CME Phones out bound calling fails to remote CME PRI
BILLY NUGIER
We have two CME's.  One has phones registered to it and the other has a PRI with backup POTS lines.  Inbound calls from the PRI to the phones work fine.  But when a phone on the CME tries to place a call across the PRI on the remote CME the call fails and ends up going out the backup POTS lines.  If I register a phone to the CME that has the PRI then the outbound call across the PRI works.  I will list a debug for a failed call.  Any help is appreciated.
   cc_api_call_setup_ind_common:
   cisco-username=10.255.101.106
   ----- ccCallInfo IE subfields -----
   cisco-ani=33136
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=9826087000
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
May 29 14:36:53.250 CAT: //-1/C6AD63E6B95F/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x490E7B00, Call Info(
   Calling Number=33136,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not       Screened, Presentation=Allowed),
   Called Number=9826087000(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=T      RUE,
   Incoming Dial-peer=3005, Progress Indication=ORIGINATING SIDE IS NON ISDN(3),       Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS      E), Call Id=1110
May 29 14:36:53.250 CAT: //-1/C6AD63E6B95F/CCAPI/ccCheckClipClir:
   In: Calling Number=33136(TON=Unknown, NPI=Unknown, Screening=Not Screened, Pr      esentation=Allowed)
   Out: Calling Number=33136(TON=Unknown, NPI=Unknown, Screening=Not Screened, P      resentation=Allowed)
May 29 14:36:53.254 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 29 14:36:53.254 CAT: :cc_get_feature_vsa malloc success
May 29 14:36:53.254 CAT:  cc_get_feature_vsa count is 1
May 29 14:36:53.254 CAT: :FEATURE_VSA attributes are: feature_name:0,feature_tim      e:1282183512,feature_id:1115
May 29 14:36:53.254 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=33136(TON=Unknown, NPI=Unknown, Screening=Not Screen      ed, Presentation=Allowed),
   Called Number=9826087000(TON=Unknown, NPI=Unknown))
May 29 14:36:53.254 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
May 29 14:36:53.254 CAT: :Inside cc_build_feature_vsa
May 29 14:36:53.254 CAT:  feature call basic
May 29 14:36:53.254 CAT: cc_build_feature_vsa attr is fn:TWC,ft:05/29/2012 14:36      :53.254,cgn:33136,cdn:9826087000,frs:0,fid:1115,fcid:C6AD63E6A8C111E1B95FC279C57      3494C,legID:456
May 29 14:36:53.258 CAT: //1110/C6AD63E6B95F/CCAPI/cc_process_call_setup_ind:
   Event=0x49CE5578
May 29 14:36:53.258 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 9826087000
May 29 14:36:53.258 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallSetContext:
   Context=0x4C5329F8
   >>>>CCAPI handed cid 1110 with tag 3005 to app "_ManagedAppProcess_Default"
May 29 14:36:53.258 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
May 29 14:36:53.262 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=107, Params=0x4C53E898, Progress Indication=ORIGINATING SI      DE IS NON ISDN(3)
May 29 14:36:53.262 CAT: //1110/C6AD63E6B95F/CCAPI/ccCheckClipClir:
   In: Calling Number=27225100(TON=Unknown, NPI=Unknown, Screening=Not Screened,       Presentation=Allowed)
   Out: Calling Number=27225100(TON=Unknown, NPI=Unknown, Screening=Not Screened      , Presentation=Allowed)
   Destination Pattern=9T, Called Number=9826087000, Digit Strip=TRUE
   Calling Number=27225100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Pre      sentation=Allowed),
   Redirect Number=, Display Info=Nugier, Billy
   Account Number=10.255.101.106, Final Destination Flag=TRUE,
   Guid=C6AD63E6-A8C1-11E1-B95F-C279C573494C, Outgoing Dial-peer=107
May 29 14:36:53.262 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=27225100
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=9826087000
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
May 29 14:36:53.262 CAT: //1110/C6AD63E6B95F/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4A5C8644, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=27225100,(Calling Name=Nugier, Billy)(TON=Unknown,       NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=9826087000(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=10      7, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Appl      ication Call Id=)
May 29 14:36:53.262 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 29 14:36:53.262 CAT: :cc_get_feature_vsa malloc success
May 29 14:36:53.262 CAT:  cc_get_feature_vsa count is 2
May 29 14:36:53.262 CAT: :FEATURE_VSA attributes are: feature_name:0,feature_tim      e:1282183288,feature_id:1116
May 29 14:36:53.262 CAT: //1111/C6AD63E6B95F/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
May 29 14:36:53.262 CAT: //1111/C6AD63E6B95F/CCAPI/ccCallSetContext:
   Context=0x4C53E848
May 29 14:36:53.262 CAT: //1110/C6AD63E6B95F/CCAPI/ccSaveDialpeerTag:
May 29 14:36:53.266 CAT: ISDN Se0/1/1:15 Q931: Applying typeplan for sw-type 0x1      2 is 0x0 0x0, Calling num 27225100
May 29 14:36:53.270 CAT: ISDN Se0/1/1:15 Q931: Sending SETUP  callref = 0x0127 c      allID = 0x80A8 switch = primary-net5 interface = User
