07-14-2015 12:58 AM - edited 03-17-2019 03:38 AM
Hi all,
I'm having an issue with a customer of ours when trying to dial an international number with 14 digits.
The cisco 79XX phone is cutting the number on 14 digits including the extra 0 for an outside line.
so when i press 0 00351214543989 and i do a debug voice dialpeer i only see 0 0035121454398
when is for example use a 9 for an outside line it works... like 9 00351214543989
why is the 0 an issue?
i tried different dialpeers like 0T as destination-pattern or just 0..............
thanks
Solved! Go to Solution.
07-14-2015 04:23 AM
You're matching another dial-peer. Can you post your config and or perform a "show dialplan number "number_that_you're_dialing"
Yosh
07-14-2015 04:23 AM
Yosh
07-16-2015 01:32 AM
Indeed... you're right... there where 2 dialpeers and it was matching a dialpeer with a shorter destination pattern...arggghh stupid.. thanks for you're reply.. :D
07-16-2015 06:25 AM
You're welcome! Glad you fixed the issue.
Yosh
