05-29-2012 05:53 AM - edited 03-16-2019 11:23 AM
We have two CME's. One has phones registered to it and the other has a PRI with backup POTS lines. Inbound calls from the PRI to the phones work fine. But when a phone on the CME tries to place a call across the PRI on the remote CME the call fails and ends up going out the backup POTS lines. If I register a phone to the CME that has the PRI then the outbound call across the PRI works. I will list a debug for a failed call. Any help is appreciated.
cc_api_call_setup_ind_common:
cisco-username=10.255.101.106
----- ccCallInfo IE subfields -----
cisco-ani=33136
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=9826087000
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
May 29 14:36:53.250 CAT: //-1/C6AD63E6B95F/CCAPI/cc_api_call_setup_ind_common:
Interface=0x490E7B00, Call Info(
Calling Number=33136,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=9826087000(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=T RUE,
Incoming Dial-peer=3005, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS E), Call Id=1110
May 29 14:36:53.250 CAT: //-1/C6AD63E6B95F/CCAPI/ccCheckClipClir:
In: Calling Number=33136(TON=Unknown, NPI=Unknown, Screening=Not Screened, Pr esentation=Allowed)
Out: Calling Number=33136(TON=Unknown, NPI=Unknown, Screening=Not Screened, P resentation=Allowed)
May 29 14:36:53.254 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 29 14:36:53.254 CAT: :cc_get_feature_vsa malloc success
May 29 14:36:53.254 CAT: cc_get_feature_vsa count is 1
May 29 14:36:53.254 CAT: :FEATURE_VSA attributes are: feature_name:0,feature_tim e:1282183512,feature_id:1115
May 29 14:36:53.254 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=33136(TON=Unknown, NPI=Unknown, Screening=Not Screen ed, Presentation=Allowed),
Called Number=9826087000(TON=Unknown, NPI=Unknown))
May 29 14:36:53.254 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
May 29 14:36:53.254 CAT: :Inside cc_build_feature_vsa
May 29 14:36:53.254 CAT: feature call basic
May 29 14:36:53.254 CAT: cc_build_feature_vsa attr is fn:TWC,ft:05/29/2012 14:36 :53.254,cgn:33136,cdn:9826087000,frs:0,fid:1115,fcid:C6AD63E6A8C111E1B95FC279C57 3494C,legID:456
May 29 14:36:53.258 CAT: //1110/C6AD63E6B95F/CCAPI/cc_process_call_setup_ind:
Event=0x49CE5578
May 29 14:36:53.258 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 9826087000
May 29 14:36:53.258 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallSetContext:
Context=0x4C5329F8
>>>>CCAPI handed cid 1110 with tag 3005 to app "_ManagedAppProcess_Default"
May 29 14:36:53.258 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
May 29 14:36:53.262 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=107, Params=0x4C53E898, Progress Indication=ORIGINATING SI DE IS NON ISDN(3)
May 29 14:36:53.262 CAT: //1110/C6AD63E6B95F/CCAPI/ccCheckClipClir:
In: Calling Number=27225100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=27225100(TON=Unknown, NPI=Unknown, Screening=Not Screened , Presentation=Allowed)
Destination Pattern=9T, Called Number=9826087000, Digit Strip=TRUE
Calling Number=27225100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Pre sentation=Allowed),
Redirect Number=, Display Info=Nugier, Billy
Account Number=10.255.101.106, Final Destination Flag=TRUE,
Guid=C6AD63E6-A8C1-11E1-B95F-C279C573494C, Outgoing Dial-peer=107
May 29 14:36:53.262 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=27225100
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=9826087000
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
May 29 14:36:53.262 CAT: //1110/C6AD63E6B95F/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x4A5C8644, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=27225100,(Calling Name=Nugier, Billy)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=9826087000(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=10 7, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Appl ication Call Id=)
May 29 14:36:53.262 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 29 14:36:53.262 CAT: :cc_get_feature_vsa malloc success
May 29 14:36:53.262 CAT: cc_get_feature_vsa count is 2
May 29 14:36:53.262 CAT: :FEATURE_VSA attributes are: feature_name:0,feature_tim e:1282183288,feature_id:1116
May 29 14:36:53.262 CAT: //1111/C6AD63E6B95F/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
May 29 14:36:53.262 CAT: //1111/C6AD63E6B95F/CCAPI/ccCallSetContext:
Context=0x4C53E848
May 29 14:36:53.262 CAT: //1110/C6AD63E6B95F/CCAPI/ccSaveDialpeerTag:
