05-11-2012 04:55 AM - edited 03-16-2019 11:06 AM
Hi Everyone,
Got the outbound SIP working with my 2851 and call manager express 8. Inbound rings at the proper extension, but the calling phone gets a busy signal. I pulled a SIP trace and it says "Internal Server Error" but I can't figure out the problem, so I'm hoping one of the experts on here can point me in the right direction.
Thanks in advance!
David
Date: Thu, 10 May 2012 13:25:26 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Supported: replaces
Content-Type: application/sdp
Content-Length: 285
v=0
o=root 7920 7920 IN IP4 74.63.41.218
s=session
c=IN IP4 74.63.41.218
t=0 0
m=audio 16466 RTP/AVP 0 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
May 10 09:24:55.889: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 74.63.41.218:5060;branch=z9hG4bK76b5a7c9;rport
From: "5163193019" <sip:5163193019@74.63.41.218>;tag=as0a195cd3
To: <sip:5164038959@96.250.50.2xx:5060>
Date: Thu, 10 May 2012 09:24:55 GMT
Call-ID: 21789578522fa0d02d991cd52d3b083f@74.63.41.218
CSeq: 102 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Sent:
[b]SIP/2.0 500 Internal Server Error[/b]
To: <sip:5164038959@96.250.50.2xx:5060>;tag=3EFA410-119D
CSeq: 102 INVITE
Content-Length: 0
May 10 09:24:55.897: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:5164038959@96.250.50.2xx:5060 SIP/2.0
Contact: <sip:5163193019@74.63.41.218>
CSeq: 102 ACK
User-Agent: VoIPMS/SERAST
Max-Forwards: 70
Remote-Party-ID: "5163193019" <sip:5163193019@74.63.41.218>;privacy=off;screen=no
Content-Length: 0CONFIG:
------------------ show version ------------------ Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 15.1(1)T, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2010 by Cisco Systems, Inc. Compiled Mon 22-Mar-10 01:25 by prod_rel_team ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1) CME uptime is 8 hours, 31 minutes System returned to ROM by power-on System image file is "flash:c2800nm-ipvoicek9-mz.151-1.T.bin" Last reload type: Normal Reload This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. Cisco 2851 (revision 53.51) with 512000K/12288K bytes of memory. Processor board ID FTX1212A1DS 2 Gigabit Ethernet interfaces 1 terminal line 4 Voice FXO interfaces 1 cisco service engine(s) DRAM configuration is 64 bits wide with parity enabled. 239K bytes of non-volatile configuration memory. 250880K bytes of ATA CompactFlash (Read/Write) License Info: License UDI: ------------------------------------------------- Device# PID SN ------------------------------------------------- *0 CISCO2851 FTX1212A1DS Configuration register is 0x2102 ------------------ show running-config ------------------ Building configuration... Current configuration : 8958 bytes ! ! Last configuration change at 03:45:25 UTC Fri May 11 2012 by david ! version 15.1 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname CME ! boot-start-marker boot-end-marker ! enable secret 5 <removed> enable password <removed> ! no aaa new-model no network-clock-participate slot 1 ! dot11 syslog ip source-route ! ! ip cef no ip dhcp use vrf connected ip dhcp excluded-address 172.16.1.1 172.16.1.10 ! ip dhcp pool VOICE network 172.16.1.0 255.255.255.0 default-router 172.16.1.1 option 150 ip 172.16.1.1 ! ! ip domain name ipolawgroup.com ip name-server 4.2.2.2 no ipv6 cef multilink bundle-name authenticated ! ! ! ! ! ! voice rtp send-recv ! voice service voip gcid clid substitute name allow-connections h323 to h323 allow-connections h323 to sip allow-connections sip to h323 allow-connections sip to sip no supplementary-service sip moved-temporarily no supplementary-service sip refer sip e911 transport switch udp tcp asserted-id ppi midcall-signaling passthru no call service stop ! voice class codec 1 codec preference 1 g729r8 codec preference 2 g711ulaw codec preference 3 g711alaw ! voice class h323 1 telephony-service ccm-compatible ccm-compatible ! ! ! ! voice translation-rule 2 rule 1 /105/ /5164038926/ ! voice translation-rule 3 rule 1 /5164038959/ /105/ ! ! voice translation-profile INCOMING ! ! voice-card 0 ! voice-card 1 ! crypto pki token default removal timeout 0 ! ! ! ! license udi pid CISCO2851 sn FTX1212A1DS archive log config hidekeys username cisco privilege 15 password 0 <removed> ! ! ! ! ! ! ! interface GigabitEthernet0/0 