CME Licensing
sylvain2006
Hi all
We have a CME with tradional license and 60 phones ares used(7940, 7960, 8840)
Now instaed of using cp8845 we had upgraded the version of CME to 10.5 and added 30 CME-UL.
but after 2 months, the systme shutdowns and i notice that the cme-ul didn't decrement.
So i want to know the compatibility of traditional license and smart???
CME license= tradionnal
CME-UL= smart
Vaijanath Sonvane
What ISR model you are using for CME?
Please note that, Cisco Unified CME supports Smart Licensing from Release 11.7 onwards and it is supported only on Cisco 4000 Series Integrated Services Router. After Release 11.7, you can not combine Traditional Licenses and Smart Licenses. You need to upgrade all your Traditional Licenses to Smart License and register with Smart Account.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmeover.html
Smart Licensing is not supported in CME version 10.5 and older ISR routers.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
sylvain2006
Hi all
Thanks for the solution
We used a ISR Cisco 4431
