10-01-2015 04:14 PM - edited 03-17-2019 04:26 AM
I have no problems making or receiving calls from my Cisco phone to any phone outside my company over my SIP provider. We have two trunk lines with a floating third. The problem is that when I leave the office I want to CallForwardAll to my cell phone. The call does ring my cell phone and when I answer it there is no audio either way. I have tried using G.711 and G.729rb and that did not solve the problem.
show call active voice br
<ID>: <CallID> <start>.<index> +<connect> pid:<peer_id> <dir> <addr> <state>
dur hh:mm:ss tx:<packets>/<bytes> rx:<packets>/<bytes>
IP <ip>:<udp> rtt:<time>ms pl:<play>/<gap>ms lost:<lost>/<early>/<late>
delay:<last>/<min>/<max>ms <codec>
media inactive detected:<y/n> media cntrl rcvd:<y/n> timestamp:<time>
long duration call detected:<y/n> long duration call duration :<sec> timestamp:<time>
MODEMPASS <method> buf:<fills>/<drains> loss <overall%> <multipkt>/<corrected>
last <buf event time>s dur:<Min>/<Max>s
FR <protocol> [int dlci cid] vad:<y/n> dtmf:<y/n> seq:<y/n>
<codec> (payload size)
ATM <protocol> [int vpi/vci cid] vad:<y/n> dtmf:<y/n> seq:<y/n>
Tele <int> (callID) [channel_id] tx:<tot>/<v>/<fax>ms <codec> noise:<l> acom:<l> i/o:<l>/<l> dBm
MODEMRELAY info:<rcvd>/<sent>/<resent> xid:<rcvd>/<sent> total:<rcvd>/<sent>/<drops>
speeds(bps): local <rx>/<tx> remote <rx>/<tx>
Proxy <ip>:<audio udp>,<video udp>,<tcp0>,<tcp1>,<tcp2>,<tcp3> endpt: <type>/<manf>
bw: <req>/<act> codec: <audio>/<video>
tx: <audio pkts>/<audio bytes>,<video pkts>/<video bytes>,<t120 pkts>/<t120 bytes>
rx: <audio pkts>/<audio bytes>,<video pkts>/<video bytes>,<t120 pkts>/<t120 bytes>
Telephony call-legs: 0
SIP call-legs: 2
H323 call-legs: 0
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 2
6B : 43422 15:43:41.082 DST Thu Oct 1 2015.1 +10660 pid:100 Answer 10007554867 active
dur 00:00:06 tx:0/0 rx:0/0
IP 72.9.149.69:44650 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 TextRelay: off
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
long duration call detected:n long duration call duration:n/a timestamp:n/a
70 : 43423 15:43:41.092 DST Thu Oct 1 2015.1 +10640 pid:200 Originate 10002881353 active
IP 72.9.149.69:58982 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 TextRelay: off
SIP call-legs: 2
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
I can run any commands needed to help figure this out. Also, when I receive a call and want to transfer it to my cell manually, as soon as I enter the first digit for my area code I get a fast busy.
