07-18-2015 09:00 AM - edited 03-17-2019 03:41 AM
I have a cisco 2901 running CME. I have dial peers to reach outside, and one inside to reach my CUC server. I have a 9971 phone. Regardless of whether I dial my 4 digit voice mail pilot, or my 9+11 long distance number, it only shows the first digit on the phone. I have translation patterns, but none would match the voice mail pilot, so that cant be it. Can someone look at my config and see if you can spot the problem? Here is the relavent config. Thank you very much.
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface g0/0.11
bind media source-interface g0/0.11
registrar server expires max 250 min 200
no call service stop
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice register global
mode cme
source-address 10.0.3.1 port 5060
max-dn 10
max-pool 5
authenticate register
authenticate realm all
voicemail 4100
tftp-path flash:
create profile sync 0033715615390558
ntp-server 98.143.24.53 mode directedbroadcast
camera
video
voice register dn 1
number 1000
call-forward b2bua busy 4100
call-forward b2bua noan 4100 timeout 15
call-forward b2bua unregistered 4100
name John Huthmaker
label John Huthmaker
mwi
voice register pool 1
id mac 8875.5650.225C
type 9971
number 1 dn 1
dtmf-relay rtp-nte
username 1000 password 12345
description +15624730887
codec g711ulaw
voice translation-rule 1
rule 1 /189388/ /1000/
voice translation-rule 2
rule 1 /9562+/ /562/
voice translation-rule 4
rule 1 /91+/ /1/
voice translation-rule 5
rule 1 /9011+/ /011/
voice translation-rule 7
rule 1 /1000/ /15624730887/
voice translation-profile Caller-ID
translate calling 7
voice translation-profile INCOMING
translate called 1
voice translation-profile International
translate calling 7
translate called 5
voice translation-profile Local10
translate calling 7
translate called 2
voice translation-profile LongDistance
translate calling 7
translate called 4
dial-peer voice 10 voip
description Business1 11-Digit Outgoing
translation-profile incoming INCOMING
translation-profile outgoing LongDistance
destination-pattern 91..........
session protocol sipv2
session target ipv4:96.44.149.186
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 11 voip
translation-profile outgoing Local10
destination-pattern 9[^1]..[2-9]......
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 12 voip
translation-profile outgoing International
destination-pattern 9011T
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 13 voip
destination-pattern *97
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 4100 voip
description VoiceMail Pilot
max-conn 8
destination-pattern 4100$
session target ipv4:10.0.3.3
dtmf-relay rtp-nte
codec g711ulaw
no vad
07-18-2015 09:12 AM
I solved my own problem. And it wasnt in anything I listed above.
Under SIP-UA I had the command "no remote-party-id"
07-18-2015 11:38 PM
Hi Huth,
+5 for sharing the results back here.
02-03-2016 01:43 AM
thanks for sharing, one command solution, cool
