12-02-2012 03:18 AM - edited 03-16-2019 02:30 PM
I'm having this problem with my callmanager express.
I am not able to reach the GUI of CME in my browser.
What could be the problem?
I have copied all of my html files to the flash of my CME site router.
I made a directory in flash (GUI) inside this folder copied all the html files.
ip http server
ip http path flash:/GUI
telephony service
web admin system name admin pass cisco
dn-webedit
I'm using the voice vlan interface (10.10.201.1) for the GUI not working
any help would be appreciated
12-02-2012 04:23 AM
with "not working" what exaclty you mean, plz try and be specific? does the request gets timed out? whats the response code? you think there is any firewal?
12-02-2012 06:41 AM
Sorry for the miscommunication.
What i meant with not working is:
The GUI is not reachable after i have configured the CME telephony-service for GUI accesibility.
I am not using a firewall
Page cannot be displayed (IE)
12-02-2012 06:00 PM
-Is there any "http class" on the configuration? That sometimes brakes the GUI, if so, remove it.
-Can you ping that IP Address from your computer?
-Please remember: http://10.10.201.1/ccme.html
-Any access-list on the interface?
-Check if ip http secure-server is enabled and disable it
Let us know how it goes.
Jorge Armijo
12-03-2012 12:12 AM
Thanks for the replys.
I'm going to try this later seems i have another problem nowe.
i deleted the ios on my flash router accidently.
I have to fix this nowe with the tftpdnld rommon procedure.
Because when i boot my cisco router it says " canot load boot flash"
I'm using a tftp server to copy the flash back in my cisco router after the procedure it gives TFTP timed oud.
Hours of troubleshooting very painful job.
12-03-2012 01:13 AM
Instead of the tftp proccess personally i am using a card reader , i put into the card reader the flash , and i have move in the flash a lot of files in less than 5 minutes
