cme ip phones help
Mohammed Al-odhari
Enthusiast
Enthusiast
Ina company which uses cisco call manager express with ip phones 7931, 7945 ,7975, 7911,7962…….
1- i want the configuration in which the user dial a pin code befor doing an outside call...?
2- i want to change the defalt configuration for the ip phones of days backlight not active to thursday and friday and the backlight in duration to 1:30.?
i did the followings commands but it doesn`t take an effect.
Router(config)# telephony-service
Router(config-telephony)# service phone daysBacklightNotActive 6
Router(config-telephony)# service phone backlightOnDuration 1:30
Router(config-telephony)# service phone backlightIdleTimeout 01:00
Router(config-telephony)# create cnf-files
Router(config-telephony)# reset all
3- i have ringtones files in the flash (sh flash attached) , i want all the ringtones appear on all the ip phones when i press settings then user prefrences and then rings- i can only see two ring tones.
thanks for your help
1 REPLY 1
frlindse
Try
Router(config-telephony)#  service phone daysBacklightNotActive  5,6
Router(config-telephony)#  service phone backlightOnDuration 01:30
Also
What firmware version is on the phone?
What version of IOS/CME?