May 29 14:36:53.266 CAT: ISDN Se0/1/1:15 Q931: Applying typeplan for sw-type 0x1 2 is 0x0 0x0, Calling num 27225100
May 29 14:36:53.270 CAT: ISDN Se0/1/1:15 Q931: Sending SETUP callref = 0x0127 c allID = 0x80A8 switch = primary-net5 interface = User
May 29 14:36:53.270 CAT: ISDN Se0/1/1:15 Q931: TX -> SETUP pd = 8 callref = 0x0 127
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x80, '27225100'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '826087000'
May 29 14:36:53.426 CAT: ISDN Se0/1/1:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8127
May 29 14:36:53.430 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
May 29 14:36:53.430 CAT: :Inside cc_build_feature_vsa
May 29 14:36:53.430 CAT: feature call basic
May 29 14:36:53.430 CAT: cc_build_feature_vsa attr is fn:TWC,ft:05/29/2012 14:36 :53.262,cgn:27225100,cdn:9826087000,frs:0,fid:1116,fcid:C6AD63E6A8C111E1B95FC279 C573494C,legID:457
May 29 14:36:53.430 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_call_proceeding:
Interface=0x4A5C8644, Progress Indication=NULL(0)
May 29 14:36:53.706 CAT: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x8127
Cause i = 0x829F - Normal, unspecified
Progress Ind i = 0x8288 - In-band info or appropriate now available
May 29 14:36:53.706 CAT: ISDN Se0/1/1:15 Q931: call_disc: PI received in disconn ect; Postpone sending RELEASE for callid 0x80A8
May 29 14:36:53.706 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_call_disc_prog_ind:
Cause Value=31, Progress Indication=INBAND(8), Interface=0x4A5C8644
May 29 14:36:53.710 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_call_disc_prog_ind:
Event(Progress Indication=0x0), Call Entry(Responsed=TRUE)
May 29 14:36:53.710 CAT: //1110/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
May 29 14:36:53.710 CAT: //1111/C6AD63E6B95F/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=1111
May 29 14:36:53.710 CAT: //1111/C6AD63E6B95F/CCAPI/ccCallDisconnect:
Cause Value=31, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C ause=31)
Cause Value=31, Call Entry(Responsed=TRUE, Cause Value=31)
May 29 14:36:53.710 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
May 29 14:36:53.710 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_call_disc_cause_update :
Cause Value=31
Call Entry(Disconnect Cause=31)
May 29 14:36:53.714 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x4A5C8644, Tag=0x0, Call Id=1111,
Call Entry(Disconnect Cause=31, Voice Class Cause Code=0, Retry Count=0)
May 29 14:36:53.718 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
May 29 14:36:53.718 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 29 14:36:53.718 CAT: :cc_free_feature_vsa freeing 4C6C9070
May 29 14:36:53.718 CAT: vsacount in free is 1
May 29 14:36:53.718 CAT: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8 callref = 0 x0127
May 29 14:36:53.722 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=108, Params=0x4C536360, Progress Indication=ORIGINATING SI DE IS NON ISDN(3)
May 29 14:36:53.722 CAT: //1110/C6AD63E6B95F/CCAPI/cc_fill_tg_params:
Not a cic call
Trunk Group Select Interface Success;
Interface=0x49D2F938, Selected Interface=1, Selected DSL=-1
May 29 14:36:53.722 CAT: //1110/C6AD63E6B95F/CCAPI/ccCheckClipClir:
Calling Number=33136(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presen tation=Allowed),
Guid=C6AD63E6-A8C1-11E1-B95F-C279C573494C, Outgoing Dial-peer=108
May 29 14:36:53.722 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=33136
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=9826087000
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
May 29 14:36:53.722 CAT: //1110/C6AD63E6B95F/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x49D2F938, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=33136,(Calling Name=Nugier, Billy)(TON=Unknown, NP I=Unknown, Screening=Not Screened, Presentation=Allowed),
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=10 8, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=FXO, tg_label_flag=2, A pplication Call Id=)
May 29 14:36:53.722 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 29 14:36:53.722 CAT: :cc_get_feature_vsa malloc success
May 29 14:36:53.722 CAT: cc_get_feature_vsa count is 2
May 29 14:36:53.722 CAT: :FEATURE_VSA attributes are: feature_name:0,feature_tim e:1282183288,feature_id:1117
May 29 14:36:53.726 CAT: //1112/C6AD63E6B95F/CCAPI/ccIFCallSetupRequestPrivate:
May 29 14:36:53.726 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallSetupRequest:
Trunk Group Call Setting;
Call Entry(Retry Count=0, Voice Class Cause Code=0)
May 29 14:36:53.726 CAT: //1112/C6AD63E6B95F/CCAPI/ccCallSetContext:
Context=0x4C536310
May 29 14:36:53.726 CAT: //1110/C6AD63E6B95F/CCAPI/ccSaveDialpeerTag:
May 29 14:36:53.726 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_modify_tgt_cid_call_ac tive_record:
Target Trkgrp Route Label=FXO, tg_label_flag=TRUE, Call Id=0x456
May 29 14:36:53.730 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
May 29 14:36:53.730 CAT: :Inside cc_build_feature_vsa
May 29 14:36:53.730 CAT: feature call basic
May 29 14:36:53.730 CAT: cc_build_feature_vsa attr is fn:TWC,ft:05/29/2012 14:36 :53.722,cgn:33136,cdn:9826087000,frs:0,fid:1117,fcid:C6AD63E6A8C111E1B95FC279C57 3494C,legID:458
May 29 14:36:53.730 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_call_proceeding:
Interface=0x49D2F938, Progress Indication=NULL(0)
May 29 14:36:53.746 CAT: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8 callre f = 0x8127
May 29 14:36:57.166 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_call_cut_progress:
Interface=0x49D2F938, Progress Indication=INBAND(8), Signal Indication=INTERC EPT(2),
Cause Value=0
May 29 14:36:57.166 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallCutProgress:
Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
May 29 14:36:57.166 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_get_called_ccm_detecte d:
CallInfo(ccm detected=0)
May 29 14:36:57.166 CAT: //1110/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4C6304FC, callID1=0x456, callID2=0x458, tag=0x0)
(confID=0x4C6304FC, callID1=0x456, gcid=0-0-0-0, tag=0x0)
May 29 14:36:57.166 CAT: //1112/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x4C6304FC, callID2=0x458, gcid=0-0-0-0, tag=0x0)
May 29 14:36:57.166 CAT: //1110/C6AD63E6B95F/CCAPI/ccConferenceCreate:
Conference Id=0x4C6304FC, Call Id1=1110, Call Id2=1112, Tag=0x0
May 29 14:36:57.166 CAT: //1110/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
May 29 14:36:57.166 CAT: cc_api_get_xcode_stream : 4534
May 29 14:36:57.166 CAT: //1110/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0xDE, Source Interface=0x490E7B00, Source Call Id=1110,
Destination Call Id=1112, Disposition=0x0, Tag=0x0
May 29 14:36:57.170 CAT: //1112/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0xDE, Source Interface=0x49D2F938, Source Call Id=1112,
Destination Call Id=1110, Disposition=0x0, Tag=0xFFFFFFFF
May 29 14:36:57.170 CAT: //1110/C6AD63E6B95F/CCAPI/cc_generic_bridge_done:
May 29 14:36:57.170 CAT: //1110/C6AD63E6B95F/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0xDE, Destination Call Id=1112)
May 29 14:36:57.170 CAT: //1112/C6AD63E6B95F/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0xDE, Destination Call Id=1110)
May 29 14:36:57.170 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_caps_ind:
Destination Interface=0x490E7B00, Destination Call Id=1110, Source Call Id=11 12,
Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
May 29 14:36:57.170 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_caps_ind:
Destination Interface=0x49D2F938, Destination Call Id=1112, Source Call Id=11 10,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Modem=0x0, Codec Bytes=160, Signal Type=2)
May 29 14:36:57.170 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=9610)
May 29 14:36:57.170 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_caps_ack:
May 29 14:36:57.174 CAT: //1110/C6AD63E6B95F/CCAPI/cc_process_notify_bridge_done :
Conference Id=0xDE, Call Id1=1110, Call Id2=1112
May 29 14:36:57.174 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_voice_mode_event:
Call Id=1112
Call Entry(Context=0x4C536310)
May 29 14:36:57.174 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_call_connected:
Interface=0x49D2F938, Data Bitmask=0x1, Progress Indication=DESTINATION IS NO N ISDN(2),
Connection Handle=0
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
May 29 14:36:57.178 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=1110
May 29 14:36:57.178 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_get_called_ccm_detecte d:
May 29 14:36:57.178 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallConnect:
Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
May 29 14:36:57.182 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_get_called_ccm_detecte d:
May 29 14:36:57.182 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallConnect:
Call Entry(Connected=TRUE, Responsed=TRUE)
May 29 14:36:57.182 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallNotify:
May 29 14:36:58.498 CAT: %RADIUS-4-RADIUS_DEAD: RADIUS server 10.50.18.123:1645, 1813 is not responding.