Current configuration : 18641 bytes
! Last configuration change at 15:43:01 DST Thu Oct 1 2015 by mdurham
! NVRAM config last updated at 17:08:36 DST Wed Sep 30 2015 by mdurham
version 15.1
service timestamps debug uptime
service timestamps log datetime msec localtime year
service password-encryption
service sequence-numbers
hostname CME_Router
boot-start-marker
boot-end-marker
logging buffered 10000000
enable secret 5 cisco
no aaa new-model
clock timezone Eastern -5 0
clock summer-time DST recurring
crypto pki trustpoint TP-self-signed-2516279958
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2516279958
revocation-check none
rsakeypair TP-self-signed-2516279958
crypto pki certificate chain TP-self-signed-2516279958
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32353136 32373939 3538301E 170D3133 30373233 30373030
31355A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 35313632
37393935 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100A322 EE57B83E 4C7B7947 8EE8EF6D 931234DB 41A4D133 19D8D297 32FF0E5F
10B94981 E7A1EA06 76CD851B FA24BDA8 561F4CC6 22C3B73B B0742465 571E07C9
04EE1661 7FC5B487 B6686CBB 22B49313 238DF90C 3795649E FA8CAD50 C0CE6A9D
E11FE11E 66870AC2 1492AE74 BBA1E419 1A7FE7F0 C88A8543 5CC6316C 2600101B
A32B0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 1402DCB2 F8C6A62B 687347AB DEA0875E ECB7063E 8C301D06
03551D0E 04160414 02DCB2F8 C6A62B68 7347ABDE A0875EEC B7063E8C 300D0609
2A864886 F70D0101 05050003 8181002E 9E5AC99B CCCF28EB 9D517ECD EA130719
EB97B0CA 09CA4AA9 5D88C9C0 FFAE75FE 09B78CD5 3023BC39 B98E4B1F D3B72C82
FDCB8BA1 620A9433 3ED237D6 CFCB8D1E 67BD4232 FECF61EB 37499502 BB3F2899
E77260E9 985F9938 C47E7A09 37A07302 3C851D7A DAEF35A5 495E0220 C3F17AFB
B68AE9D3 F0CFE894 7E8DBC39 ED077B
quit
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.69.1 192.168.69.240
ip dhcp excluded-address 192.168.200.1 192.168.200.240
ip dhcp excluded-address 10.110.0.1 10.110.0.20
ip dhcp excluded-address 192.168.125.1 192.168.125.9
ip dhcp pool AirPark-WiFi
network 192.168.200.0 255.255.255.0
default-router 192.168.200.1
domain-name mtd.home
dns-server 4.2.2.2
lease 0 12
ip dhcp pool Users
network 192.168.69.0 255.255.255.0
default-router 192.168.69.1
dns-server 4.2.2.2
option 150 ip 10.110.0.1
lease 0 12
ip dhcp pool Voice
network 10.110.0.0 255.255.255.0
default-router 10.110.0.1
dns-server 4.2.2.2
lease 0 12
ip dhcp pool TV
network 192.168.125.0 255.255.255.0
default-router 192.168.125.1
dns-server 4.2.2.2
lease 0 12
ip dhcp pool Reserved69
host 192.168.69.101 255.255.255.0
hardware-address 0800.091a.8987
dns-server 4.2.2.2
ip dhcp pool WirelessRES
host 192.168.200.252 255.255.255.0
hardware-address 001d.e04d.c323
dns-server 4.2.2.2
ip domain lookup source-interface GigabitEthernet0/0
ip domain name mtd.home
ip name-server 4.2.2.2
ip name-server 8.8.8.8
no ipv6 cef
password encryption aes
voice service voip
ip address trusted list
ipv4 72.9.149.69
ipv4 185.35.78.39
ipv4 10.110.0.2
allow-connections sip to sip
no supplementary-service sip moved-temporarily
redirect ip2ip
sip
registrar server
voice class codec 1
codec preference 1 g729r8
voice translation-rule 1
rule 1 /10002439001/ /1000/
rule 2 /1112901577/ /1010/
rule 3 /2229487364/ /1000/
voice translation-rule 2
rule 1 /\([2-9].........\)/ /1\1/
voice translation-rule 3
rule 1 /[*]86/ /1186/
voice translation-rule 4
rule 1 /411/ /18003733411/
voice translation-rule 5
rule 1 reject /0/
voice translation-profile BLOCK-INBOUND
translate calling 5
voice translation-profile Free_411
translate called 4
voice translation-profile Incoming_calls
translate called 1
voice translation-profile Ten_Digit_Dialing
translate called 2
voice translation-profile Voice_Mail
translate called 3
voice-card 0
license udi pid CISCO2851 sn FTX1331AJZF
dial-control-mib retain-timer 10080
dial-control-mib max-size 500
username mdurham privilege 15 password 7 cisco
redundancy
track 10 ip sla 1 reachability
delay down 1 up 1
track 20 ip sla 2 reachability
delay down 1 up 1
gw-accounting syslog
ip address 192.168.254.1 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Service-Engine0/1