description LAN_INTERFACE ip address 172.16.1.1 255.255.255.0 ip nat inside ip virtual-reassembly duplex auto speed auto no mop enabled ! interface Service-Engine0/1 ip address 172.16.200.1 255.255.255.252 service-module ip address 172.16.200.2 255.255.255.252 service-module ip default-gateway 172.16.200.1 ! interface GigabitEthernet0/1 description WAN_INTERFACE ip address xx.xxx.xx.xxx 255.255.255.0 ip nat outside ip virtual-reassembly duplex auto speed auto no mop enabled ! ip forward-protocol nd ! ip http server ip http access-class 10 ip http authentication local no ip http secure-server ip http path flash: ! ip nat inside source list 1 interface GigabitEthernet0/1 overload ip route 0.0.0.0 0.0.0.0 xx.xxx.xx.x ip route 10.10.1.0 255.255.255.0 172.16.1.254 ! access-list 1 permit 172.16.1.0 0.0.0.255 dialer-list 1 protocol ip permit ! ! tftp-server flash:term06.default.loads tftp-server flash:term41.default.loads tftp-server flash:P00308010200.bin alias P00308010200.bin tftp-server flash:P00308010200.loads alias P00308010200.loads tftp-server flash:P00308010200.sb2 alias P00308010200.sb2 tftp-server flash:P00308010200.sbn alias P00308010200.sbn tftp-server flash:term42.default.loads tftp-server flash:term62.default.loads tftp-server flash:term45.default.loads tftp-server flash:term65.default.loads tftp-server flash:term70.default.loads tftp-server flash:term71.default.loads tftp-server flash:/Ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml tftp-server flash:/Ringtones/AreYouThereF.raw alias AreYouThereF.raw tftp-server flash:/Ringtones/FilmScore.raw alias FilmScore.raw tftp-server flash:/Ringtones/HarpSynth.raw alias HarpSynth.raw tftp-server flash:/Ringtones/Jamaica.raw alias Jamaica.raw tftp-server flash:/Ringtones/KotoEffect.raw alias KotoEffect.raw tftp-server flash:/Ringtones/MusicBox.raw alias MusicBox.raw tftp-server flash:/Ringtones/Piano1.raw alias Piano1.raw tftp-server flash:/Ringtones/Piano2.raw alias Piano2.raw tftp-server flash:/Ringtones/Pop.raw alias Pop.raw tftp-server flash:/Ringtones/Pulse1.raw alias Pulse1.raw tftp-server flash:/Ringtones/Ring1.raw alias Ring1.raw tftp-server flash:/Ringtones/Ring2.raw alias Ring2.raw tftp-server flash:/Ringtones/Ring3.raw alias Ring3.raw tftp-server flash:/Ringtones/Ring4.raw alias Ring4.raw tftp-server flash:/Ringtones/Ring6.raw alias Ring6.raw tftp-server flash:/Ringtones/Ring7.raw alias Ring7.raw tftp-server flash:/Ringtones/Sax1.raw alias Sax1.raw tftp-server flash:/Ringtones/Sax2.raw alias Sax2.raw tftp-server flash:/Ringtones/Vibe.raw alias Vibe.raw tftp-server flash:/Ringtones/RingList.xml alias RingList.xml tftp-server flash:/Ringtones/Analog1.raw alias Analog1.raw tftp-server flash:/Ringtones/Analog2.raw alias Analog2.raw tftp-server flash:/Ringtones/AreYouThere.raw alias AreYouThere.raw tftp-server flash:/Ringtones/Bass.raw alias Bass.raw tftp-server flash:/Ringtones/CallBack.raw alias CallBack.raw tftp-server flash:/Ringtones/Chime.raw alias Chime.raw tftp-server flash:/Ringtones/Classic1.raw alias Classic1.raw tftp-server flash:/Ringtones/Classic2.raw alias Classic2.raw tftp-server flash:/Ringtones/ClockShop.raw alias ClockShop.raw tftp-server flash:/Ringtones/Drums1.raw alias Drums1.raw tftp-server flash:/Ringtones/Drums2.raw alias Drums2.raw ! control-plane ! ! voice-port 1/0/0 connection plar opx 102 caller-id enable ! voice-port 1/0/1 ! voice-port 1/0/2 ! voice-port 1/0/3 ! ccm-manager music-on-hold ! ! ! dial-peer voice 100 voip description DIAL_PEER_TO_CUE destination-pattern 77[5-9] session protocol sipv2 session target ipv4:172.16.200.2 dtmf-relay sip-notify codec g711ulaw no vad ! dial-peer voice 10 pots description POTS_DIAL_PEER_OUTGOING destination-pattern 1[2-9]..[2-9]...... port 1/0/0 ! dial-peer voice 1 voip incoming called-number 51640389.. voice-class sip asserted-id ppi no voice-class sip block 180 no voice-class sip block 183 no voice-class sip block 181 voice-class sip pass-thru headers unsupp voice-class sip pass-thru content unsupp voice-class sip pass-thru content sdp dtmf-relay rtp-nte ! dial-peer voice 2 voip destination-pattern [2-9]..