CME ISR4331 sip phone 7800 with wrong timestamp display
dsobrinho
Level 9
Level 9
Hi team,
We have tac opened but without any solution yet.
CME ISR4331  IOS "bootflash:isr4300-universalk9.16.03.06.SPA.bin"
NTP Configured:  in voice register global ->  ntp-server 200.160.7.186 mode anycast,
Configured in the router as well
ntp logging
ntp server 200.160.7.186 prefer source GigabitEthernet0/0/0
ntp server 200.186.125.195
ntp server 200.199.205.149
Timezone set to 17  South America Standard/Daylight Time -186
IP Phone 3905 (show correct timestamp-> South America Standard/Daylight Time -186 min GMT/UTC) -  OKay
Problem description:
IP Phone 7821 (show incorrect timestamp ->Greenwich Standard Time - 0 min GMT/UTC)
IP Phone 7861 (show incorrect timestamp ->Greenwich Standard Time - 0 min GMT/UTC)
Firmware version: sip78xx.11-7-1-17.loads (Actual)
Firmware version: sip78xx.11-5-1-18.loads (same problem in this version)
Error description in the log of phone:
1905 ERR Aug 03 14:49:08.078437 (595:1615) JAVA-configmgr MQThread|cip.cfg.TimeDateProperty:? - Could not find timezone: South America Standard/Daylight Time
1906 NOT Aug 03 14:49:08.079932 (595:1615) JAVA-configmgr MQThread|cip.cfg.TimeDateProperty:? - setTimeZone tz:Greenwich Standard Time ctz:GMT
1907 NOT Aug 03 14:49:08.113810 (595:1615) JAVA-configmgr MQThread|cip.cfg.SipConfig:? - customerUUID is
1908 NOT Aug 03 14:49:08.118083 (595:1615) JAVA-configmgr MQThread|cip.cfg.SipConfig:? - userUUID is
Does anybody know something like that?
Daniel Sobrinho
2 Accepted Solutions
I am not talking about trying different time zones. Have you tested with Olson ? Did you review the CME admin guide for this ?
Hi @R0g22
Thank you for your feedback. 5 stars for you.
Following the resolution:
Download files:
The tzupdater can be downloaded here.    http://www.oracle.com/technetwork/java/javase/downloads/tzupdater-download-513681.html.
Details Instructions on how to configure the Olson timezone for SIP phones are @   http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmenetwk.html#pgfId-1066833
After uploaded the files to flash, need configured them in TFTP Server:
tftp-server flash:/iphone/CP3905.9-2-2-0.loads alias CP3905.9-2-2-0.loads
tftp-server flash:/iphone/APP3905.9-2-2-0.zz alias APP3905.9-2-2-0.zz
tftp-server flash:/iphone/sip78xx.10-1-1SR1-4.loads alias sip78xx.10-1-1SR1-4.loads
tftp-server flash:/iphone/kern78xx.10-1-1SR1-4.sbn alias kern78xx.10-1-1SR1-4.sbn
tftp-server flash:/iphone/rootfs78xx.10-1-1SR1-4.sbn alias rootfs78xx.10-1-1SR1-4.sbn
tftp-server flash:/iphone/sboot78xx.10-1-1SR1-4.sbn alias sboot78xx.10-1-1SR1-4.sbn
tftp-server flash:/its/music-on-hold.au alias music-on-hold.au
tftp-server flash:en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/iphone/kern2.78xx.11-5-1SR1-1.sbn alias kern2.78xx.11-5-1SR1-1.sbn
tftp-server flash:/iphone/kern78xx.11-5-1SR1-1.sbn alias kern78xx.11-5-1SR1-1.sbn
tftp-server flash:/iphone/rootfs2.78xx.11-5-1SR1-1.sbn alias rootfs2.78xx.11-5-1SR1-1.sbn
tftp-server flash:/iphone/rootfs78xx.11-5-1SR1-1.sbn alias rootfs78xx.11-5-1SR1-1.sbn
tftp-server flash:/iphone/sboot2.78xx.11-5-1SR1-1.sbn alias sboot2.78xx.11-5-1SR1-1.sbn