May 29 14:36:58.498 CAT: %RADIUS-4-RADIUS_ALIVE: RADIUS server 10.50.18.123:1645 ,1813 is being marked alive.
May 29 14:37:01.838 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x490E7B00, Call Id=1110
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
May 29 14:37:01.838 CAT: //1110/C6AD63E6B95F/CCAPI/ccConferenceDestroy:
Conference Id=0xDE, Tag=0x0
May 29 14:37:01.838 CAT: //1110/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
May 29 14:37:01.838 CAT: //1112/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=1110, Disposition=0x0, Tag=0x0
May 29 14:37:01.838 CAT: //1110/C6AD63E6B95F/CCAPI/cc_generic_bridge_done:
May 29 14:37:01.842 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C ause=16)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
May 29 14:37:01.842 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_get_transfer_info:
May 29 14:37:01.842 CAT: //1112/C6AD63E6B95F/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C ause=0)
May 29 14:37:01.842 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_get_transfer_info:
May 29 14:37:01.846 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_get_transfer_info:
May 29 14:37:01.850 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x490E7B00, Tag=0x0, Call Id=1110,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
May 29 14:37:01.850 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 29 14:37:01.850 CAT: :cc_free_feature_vsa freeing 4C6C9150
May 29 14:37:01.850 CAT: vsacount in free is 1
May 29 14:37:01.862 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x49D2F938, Tag=0x0, Call Id=1112,
tg for this call is FXO success/fail is 1
May 29 14:37:01.862 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 29 14:37:01.862 CAT: :cc_free_feature_vsa freeing 4C6C9070
May 29 14:37:01.862 CAT: vsacount in free is 0un all
All possible debugging has been turned off
PEMrt1#
Solved! Go to Solution.
05-29-2012 06:22 AM
05-29-2012 05:58 AM
Here are the cme dial-peer configs
CME (PEMrt4) with Phones
dial-peer voice 208 voip
description "Dial Peer for PRI Access"
preference 1
destination-pattern T
session target ipv4:10.101.85.1
voice-class codec 1
CME (PEMrt1) with PRI
dial-peer voice 3005 voip
description Dial-Peer to PEMrt4
destination-pattern 331[0-4].
session target ipv4:10.255.101.106
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 3006 voip
destination-pattern 332..
codec g711ulaw
dial-peer voice 107 pots
translation-profile outgoing TranslateOutgoingMain
preference 1
destination-pattern 9T
port 0/1/1:15
dial-peer voice 101 pots
translation-profile incoming TranslateIncoming
incoming called-number .
direct-inward-dial
05-29-2012 06:04 AM
The call is matching dial-peer 10 and 107 on router 1...What is in thos dial-peers?
05-29-2012 06:07 AM
I don’t have a dial-peer 10 configured. Here are all the dial-peers I have configured at this time on that router.
dial-peer voice 3000 voip
description Dial-Peer to Maputo
destination-pattern 331[5-9].
session target ipv4:10.101.254.1
direct-inward-dial
dial-peer voice 208 pots
preference 1
destination-pattern 8T
port 0/1/1:15
preference 1
port 0/1/1:15
dial-peer voice 999030 pots
destination-pattern 33199
port 0/3/0
codec g711ulaw
codec g711ulaw
dial-peer voice 108 pots
trunkgroup FXO
preference 2
dial-peer voice 207 pots
trunkgroup FXO
description "FXO Backup Dial-Peer for PSTN Access"
preference 2
05-29-2012 06:11 AM
Oh, that is not dial-peer 10, that is a space in the copy and paste I did. It is 107.
05-29-2012 06:00 AM
Can you send a sh run of both routers? Which router did you take this log from?
05-29-2012 06:03 AM
I took the debug from the CME with the PRI. I will send you a message with the sh run of each router.
05-29-2012 06:15 AM
Ok,
Billy this is what is going on..
The call goes out first through dial-peer 107 which is your PRI port, it goes to the PSTN and the telco disconnects the call
Then it comes back and tries the second dial-peer 108 and it connects..
So you need to talk to your provider and find out why they are disconeecting the call
05-29-2012 06:16 AM
Ok, thanks.
05-29-2012 06:22 AM
Pls rate all useful posts!
05-29-2012 06:23 AM
Ok, when this issue is resolved I will. Thanks.