[2-9]...... session protocol sipv2 session target ipv4:74.63.41.218 session transport udp voice-class sip asserted-id ppi no voice-class sip block 180 no voice-class sip block 183 no voice-class sip block 181 voice-class sip pass-thru headers unsupp voice-class sip pass-thru content unsupp voice-class sip pass-thru content sdp dtmf-relay rtp-nte codec g711ulaw ! ! ! telephony-service authentication credential cisco cisco max-ephones 30 max-dn 45 ip source-address 172.16.1.1 port 2000 system message IPO Law Group url services http://172.16.200.2/voiceview/common/login.do url authentication http://172.16.200.1/CCMCIP/authenticate.asp cnf-file location flash: load 7960-7940 P00308010200 load 7941 term41.default.loads load 7942 term42.default.loads load 7945 term70.default.loads load 7961 term06.default.loads load 7962 term62.default.loads load 7965 term71.default.loads max-conferences 4 gain -6 moh flash:music-on-hold.au multicast moh 239.1.1.1 port 2000 web admin system name cisco password <removed> dn-webedit time-webedit transfer-system full-consult create cnf-files version-stamp Jan 01 2002 00:00:00 ! ! ephone-dn 1 dual-line number 101 call-forward noan 777 timeout 16 ! ! ephone-dn 2 dual-line number 102 call-forward busy 777 call-forward noan 777 timeout 16 ! ! ephone-dn 3 dual-line number 103 call-forward busy 777 call-forward noan 777 timeout 16 ! ! ephone-dn 4 dual-line number 104 ! ! ephone-dn 5 dual-line number 5164038959 description DID 1 VOIPMS ! ! ephone-dn 6 dual-line number 106 ! ! ephone-dn 7 dual-line number 107 ! ! ephone-dn 8 dual-line number 108 ! ! ephone-dn 9 dual-line number 109 ! ! ephone-dn 10 dual-line number 110 ! ! ephone-dn 11 dual-line number 111 ! ! ephone-dn 12 dual-line number 112 ! ! ephone-dn 13 dual-line number 113 ! ! ephone-dn 14 dual-line number 114 ! ! ephone-dn 15 dual-line number 115 ! ! ephone-dn 16 dual-line number 116 ! ! ephone-dn 17 dual-line number 117 ! ! ephone-dn 18 dual-line number 118 ! ! ephone-dn 19 dual-line number 119 ! ! ephone-dn 20 dual-line number 120 ! ! ephone-dn 21 dual-line number 121 ! ! ephone-dn 22 dual-line number 122 ! ! ephone-dn 23 dual-line number 123 ! ! ephone-dn 24 dual-line number 124 ! ! ephone-dn 25 dual-line number 125 ! ! ephone-dn 26 dual-line number 126 ! ! ephone-dn 27 dual-line number 127 ! ! ephone-dn 28 dual-line number 128 ! ! ephone-dn 29 dual-line number 129 ! ! ephone-dn 30 dual-line number 130 ! ! ephone 2 mac-address 0013.60B5.26F1 username "user2" type 7960 button 1:2 ! ! ! ephone 3 mac-address 000E.D759.515C type 7940 button 1:3 2:5 ! ! ! line con 0 line aux 0 line 258 no activation-character no exec transport preferred none transport input all transport output pad telnet rlogin lapb-ta mop udptn v120 ssh line vty 0 4 password <removed> login local transport input ssh ! scheduler allocate 20000 1000 end
Solved! Go to Solution.
05-16-2012 04:58 PM
ok while you are doing that..
can you try to remove this commands on dial-peer 1, please add codec 711ulaw back to it.
05-11-2012 05:53 AM
try this:
voice service voip
ip address trusted list
ipv4 x.x.x.x x.x.x.x
05-11-2012 05:59 AM
Thanks for the reply Tun Moe. Its not taking the commands:
05-11-2012 07:19 AM
sorry David. the command I suggested only work for v8.1 and after.
I think you have v8.0
can you do show sip-ua status/stat
05-11-2012 07:42 AM
Yes, I'm on 8.0
CME#show sip-ua status
SIP User Agent Status
SIP User Agent for UDP : ENABLED
SIP User Agent for TCP : ENABLED
SIP User Agent for TLS over TCP : ENABLED
SIP User Agent bind status(signaling): DISABLED
SIP User Agent bind status(media): DISABLED
SIP early-media for 180 responses with SDP: ENABLED
SIP max-forwards : 70
SIP DNS SRV version: 2 (rfc 2782)
NAT Settings for the SIP-UA
Role in SDP: NONE
Check media source packets: DISABLED
Maximum duration for a telephone-event in NOTIFYs: 2000 ms
SIP support for ISDN SUSPEND/RESUME: ENABLED
Redirection (3xx) message handling: ENABLED
Reason Header will override Response/Request Codes: DISABLED
Out-of-dialog Refer: DISABLED
Presence support is DISABLED
protocol mode is ipv4
SDP application configuration:
Version line (v=) required
Owner line (o=) required
Timespec line (t=) required
Media supported: audio video image
Network types supported: IN
Address types supported: IP4 IP6
Transport types supported: RTP/AVP udptl
05-11-2012 09:05 AM
can you please add
codec g711ulaw
under
and test it again
thanks
05-11-2012 09:25 AM
Same symptoms, the extension rings and the calling phone has a busy signal.
