Highlighted
Beginner
CME LPCOR Weird Behaviour
Hi Guys,
We have  setup a LPCOR on CME 9.1. And initial testing went successfully passed. Below is the work flows.
1. user press "9" to obtain the PSTN line and input the number that they want to reach.
2. CME prompt for user-code.
3. user input user-code (123).
4. CME prompt for pin-code.
5. user input pin-code (456).
6. supposingly the call will get thru and ring to external party, but however, the phone just disconnect the call immediately.
We confirm that all the user-code and user-pin we input are correct. Below is the snipplet.
application
package auth
  param max-digit 40
  param passwd-prompt flash:flash/LPCOR/pin.wav
  param max-retries 5
  param term-digit #
  param user-prompt flash:flash/LPCOR/password.wav
  param abort-digit *
  param passwd 12345
voice lpcor enable
voice lpcor custom
group 18 FAC
voice lpcor policy FAC
service fac
accept FAC fac
control-plane
voice-port 0/1/0:15
lpcor incoming FAC
lpcor outgoing FAC
ephone  886
lpcor type local
lpcor incoming FAC
device-security-mode none
mac-address 0011:2222:3333
type 7911
button  1:886
Any way to debug or check is what is the underlaying issues that causing this weird behaviour?
Everyone's tags (6)
6 REPLIES 6
Highlighted
Beginner
Below is the debug that we have. Is it due to "FAC data cannot be found from the call" ???
CME-3945-1#
Mar 26 04:42:55.086: //-1/xxxxxxxxxxxx/LPCOR/lpcor_get_index_by_name:
   lpcor FAC
   lpcor FAC index 10
CME-3945-1#
Mar 26 04:42:57.289: //2274//Dest:/DestPeerItemResetLPCORInfo:
Mar 26 04:42:57.289: //2274//Dest:/DestHandleLPCOR:
Mar 26 04:42:57.289: //-1/xxxxxxxxxxxx/LPCOR/lpcor_get_index_by_name:
   lpcor FAC
   lpcor FAC index 10
Mar 26 04:42:57.289: //2274//Dest:/DestProcessLPCOR: Peer 220 Source Callid 2274 CallType 0
Mar 26 04:42:57.289: //-1/xxxxxxxxxxxx/LPCOR/lpcor_index_is_valid:
   lpcor index 10 is valid
Mar 26 04:42:57.289: //-1/xxxxxxxxxxxx/LPCOR/lpcor_policy_validate_internal:
   Source LPCOR Index=10, Target LPCOR Policy=FAC
Mar 26 04:42:57.289: -Traceback= 190C8E0z 522C72Cz 522CECFz 4FCE9FAz 4FCE4D5z 4FC9FABz 4FD1941z 4FD2118z 4FD1389z 500A605z 4F9F4A5z 4FA4BB0z 4FA4E2Ez 500A605z 4FA5B46z 4FE9CCEz
   Validate Pass; lpcor (source[10] target[10])
Mar 26 04:42:57.289: //-1/xxxxxxxxxxxx/LPCOR/lpcor_policy_validate_get_service:
   FAC is enabled; lpcor (source[10] target[10])
Mar 26 04:42:57.289: //2274//Dest:/DestProcessLPCOR: lpcor source index(10) target index (10) ret_cause=0
Mar 26 04:42:57.289: //2274//Dest:/DestProcessLPCOR: Save return lpcor service_bits(0x1)
CME-3945-1#FAC Service is enabled on peerTag 220
Mar 26 04:42:57.289: //2274//Dest:/DestAuthInd:
Mar 26 04:42:57.289: //2274/75A89DC19300/AFW_:/AFW_Leg_GetFACData: FAC data cannot be found from the call
CME-3945-1#
Mar 26 04:43:04.331: //2274/75A89DC19300/AFW_:/AFW_Leg_GetFACData: FAC data cannot be found from the call
Highlighted
Beginner
Anyone please help on this?
Any good/bad comments are welcome...
Highlighted
Hall of Fame Master
You may need to contact the TAC on this. Or use another call-block mechanism.
Somebody finde solution?
Highlighted
Beginner
Hello, I have the same issue,
I have the same issue, Any ideas about this???
Aug 21 00:07:58.550: //21//Dest:/DestPeerItemResetLPCORInfo:
Aug 21 00:07:58.550: //21//Dest:/DestHandleLPCOR:
Aug 21 00:07:58.550: //21//Dest:/DestProcessLPCOR: Peer 2 Source Callid 21 CallType 0
Aug 21 00:07:58.550: //21//Dest:/DestProcessLPCOR: lpcor source index(10) target index (10) ret_cause=0
Aug 21 00:07:58.550: //21//Dest:/DestProcessLPCOR: Save return lpcor service_bits(0x1)
Aug 21 00:07:58.550: //21//Dest:/DestHandleLPCOR: FAC Service is enabled on peerTag 2
Aug 21 00:07:58.550: //21//Dest:/DestAuthInd:
Aug 21 00:07:58.554: //21/0A51252B8020/AFW_:/AFW_Leg_GetFACData: FAC data cannot be found from the call
Aug 21 00:08:05.294: //21/0A51252B8020/AFW_:/AFW_Leg_GetFACData: FAC data cannot be found from the call
CME1#
Thanks!
OG
Highlighted
Beginner
CME1#
Thanks!
OG