tftp-server flash:/iphone/sboot78xx.11-5-1SR1-1.sbn alias sboot78xx.11-5-1SR1-1.sbn
tftp-server flash:/iphone/sip78xx.11-5-1SR1-1.loads alias sip78xx.11-5-1SR1-1.loads
tftp-server flash:/iphone/APP3905.9-4-1SR2-2.zz alias APP3905.9-4-1SR2-2.zz
tftp-server flash:/iphone/CP3905.9-4-1SR2-2.loads alias CP3905.9-4-1SR2-2.loads
tftp-server flash:/iphone/kern2.78xx.11-7-1-17.sbn alias kern2.78xx.11-7-1-17.sbn
tftp-server flash:/iphone/kern78xx.11-7-1-17.sbn alias kern78xx.11-7-1-17.sbn
tftp-server flash:/iphone/rootfs2.78xx.11-7-1-17.sbn alias rootfs2.78xx.11-7-1-17.sbn
tftp-server flash:/iphone/rootfs78xx.11-7-1-17.sbn alias rootfs78xx.11-7-1-17.sbn
tftp-server flash:/iphone/sboot2.78xx.11-7-1-17.sbn alias sboot2.78xx.11-7-1-17.sbn
tftp-server flash:/iphone/sboot78xx.11-7-1-17.sbn alias sboot78xx.11-7-1-17.sbn
tftp-server flash:/iphone/sip78xx.11-7-1-17.loads alias sip78xx.11-7-1-17.loads
tftp-server flash:/iphone/tzupdater.jar alias tzupdater.jar
tftp-server flash:/iphone/TzDataCSV.CSV alias TzDataCSV.CSV
mode cme
source-address 192.168.X.Y port 5060
max-dn 60
max-pool 60
load 3905 CP3905.9-4-1SR2-2
load 7821 sip78xx.11-7-1-17
load 7861 sip78xx.11-7-1-17
authenticate register
authenticate realm acme.net
olsontimezone America/Sao_Paulo version 2015a
timezone 17
time-format 24
date-format D/M/Y
hold-alert
no dst auto-adjust
phone-mode phone-only
service https
tftp-path flash:
file text
create profile sync 0264625631487531
network-locale PT
network-locale 1 PT
user-locale U1 load CME-locale-pt_BR-Portuguese-11.5.11.5.tar
ip qos dscp af11 media
ip qos dscp cs2 signal
ip qos dscp af43 video
ip qos dscp 25 service
conference hardware
video
auto-register
Configuration here:
#config term
#voice register global
#olsontimezone <timezonename>  version 2015a
#no create profile
#create profile
#reset
Daniel Sobrinho
7 Replies 7
R0g22
Have you tried setting up Olson for these phones ? Review the CME admin guide for details.
Hi Nipun Sigh Raghav,
I have already tried to change to different timezone and it worked only for cisco ip phone 3905, but did not for 78xx phones. All IP Phone 3905 (show correct timestamp-> South America Standard/Daylight Time -180 min GMT/UTC).
The problem happens only in 78xx display timestamp. All other features in 78xx works fine, inbound/outbound, conference, transfer, hold etc.
Daniel Sobrinho
Ah just saw this reply that you've tried other timezones and they have not worked. Have you tried to change the ntp broadcast type?
As you mentioned I will do today the Olso timezone and keep you informed about the results.
About NTP anycast, I have change to broadcast, but without results after restart and reload services.
Daniel Sobrinho
Hi @R0g22
Download files:
mode cme
max-dn 60
max-pool 60
timezone 17
time-format 24
date-format D/M/Y
hold-alert
no dst auto-adjust
service https
tftp-path flash:
file text
network-locale PT
network-locale 1 PT
conference hardware
video
auto-register
Configuration here:
#config term
#no create profile
#create profile
#reset
Daniel Sobrinho
Sreekanth Narayanan
Daniel, have you tried to change the ntp mode to "directedBroadcast" instead of anycast?
Also, what if you change the timezone to a different value such as CET? Do the phones get the right time then?