description "CUE-AIM Voicemail Module"
ip unnumbered GigabitEthernet0/1.110
ip nat inside
service-module ip address 10.110.0.2 255.255.255.0
service-module ip default-gateway 10.110.0.1
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.2
encapsulation dot1Q 2
ip address 192.168.0.253 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.50
description "VMWare Server"
encapsulation dot1Q 50
ip address 192.168.50.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.69
description "Data Network"
encapsulation dot1Q 69 native
ip address 192.168.69.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.110
description "Voice Network"
encapsulation dot1Q 110
ip address 10.110.0.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.125
description "TV & Media Network"
encapsulation dot1Q 125
ip address 192.168.125.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.172
description Alt Internet Conntection via Sommer's
encapsulation dot1Q 172
ip address 172.16.31.1 255.255.255.248
ip nat inside
shutdown
interface GigabitEthernet0/1.200
description "Guest User Network"
encapsulation dot1Q 200
ip address 192.168.200.1 255.255.255.0
ip access-group 100 in
ip nat inside
router eigrp 1577
network 10.110.0.0 0.0.0.255
network 192.168.0.0
network 192.168.50.0
network 192.168.254.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 192.168.254.254 track 10
ip route 0.0.0.0 0.0.0.0 192.168.0.254 10 track 20
ip route 10.110.0.2 255.255.255.255 Service-Engine0/1
ip sla 1
icmp-echo 192.168.254.254 source-ip 192.168.254.1
threshold 750
timeout 900
frequency 1
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 192.168.0.254 source-ip 192.168.0.253
threshold 750
timeout 900
frequency 1
ip sla schedule 2 life forever start-time now
logging esm config
logging history size 500
access-list 100 remark "Block access from the Guest network to everything except the printer & the Interent
access-list 100 permit ip any host 192.168.69.99
access-list 100 permit ip host 192.168.200.252 host 192.168.50.100
access-list 100 permit ip any 192.168.200.0 0.0.0.7
access-list 100 deny ip any 192.168.0.0 0.0.255.255
access-list 100 permit ip any any
tftp-server flash:P00308000800.sbn
tftp-server flash:P00308000800.loads
tftp-server flash:P00308000800.txt
tftp-server flash:P00308000800.sb2
tftp-server flash:SEP0013191f4980.cnf.xm
tftp-server flash:SEP0013191f4980.cnf.xml
tftp-server flash:p00308010200.loads
tftp-server flash:p00308010200.bin
tftp-server flash:P00308010200.sb2
tftp-server flash:P00308010200.sbn
tftp-server flash:SEP001b535ccabd.cnf.xml
tftp-server flash:Phone/7970/SCCP70.9-1-1SR1S.loads alias SCCP70.9-1-1SR1S.loads
tftp-server flash:Phone/7970/jar70sccp.9-1-1TH1-16.sbn alias jar70sccp.9-1-1TH1-16.sbn
tftp-server flash:Phone/7970/dsp70.9-1-1TH1-16.sbn alias dsp70.9-1-1TH1-16.sbn
tftp-server flash:Phone/7970/cvm70sccp.9-1-1TH1-16.sbn alias cvm70sccp.9-1-1TH1-16.sbn
tftp-server flash:Phone/7970/apps70.9-1-1TH1-16.sbn alias apps70.9-1-1TH1-16.sbn
tftp-server flash:Phone/7970/cnu70.9-1-1TH1-16.sbn alias cnu70.9-1-1TH1-16.sbn
tftp-server flash:Phone/7970/term71.default.loads alias term71.default.loads
tftp-server flash:Phone/7970/term70.default.loads alias term70.default.loads
tftp-server flash:Phone/7970/List.xml
tftp-server flash:Phone/7970/CTS_80x53.png
tftp-server flash:Phone/7970/CTS_320x212.png
control-plane
no ccm-manager fax protocol cisco
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp profile default
dial-peer cor custom
name LoK_Local
name LoK_National
name LoK_International
name LoK_EMS
dial-peer cor list Keyring-Local
member LoK_Local
member LoK_EMS
dial-peer cor list Keyring-National
member LoK_Local
member LoK_National
member LoK_EMS
dial-peer cor list Keyring-International
member LoK_Local
member LoK_National
member LoK_International
member LoK_EMS
dial-peer cor list Keyring-EMS-Only
member LoK_EMS
dial-peer cor list Door-Local
member LoK_Local
member LoK_EMS
dial-peer cor list Door-National
member LoK_Local
member LoK_National
member LoK_EMS
dial-peer cor list Door-International
member LoK_Local
member LoK_National
member LoK_EMS
dial-peer cor list Door-EMS-Only
