CME Issues with Pick up from SCCP - SIP
Hello Team,
I have 6921 SCCP IP phones and 8941 SIP IP Phones registered to a CME 8.6. Calls between the IP Phones are working fine. The issue is when a call gets to a SIP Phone from PSTN or Internal you are not able to pick up the call from any SCCP IP Phone.
Here is my config for the SIP Phones and one SCCP Phone:
voice register dn  1
number 1101
allow watch
pickup-call any-group
pickup-group 2
ephone-dn  10  dual-line
number 1100
pickup-group 2
All IP phones were associated to the same pick up group in order to avoid any issue. When anyone attempt to pick up the call you get a fast busy. Not even using the Gpickup Softkey, or PickUp softkey + Extension number ringing.
Not able to find any restriction on features and in the Admin Guide I found the following:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html#wp1092675
Any help would be appreciated it.
Daniel Alvarez
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
No, as discussed in other threads, that is not supported.
You can use a voice hunt-group to make so that calls go after perople instead of the other way around.
paolo bevilacqua
Hall of Fame Master
Recognize Your Peers