! dial-peer voice 1 voip incoming called-number 51640389.. voice-class sip asserted-id ppi no voice-class sip block 180 no voice-class sip block 183 no voice-class sip block 181 voice-class sip pass-thru headers unsupp voice-class sip pass-thru content unsupp voice-class sip pass-thru content sdp dtmf-relay rtp-nte codec g711ulaw !
05-14-2012 02:34 PM
Have a more detailed sip trace, still need help please!
CME#
CME#
.May 14 16:44:09.684: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [74.63.41.218]:5060
.May 14 16:44:09.684: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
.May 14 16:44:09.684: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
.May 14 16:44:09.684: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:xxxxxxxx60@xx.xxx.xx.xxx:5060 SIP/2.0
Via: SIP/2.0/UDP 74.63.41.218:5060;branch=z9hG4bK09426ff8;rport
To:
Contact:
Call-ID: 372c3b68582552781c93894f3331c819@74.63.41.218
CSeq: 102 INVITE
Max-Forwards: 70
Remote-Party-ID: "xxxxxxxx26" ;privacy=off;screen=no
Date: Mon, 14 May 2012 16:45:46 GMT
Supported: replaces
Content-Length: 285
v=0
s=session
t=0 0
m=audio 11968 RTP/AVP 0 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
.May 14 16:44:09.684: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
.May 14 16:44:09.688: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x4871BFB8) with key=[9] to table
.May 14 16:44:09.688: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 74.63.41.218,Port 5060, Transport 1, SentBy Port 5060
.May 14 16:44:09.688: //-1/DCCBEED18050/SIP/State/sipSPIChangeState: 0x4871BFB8 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
.May 14 16:44:09.688: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone edt to SIP default timezone = GMT
.May 14 16:44:09.688: //-1/DCCBEED18050/SIP/Info/sipSPISetInfoFromRpid: Received current remote name: xxxxxxxx26, current remote number: xxxxxxxx26
.May 14 16:44:09.688: //-1/DCCBEED18050/SIP/Info/sipSPISetInfoFromRpid: Received ;screen=no ;privacy=off -> Setting Octet3A 0x80, extended_privacy 0x00
.May 14 16:44:09.688: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
.May 14 16:44:09.688: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCSTA: No CSTA found in inbound container
.May 14 16:44:09.688: //-1/DCCBEED18050/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
.May 14 16:44:09.688: //-1/DCCBEED18050/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4871BFB8 key=372c3b68582552781c93894f3331c819@74.63.41.218xxxxxxxx60
.May 14 16:44:09.688: //-1/DCCBEED18050/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on carrier id
.May 14 16:44:09.688: //-1/DCCBEED18050/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on Incoming called number: xxxxxxxx60
.May 14 16:44:09.688: //-1/DCCBEED18050/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on destination pattern: xxxxxxxx26
.May 14 16:44:09.688: //-1/DCCBEED18050/SIP/Info/ccsipUpdateIncomingCallParams: ccCallInfo: Calling name xxxxxxxx26, number xxxxxxxx26, Calling oct3 0x00, oct_3a 0x80, Called number xxxxxxxx60
.May 14 16:44:09.688: //-1/DCCBEED18050/SIP/Info/sipSPIGetShrlPeer: Try match incoming dialpeer for Calling number: : xxxxxxxx26
.May 14 16:44:09.692: //-1/DCCBEED18050/SIP/Info/sipSPIGetFromCalledPartyId: P-Called-Party-ID header not found
.May 14 16:44:09.692: //-1/DCCBEED18050/SIP/Info/sipSPIGetPeerByCalledPartyId: P-Called-Party-ID not found or parse error
.May 14 16:44:09.692: //-1/DCCBEED18050/SIP/Info/sipSPIGetCallConfig: No match found for P-Called-Party-ID
.May 14 16:44:09.692: //-1/DCCBEED18050/SIP/Info/sipSPIGetCallConfig: Peer tag 1 matched for incoming call
.May 14 16:44:09.692: //-1/DCCBEED18050/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
.May 14 16:44:09.692: //-1/DCCBEED18050/SIP/Info/sipSPIGetCallConfig: This call is being treated for E911
.May 14 16:44:09.692: //-1/DCCBEED18050/SIP/Info/sipSPIGetCallConfig: Not using Voice Class Codec
.May 14 16:44:09.692: //-1/DCCBEED18050/SIP/Info/sipSPIGetCallConfig: Checking Video Type Rate=-1 video_codec_allowed=1F
.May 14 16:44:09.692: //-1/DCCBEED18050/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
.May 14 16:44:09.692: //-1/DCCBEED18050/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=0
.May 14 16:44:09.692: //-1/DCCBEED18050/SIP/Info/sipSPIGetCallConfig: xcoder high-density disabled
.May 14 16:44:09.692: //-1/DCCBEED18050/SIP/Info/sipSPIGetCallConfig: Flow Mode set to FLOW_THROUGH
.May 14 16:44:09.692: //-1/DCCBEED18050/SIP/Info/sipSPIGetCallConfig: Media forking disabled
.May 14 16:44:09.692: //-1/DCCBEED18050/SIP/Info/sipSPIContinueNewMsgInvite: Calling name xxxxxxxx26, number xxxxxxxx26, Calling oct3 0x00, oct_3a 0x80, ext_priv 0x00, Called number xxxxxxxx60, oct3 0x00