member LoK_EMS
dial-peer voice 911 voip
corlist outgoing Door-EMS-Only
destination-pattern [2-9]11
session protocol sipv2
session target sip-server
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 100 voip
description *** Incoming Calls VoIP ***
translation-profile incoming Incoming_calls
call-block translation-profile incoming BLOCK-INCOMING
call-block disconnect-cause incoming call-reject
preference 1
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 210 voip
corlist outgoing Door-National
description *** Outbound 11 Digit Dialing Calls ***
preference 1
destination-pattern 1[2-9]..[2-9]......$
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 200 voip
description *** Outbound 10 Digit Dialing Calls ***
translation-profile outgoing Ten_Digit_Dialing
preference 1
destination-pattern [2-9].........$
translate-outgoing called 3
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 220 voip
description *** Outbound * Digit Dialing Calls ***
preference 1
destination-pattern 1186
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 221 voip
translation-profile outgoing Voice_Mail
preference 1
destination-pattern *86
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 222 voip
description *** Outbound - Free 411 (Information) Calls ***
translation-profile outgoing Free_411
preference 1
destination-pattern 411
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 600 pots
description "To be able to answer the PSTN line from an IP phone by dialing
destination-pattern 6000
dial-peer voice 5000 voip
description Dial-peer to the Voicemail System"
destination-pattern 5000
b2bua
session target ipv4:10.110.0.2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer inbound selection sip-trunk
sip-ua
credentials username 2229487364 password 7 phone realm anveo.com
authentication username 2229487364 password 7 phone realm anveo.com
mwi-server ipv4:10.110.0.2 expires 3600 port 5060 transport udp unsolicited
registrar dns:sip.anveo.com:5010 expires 180
sip-server dns:sip.anveo.com:5010
gatekeeper
shutdown
telephony-service
max-ephones 50
max-dn 100
ip source-address 10.110.0.1 port 2000
service phone daysDisplayNotActive 1,7
service phone displayOnTime 08:00
service phone displayOnDuration 12
service phone displayIdleTimeout 00:10
service phone settingsAccess 1
service phone modeOfOperation 1
service phone displaywhebincomingcall 1
system message The Corporation
url services http://phone-xml.berbee.com/menu.xml
load 7960-7940 P00308000800
load 7970 SCCP70.9-1-1SR1S
time-zone 12
voicemail 5000
mwi relay
max-conferences 4 gain -6
moh MoH.wav
multicast moh 239.2.2.2 port 2000
web admin system name mdurham password Education$1
dn-webedit
time-webedit
transfer-system full-consult
directory entry 12 8002758777 name US Post Office
directory entry 13 8004633339 name FedEx
directory entry 14 8772234714 name QuickBooks Support
directory entry 15 8665403229 name eBay
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1 dual-line
number 1000
label "Solutions"
description Administrator
call-forward all 0002881353
call-forward busy 5000
call-forward noan 5000 timeout 17
corlist incoming Keyring-National
ephone-dn 2 dual-line
number 1010
label "Michael T. Durham"
ephone-dn 3 dual-line
number 1101
label Office
description Office
ephone-dn 4 dual-line
number 1102
label "Living Room"
description Living Room
ephone-dn 5 dual-line
number 1103
label Shop
description Shop
ephone-dn 6 dual-line
number 1104
label Hanger
description Hanger
ephone-dn 7
number 1105
ephone-dn 8
number 1106
trunk 1000
ephone-dn 11
number A1101
name Intercom Office
intercom A1102 no-mute label "Living Room"
ephone-dn 12
number A1101
intercom A1103 no-mute label "Shop"
ephone-dn 13
number A1102
name Intercom Living Room
intercom A1101 no-mute label "Office"
ephone-dn 14
number A1102
ephone-dn 15
number A1103
name intercom Shop
ephone-dn 16
number A1103
name Iintercom Shop
ephone-dn 17
number A1105
name Intercom test
ephone-dn 18
number A1105
name Intercom test
ephone-dn 19
number A1105
name Intercom test
ephone-dn 20
number A1102
intercom A1105 no-mute label "Janice Durham"
ephone-dn 99
number 5998....
