CME FXO-Caller id Unknown Number
netCisco86
Dear all,
I have CME ver 12.8 on ISR4331 in which caller-id is not showing as stated in the debug attached it is failed to be received.
I did a test by plug the fxo line to analog phone and did a test call in which the caller id appears on the analog phone.
But when plugging the line in the FXO port 0/2/1 and do a plar opx to the IP phone extension 4016, it shows unknown.
Below debug test call is attached with voice port settings.
Trying also these are not worthy ;
-no battery-reversal
-caller-id alerting dsp-pre-allocate
-caller-id alerting line-reversal
-caller-id alerting ring
voice-port 0/2/1
supervisory disconnect dualtone mid-call
no battery-reversal
cptone SA
timeouts call-disconnect 1
timeouts wait-release 1
connection plar opx immediate 4416
impedance complex2
caller-id enable
acampbell
Can you try the set up below.You may need both alerts for caller-id to work
Worth a try.
voice-port 0/2/1
battery-reversal
caller-id enable
Regards, Alex. Please rate useful posts.
Thanks Advocate  for your time and replay.
I`ll try it and update you back soon.
regards,
Hi again,
I did as informed, but same result unfortunately. Any other ideas , please.
thanks