.May 14 16:44:09.692: //-1/DCCBEED18050/SIP/Info/sipSPIContinueNewMsgInvite: Carrier id code , prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
.May 14 16:44:09.692: //-1/DCCBEED18050/SIP/Info/sipSPIValidateRequestUri: Not Enabled
.May 14 16:44:09.692: //-1/DCCBEED18050/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
.May 14 16:44:09.692: //27/DCCBEED18050/SIP/Info/sipSPI_ipip_IsSDPPassthruEnabled: - 1
.May 14 16:44:09.692: //27/DCCBEED18050/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:2 tag:0
.May 14 16:44:09.692: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckHeaderSupport: Found Supported header Resource-Priority
.May 14 16:44:09.692: //27/DCCBEED18050/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
.May 14 16:44:09.692: //27/DCCBEED18050/SIP/Info/sipSPIProcessDiversionHeader: No diversion headers recvd from app container
.May 14 16:44:09.692: //27/DCCBEED18050/SIP/Info/sipSPIProcessReplacesHeader: No replaces hdr found
.May 14 16:44:09.692: //27/DCCBEED18050/SIP/Info/sipSPI_ipip_ProcessSDPForPthru:
.May 14 16:44:09.692: //27/DCCBEED18050/SIP/Info/sipSPI_ipip_GetContentSDPForPthru: Getting content to pass-through
.May 14 16:44:09.692: //27/DCCBEED18050/SIP/Media/sipSPI_ipip_GetContentSDPForPthru: Updated SDP from inbound container:285
.May 14 16:44:09.692: //27/DCCBEED18050/SIP/Info/sipSPI_ipip_ProcessPthruSDPInInvite:
.May 14 16:44:09.692: //27/DCCBEED18050/SIP/Info/sipSPI_ipip_DoPthruMediaNegotiation:
SIP: Attribute mid, level 1 instance 1 not found.
.May 14 16:44:09.692: //27/DCCBEED18050/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = xx.xxx.xx.xxx
.May 14 16:44:09.692: //27/DCCBEED18050/SIP/State/sipSPIChangeStreamState: Stream (callid = -1) State changed from (STREAM_DEAD) to (STREAM_ADDING)
.May 14 16:44:09.692: //27/DCCBEED18050/SIP/Info/sipSPICompareSDP: Comparison not needed for first offer sdp
.May 14 16:44:09.692: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISipSdpFree:
.May 14 16:44:09.692: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_FreeSipRawSdp: no sdp to free
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's a Flow thru
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 27) to the VOIP RTP library
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Media/sipSPIAddStream: Reserved port 16610 for rtp/rtcp
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = xx.xxx.xx.xxx
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = xx.xxx.xx.xxx, lport = 16610, raddr = 74.63.41.218, rport=11968, do_rtcp=TRUE
src_callid = 27, dest_callid = -1, stream type = voice+dtmf, stream direction = SENDRECV
media_ip_addr = 74.63.41.218, vrf tableid = 0 media_addr_type = 1
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Info/sipSPICreateRtpSession: sess: 476A6480 do_rtcp:1
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Media/sipSPICreateRtpSession: stun is disabled
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Error/sipSPIUpdateRtcpSession: Unable to update remote media ip address to,application, proceed further
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Media/sipSPIAddStream: AddStream in idle state to open a 'recvonly' media session
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/State/sipSPIChangeStreamState: Stream (callid = 27) State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Info/sipSPIUpdateSrcSdpFixedPart: RTP port already reserved for stream 1, src_port=16610
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Info/sipSPI_ipip_ReportPthruMediaToPeer:
CCSIP: Unable to send OPEN_CHANNEL_IND
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Info/sipSPI_ipip_UpdPthruCallWithSdpInfo:
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Info/sipSPIAddBillingInfoToCcb: sipCallId for billing records = 372c3b68582552781c93894f3331c819@74.63.41.218
.May 14 16:44:09.696: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCPA: No CPA found in inbound container
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Info/sipSPIProcessCPA: No x-cisco-cpa content found
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:2 tag:0
.May 14 16:44:09.696: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckHeaderSupport: Found Supported header Date
.May 14 16:44:09.696: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckHeaderSupport: Found Supported header Allow
.May 14 16:44:09.696: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckHeaderSupport: Found Supported header From
.May 14 16:44:09.696: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckHeaderSupport: Found Supported header Supported
.May 14 16:44:09.696: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckHeaderSupport: Found Supported header Remote-Party-ID