mwi off
ephone-dn 100
number 5999....
mwi on
ephone 1
device-security-mode none
mac-address 0016.C7AE.E08C
speed-dial 1 3867554867 label "Durham"
speed-dial 2 6000 label "PSTN"
type 7970
button 1:7 2:17 3:18 4:19
ephone 2
description "Michael's Phone"
mac-address 0008.2154.1606
type 7940
button 1:1 2f2
ephone 3
description "Office Phone"
video
mac-address 0018.1994.565F
type 7970
mwi-line 2
button 1:3 2:1 3f2 5:11
button 6:12
ephone 4
description "Living Room Phone"
mac-address 0013.191F.4317
type 7960
button 1:1 2:2 4:13 5:14
button 6:20
ephone 5
description Hanger Phone
mac-address 0008.2128.7A30
type 7940
button 1:1 2f2
ephone 6
description "Shop Video Phone"
video
mac-address 0050.6003.6B74
type 7985
button 1:5 2:1 3f2 5:15
button 6:16
ephone 7
description "Office Video Phone"
video
mac-address 0050.6003.2BE8
type 7985
button 6:12
ephone 8
mac-address 0011.93C2.AE67
type 7905
button 1:8
ephone 10
mac-address 0022.90FD.8AA4
max-calls-per-button 4
type 7921
button 1:1
ephone 11
mac-address 0016.C798.7B51
button 1:1
ephone 19
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line 258
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
exec-timeout 0 0
privilege level 15
password 7 cisco
logging synchronous
login local
monitor
transport input telnet ssh
transport output telnet
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
ntp master 2
end
10-02-2015 01:35 AM
Hi Michael
Can you do the following and then attach the logs here. please include call details..
conf t
service timestamps debug datetime localtime msec
logging buffered 10000000 debug
no logging console
no logging monitor
default logging rate-limit
default logging queue-limit
Then..
<Enable debugs, then test again.>
debug ccsip messages
<Enable session capture to txt file in terminal program.> (such as Putty)
then do the ff:
terminal length 0
show logging
10-02-2015 01:09 PM
10-02-2015 03:32 PM
Hi Michael.. Looking at the logs, the only thing that stands out is that the ITSP is using non standard ports for media. Media ports should be in range 16384 to 32767.
Can you send the ff
1. Same debug above for normal call.
2.sh voip rtp connection... For normal call.
Repeat same foforwarded call. Send me both logs
10-05-2015 12:07 PM
Sorry I could not get this to you sooner,
CME_Router#sh voip rtp connection
VoIP RTP active connections :
No. CallId dstCallId LocalRTP RmtRTP LocalIP RemoteIP
1 1114 1115 17716 44734 192.168.254.1 72.9.149.69
Found 1 active RTP connections
1 1140 1141 19034 48360 192.168.254.1 72.9.149.69
2 1141 1140 16944 40920 192.168.254.1 72.9.149.69
Found 2 active RTP connections
10-07-2015 12:41 AM
Hi Michael please try this..
Config t
voice class sip-profiles 1
request INVITE sip-header Diversion modify "<sip:(.*)@192.168.254.1>" "<sip:06 69487364@192.168.254.1>"
Then apply the sip profile to the outbound dial peer to your itsp
dial-p v XX v
voice-class sip profile 1
