CME Licence for 2921-k9
Kevin100
Hai
One of client have Cisco 2921-k9 and need to have cme licence for 50 phones with sip trunk
I am trying to find out part numbers , but only found  Cisco SL-29-UC-K9 in GPL
Can any one tell part numbers available to order now, cme , cube etc
Or SL-29-UC-K9 in GPL  is enough
Thank you
2 Accepted Solutions
Muhammad Awais Khan
Part numbers are still available for CUCME. Technically, with the license L-SL-29-UC-K9 you will be able to run CUCME and CUBE as these license are RTU only. It will not install it on the Router but since CUCME licenses are available, i will advice you to buy it as it will also help for any support issues.
Top level sku for CUCME license is "L-CME-CUE" . For CUBE, there is no sku applicable for 2900 now. There is only L-CUBE which is applicable for 4000 series.
I made the sample BOM for you which is attached.
@Kevin100 let me know if you have any doubts on it.
Please rate above response as helpful or accepted as solution if it answered your query. It will be helpful for others.
Muhammad Awais Khan