.May 14 16:44:09.696: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckHeaderSupport: Found Supported header Content-Length
.May 14 16:44:09.696: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckHeaderSupport: Found Supported header User-Agent
.May 14 16:44:09.696: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckHeaderSupport: Found Supported header To
.May 14 16:44:09.696: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckHeaderSupport: Found Supported header Contact
.May 14 16:44:09.696: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckHeaderSupport: Found Supported header Content-Type
.May 14 16:44:09.696: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckHeaderSupport: Found Supported header Call-ID
.May 14 16:44:09.696: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckHeaderSupport: Found Supported header Via
.May 14 16:44:09.696: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckHeaderSupport: Found Supported header CSeq
.May 14 16:44:09.696: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckHeaderSupport: Found Supported header Max-Forwards
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled: - 1
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Info/sipSPI_ipip_GetPassthruContent: Found Single Content in SIP Msg
.May 14 16:44:09.696: //-1/xxxxxxxxxxxx/SIP/Info/sipSPI_ipip_IsUnsupportedContentType: Content-Type application/sdp matched
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: No content in SIP Msg or Error
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Info/sipSPI_ipip_store_channel_info: Store channelInfo in CallInfo
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Info/sipSPI_ipip_CopySdpToContainer: initialInvite:TRUE
.May 14 16:44:09.696: //27/DCCBEED18050/SIP/Info/sipSPI_ipip_CopySdpToContainer: sdp being passed through;v=0
s=session
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
.May 14 16:44:09.700: //27/DCCBEED18050/SIP/Info/sipSPIShrlCall: Check peer: 1 for Shared-Line call, callid: 27
.May 14 16:44:09.700: //27/DCCBEED18050/SIP/Info/ccsip_set_bearer_capability:
Bearer Capability: Speech (0x00)
.May 14 16:44:09.700: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
.May 14 16:44:09.700: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
.May 14 16:44:09.700: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
.May 14 16:44:09.700: //27/DCCBEED18050/SIP/Info/sipSPIContinueNewMsgInvite: ccsip_api_call_setup_ind returned: SIP_SUCCESS
.May 14 16:44:09.700: //27/DCCBEED18050/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 1B to table
.May 14 16:44:09.700: //27/DCCBEED18050/SIP/Info/sipSPISendInviteResponse: Associated container=0x4934D824 to Invite Response 100
.May 14 16:44:09.700: //27/DCCBEED18050/SIP/Transport/sipSPITransportSendMessage: msg=0x4790D6B0, addr=74.63.41.218, port=5060, sentBy_port=5060, is_req=0, transport=1, switch=0, callBack=0x0
.May 14 16:44:09.700: //27/DCCBEED18050/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
.May 14 16:44:09.700: //27/DCCBEED18050/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
.May 14 16:44:09.700: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4790D6B0, addr=74.63.41.218, port=5060, connId=0 for UDP
.May 14 16:44:09.700: //27/DCCBEED18050/SIP/State/sipSPIChangeState: 0x4871BFB8 : State change from (STATE_IDLE, SUBSTATE_NONE) to (STATE_RECD_INVITE, SUBSTATE_NONE)
.May 14 16:44:09.700: //27/DCCBEED18050/SIP/Info/sipSPIProcessContactInfo: Previous Hop 74.63.41.218:5060
.May 14 16:44:09.704: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
.May 14 16:44:09.704: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler:
.May 14 16:44:09.704: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 164)
.May 14 16:44:09.704: //27/DCCBEED18050/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 28 chans 0x4B09B538 event 164 flags 0x40001C 0x100 0x601 data 0x4B09B538
ccsip_event_handler: CC_EV_H245_SET_MODE: peer ID 28 chans 0x4B09B538 event 164 flags 0x40001C 0x100 0x601 data 0x4B09B538, type = 1
.May 14 16:44:09.708: //27/DCCBEED18050/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
.May 14 16:44:09.708: //27/DCCBEED18050/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = xx.xxx.xx.xxx
.May 14 16:44:09.708: //27/DCCBEED18050/SIP/State/sipSPIChangeStreamState: Stream (callid = 27) State changed from (STREAM_ACTIVE) to (STREAM_ADDING)
.May 14 16:44:09.708: //27/DCCBEED18050/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-TDM
.May 14 16:44:09.708: //27/DCCBEED18050/SIP/Error/ccsip_event_handler: It is not supported to set SDPpassthrough for non SIP-SIP callsThe call will be disconnected
.May 14 16:44:09.708: //27/DCCBEED18050/SIP/Info/sipSPIUaddCcbToUASRespTable: ****Adding to UAS Response table.
