dec 5 2013 14:47:24 +07:00 ringtones/Drums2.raw
414      15840 Dec 5 2013 14:47:24 +07:00 ringtones/FilmScore.raw
415      16080 Dec 5 2013 14:47:24 +07:00 ringtones/HarpSynth.raw
416       8160 Dec 5 2013 14:47:24 +07:00 ringtones/Jamaica.raw
417      16080 Dec 5 2013 14:47:24 +07:00 ringtones/KotoEffect.raw
418      12720 Dec 5 2013 14:47:26 +07:00 ringtones/MusicBox.raw
419       8160 Dec 5 2013 14:47:26 +07:00 ringtones/Piano1.raw
420      15360 Dec 5 2013 14:47:26 +07:00 ringtones/Piano2.raw
421       9360 Dec 5 2013 14:47:26 +07:00 ringtones/Pop.raw
422       7200 Dec 5 2013 14:47:26 +07:00 ringtones/Pulse1.raw
423       4000 Dec 5 2013 14:47:28 +07:00 ringtones/Ring1.raw
424       4000 Dec 5 2013 14:47:28 +07:00 ringtones/Ring2.raw
425       4000 Dec 5 2013 14:47:28 +07:00 ringtones/Ring3.raw
426       4000 Dec 5 2013 14:47:28 +07:00 ringtones/Ring4.raw
427       4000 Dec 5 2013 14:47:30 +07:00 ringtones/Ring5.raw
428       4000 Dec 5 2013 14:47:30 +07:00 ringtones/Ring6.raw
429       4000 Dec 5 2013 14:47:30 +07:00 ringtones/Ring7.raw
430        495 Dec 5 2013 14:47:30 +07:00 ringtones/RingList.xml
431      10800 Dec 5 2013 14:47:30 +07:00 ringtones/Sax1.raw
432      14160 Dec 5 2013 14:47:32 +07:00 ringtones/Sax2.raw
433      16080 Dec 5 2013 14:47:32 +07:00 ringtones/Vibe.raw
434       1435 Dec 6 2013 17:33:04 +07:00 its/vrf1/SEP0C6803C179B8.cnf.xml
181395456 bytes available (75214848 bytes used)
RTR-01#
Create
Recognize Your Peers
Content for Community-Ad