.May 14 16:44:09.708: //27/DCCBEED18050/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4871BFB8 key=372c3b68582552781c93894f3331c819@74.63.41.21860F2428-2506
.May 14 16:44:09.708: //27/DCCBEED18050/SIP/Info/sipSPISendInviteResponse: Associated container=0x4934C95C to Invite Response 500
.May 14 16:44:09.708: //27/DCCBEED18050/SIP/Transport/sipSPITransportSendMessage: msg=0x476A8EAC, addr=74.63.41.218, port=5060, sentBy_port=5060, is_req=0, transport=1, switch=0, callBack=0x4185D118
.May 14 16:44:09.708: //27/DCCBEED18050/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
.May 14 16:44:09.708: //27/DCCBEED18050/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
.May 14 16:44:09.708: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x476A8EAC, addr=74.63.41.218, port=5060, connId=0 for UDP
.May 14 16:44:09.708: //27/DCCBEED18050/SIP/Info/sentErrResDisconnecting: Sent an 3456XX Error Response
.May 14 16:44:09.708: //27/DCCBEED18050/SIP/State/sipSPIChangeState: 0x4871BFB8 : State change from (STATE_RECD_INVITE, SUBSTATE_NONE) to (STATE_DISCONNECTING, SUBSTATE_NONE)
.May 14 16:44:09.708: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 3
.May 14 16:44:09.708: //27/DCCBEED18050/SIP/Info/act_ignore_event: Ignoring unexpected event 3 (SIPSPI_EV_CC_CALL_PROCEEDING) in state 9 (STATE_DISCONNECTING) substate 0 (SUBSTATE_NONE)
.May 14 16:44:09.716: //27/DCCBEED18050/SIP/Info/sip_gw_video_handle_alert: Video caps are not detected in the caps posted by peer leg
.May 14 16:44:09.716: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
.May 14 16:44:09.716: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
.May 14 16:44:09.716: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 5
.May 14 16:44:09.716: //27/DCCBEED18050/SIP/Error/sipSPIAddCiscoGcid: Fatal Error in parsing CCB/Msg
.May 14 16:44:09.716: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIStoreTunnelData: Container /RawMessage Absent
.May 14 16:44:09.716: //27/DCCBEED18050/SIP/Error/sipSPI_ipip_set_history_info_header: Not SIP2SIP mode
.May 14 16:44:09.716: //27/DCCBEED18050/SIP/Info/act_ignore_event: Ignoring unexpected event 5 (SIPSPI_EV_CC_CALL_ALERTING) in state 9 (STATE_DISCONNECTING) substate 0 (SUBSTATE_NONE)
.May 14 16:44:09.716: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 30
.May 14 16:44:09.716: //27/DCCBEED18050/SIP/Error/sipSPIPreProcessCallerIDMediaEvent: Don't expect a callerid update in STATE_DISCONNECTING
.May 14 16:44:09.716: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIPreProcessCallerIDMediaEvent: Updated Connected Party Name: Updated Connected Party Number: xxxxxxxx60 Updated Connected Party Oct3a: 0x00
.May 14 16:44:09.716: //27/DCCBEED18050/SIP/Info/sipSPIShrlGetInstanceInfo: Obtained the call instance 0 for non-shared-line '' with callid: 27
.May 14 16:44:09.716: //27/DCCBEED18050/SIP/Info/act_handle_app_media_event: method = 109 state = 9
.May 14 16:44:09.716: //27/DCCBEED18050/SIP/Info/act_handle_app_media_event: Received media sip event SIP_REQUEST_OFFER
.May 14 16:44:09.716: //27/DCCBEED18050/SIP/Info/sipSPICacheEvent: Clear UPDATE flags
.May 14 16:44:09.716: //27/DCCBEED18050/SIP/Error/sact_app_media_event_send_request: Cannot send UPDATE without calling ccsip_api_update_allowed
.May 14 16:44:09.720: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To:
Date: Mon, 14 May 2012 16:44:09 GMT
CSeq: 102 INVITE
Content-Length: 0
Sent:
To: ;tag=60F2428-2506
CSeq: 102 INVITE
Content-Length: 0
.May 14 16:44:09.724: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [74.63.41.218]:5060
.May 14 16:44:09.724: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
.May 14 16:44:09.724: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
.May 14 16:44:09.724: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:xxxxxxxx60@xx.xxx.xx.xxx:5060 SIP/2.0
Contact:
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
.May 14 16:44:09.724: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
.May 14 16:44:09.728: //27/DCCBEED18050/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4871BFB8
.May 14 16:44:09.728: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 74.63.41.218,Port 5060, Transport 1, SentBy Port 5060
.May 14 16:44:09.728: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone edt to SIP default timezone = GMT
.May 14 16:44:09.728: //27/DCCBEED18050/SIP/Info/sipSPISetInfoFromRpid: Received current remote name: xxxxxxxx26, current remote number: xxxxxxxx26
.May 14 16:44:09.728: //27/DCCBEED18050/SIP/Info/sipSPISetInfoFromRpid: Received ;screen=no ;privacy=off -> Setting Octet3A 0x80, extended_privacy 0x00
.May 14 16:44:09.728: //27/DCCBEED18050/SIP/Info/sipSPIIcpifUpdate: CallState: 2 Playout: 0 DiscTime:10165561 ConnTime 0
.May 14 16:44:09.728: //27/DCCBEED18050/SIP/Media/sipSPIDestroyRtpSession: stream:476A568C
.May 14 16:44:09.728: //27/DCCBEED18050/SIP/State/sipSPIChangeState: 0x4871BFB8 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE) to (STATE_DEAD, SUBSTATE_NONE)
.May 14 16:44:09.728: //27/DCCBEED18050/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x4871BFB8
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : xxxxxxxx26
Called Number : xxxxxxxx60
Source IP Address (Sig ): xx.xxx.xx.xxx
Destn SIP Req Addr:Port : 74.63.41.218:5060
Destn SIP Resp Addr:Port : 74.63.41.218:5060
Destination Name : 74.63.41.218
.May 14 16:44:09.728: //27/DCCBEED18050/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : Passthrough
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): xx.xxx.xx.xxx
Source IP Port (Media): 16610
Destn IP Address (Media): 74.63.41.218
Destn IP Port (Media): 11968
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC) : 0
Disconnect Cause (SIP) : 500
.May 14 16:44:09.728: //27/DCCBEED18050/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 1B
.May 14 16:44:09.728: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[9] removed.
.May 14 16:44:09.728: //27/DCCBEED18050/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
.May 14 16:44:09.728: //27/DCCBEED18050/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4871BFB8 key=372c3b68582552781c93894f3331c819@74.63.41.218xxxxxxxx60
.May 14 16:44:09.728: //27/DCCBEED18050/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
.May 14 16:44:09.728: //27/DCCBEED18050/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4871BFB8 key=372c3b68582552781c93894f3331c819@74.63.41.21860F2428-2506
.May 14 16:44:09.728: //27/DCCBEED18050/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
.May 14 16:44:09.728: //27/DCCBEED18050/SIP/Info/sipSPIStopRequestPendingTimer: Stopping Request Pending Timer
.May 14 16:44:09.728: //27/DCCBEED18050/SIP/Info/ccsip_qos_cleanup: Entry
.May 14 16:44:09.728: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISipSdpFree:
.May 14 16:44:09.728: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_FreeSipRawSdp: no sdp to free
.May 14 16:44:09.728: //-1/xxxxxxxxxxxx/SIP/Info/sipSPI_ipip_FreeSipRawSdp: sdp_ptr:0x48FA998C
.May 14 16:44:09.728: //27/DCCBEED18050/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
.May 14 16:44:09.728: //27/DCCBEED18050/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4871BFB8
.May 14 16:44:09.728: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[9]
.May 14 16:44:13.792: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_call_statistics: ccb NULL, or stats request pending.
.May 14 16:44:13.792: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
.May 14 16:44:13.792: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
.May 14 16:44:13.792: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_spi_process_ccapi_event: CCB not found for application event 8 withcallID: 27
05-15-2012 08:05 AM
please try following and test it again:
voice service voip
address-hiding
05-15-2012 09:03 AM
Thanks for the reply, same symptoms. Would you like me to post a debug and an updated config?
Best,
David
05-15-2012 11:31 AM
yes please do.
can you also do debug for outgoing connection which you said is fine, right?
05-15-2012 12:57 PM
05-16-2012 03:10 PM
Its diffcult to troubleshoot your issue, beacuse you have hidden your ip addresses. With SIP traces, the ips are important to kno where the call is sent to etc. I have notice that you are doing NAT. this is why its important to know what IP the call is sent to. You can send me a private message with the full traces. But let me know if you send it. NAT and SIP dont work well..so bear that in mind
05-16-2012 03:33 PM
PM sent with the logs, thanks aokanlawon.
The 2851 is doing NAT, but the voice is the only thing on the router, and the phones are the only devices behind the router.
05-16-2012 03:55 PM
David,
I see that the error occurs when the gateway attempts to look for the dialled number 51......
Looking at your config, no such number is matched? Where is this number?