May 29 14:36:53.270 CAT: ISDN Se0/1/1:15 Q931: TX -> SETUP pd = 8  callref = 0x0      127
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x80, '27225100'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '826087000'
May 29 14:36:53.426 CAT: ISDN Se0/1/1:15 Q931: RX <- CALL_PROC pd = 8  callref =       0x8127
May 29 14:36:53.430 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
May 29 14:36:53.430 CAT: :Inside cc_build_feature_vsa
May 29 14:36:53.430 CAT:  feature call basic
May 29 14:36:53.430 CAT: cc_build_feature_vsa attr is fn:TWC,ft:05/29/2012 14:36      :53.262,cgn:27225100,cdn:9826087000,frs:0,fid:1116,fcid:C6AD63E6A8C111E1B95FC279      C573494C,legID:457
May 29 14:36:53.430 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_call_proceeding:
   Interface=0x4A5C8644, Progress Indication=NULL(0)
May 29 14:36:53.706 CAT: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8  callref       = 0x8127
        Cause i = 0x829F - Normal, unspecified
        Progress Ind i = 0x8288 - In-band info or appropriate now available
May 29 14:36:53.706 CAT: ISDN Se0/1/1:15 Q931: call_disc: PI received in disconn      ect; Postpone sending RELEASE for callid 0x80A8
May 29 14:36:53.706 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_call_disc_prog_ind:
   Cause Value=31, Progress Indication=INBAND(8), Interface=0x4A5C8644
May 29 14:36:53.710 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_call_disc_prog_ind:
   Event(Progress Indication=0x0), Call Entry(Responsed=TRUE)
May 29 14:36:53.710 CAT: //1110/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
May 29 14:36:53.710 CAT: //1111/C6AD63E6B95F/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=1111
May 29 14:36:53.710 CAT: //1111/C6AD63E6B95F/CCAPI/ccCallDisconnect:
   Cause Value=31, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C      ause=31)
   Cause Value=31, Call Entry(Responsed=TRUE, Cause Value=31)
May 29 14:36:53.710 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
May 29 14:36:53.710 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_call_disc_cause_update      :
   Cause Value=31
   Call Entry(Disconnect Cause=31)
May 29 14:36:53.714 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4A5C8644, Tag=0x0, Call Id=1111,
   Call Entry(Disconnect Cause=31, Voice Class Cause Code=0, Retry Count=0)
May 29 14:36:53.718 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
May 29 14:36:53.718 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 29 14:36:53.718 CAT: :cc_free_feature_vsa freeing 4C6C9070
May 29 14:36:53.718 CAT:  vsacount in free is 1
May 29 14:36:53.718 CAT: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8  callref = 0      x0127
May 29 14:36:53.722 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=108, Params=0x4C536360, Progress Indication=ORIGINATING SI      DE IS NON ISDN(3)
May 29 14:36:53.722 CAT: //1110/C6AD63E6B95F/CCAPI/cc_fill_tg_params:
   Not a cic call
   Trunk Group Select Interface Success;
   Interface=0x49D2F938, Selected Interface=1, Selected DSL=-1
May 29 14:36:53.722 CAT: //1110/C6AD63E6B95F/CCAPI/ccCheckClipClir:
   Calling Number=33136(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presen      tation=Allowed),
   Guid=C6AD63E6-A8C1-11E1-B95F-C279C573494C, Outgoing Dial-peer=108
May 29 14:36:53.722 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=33136
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=9826087000
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
May 29 14:36:53.722 CAT: //1110/C6AD63E6B95F/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x49D2F938, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=33136,(Calling Name=Nugier, Billy)(TON=Unknown, NP      I=Unknown, Screening=Not Screened, Presentation=Allowed),
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=10      8, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=FXO, tg_label_flag=2, A      pplication Call Id=)
May 29 14:36:53.722 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 29 14:36:53.722 CAT: :cc_get_feature_vsa malloc success
May 29 14:36:53.722 CAT:  cc_get_feature_vsa count is 2
May 29 14:36:53.722 CAT: :FEATURE_VSA attributes are: feature_name:0,feature_tim      e:1282183288,feature_id:1117
May 29 14:36:53.726 CAT: //1112/C6AD63E6B95F/CCAPI/ccIFCallSetupRequestPrivate:
May 29 14:36:53.726 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallSetupRequest:
   Trunk Group Call Setting;
   Call Entry(Retry Count=0, Voice Class Cause Code=0)
May 29 14:36:53.726 CAT: //1112/C6AD63E6B95F/CCAPI/ccCallSetContext:
   Context=0x4C536310
May 29 14:36:53.726 CAT: //1110/C6AD63E6B95F/CCAPI/ccSaveDialpeerTag:
May 29 14:36:53.726 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_modify_tgt_cid_call_ac      tive_record:
   Target Trkgrp Route Label=FXO, tg_label_flag=TRUE, Call Id=0x456
May 29 14:36:53.730 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
May 29 14:36:53.730 CAT: :Inside cc_build_feature_vsa
May 29 14:36:53.730 CAT:  feature call basic
May 29 14:36:53.730 CAT: cc_build_feature_vsa attr is fn:TWC,ft:05/29/2012 14:36      :53.722,cgn:33136,cdn:9826087000,frs:0,fid:1117,fcid:C6AD63E6A8C111E1B95FC279C57      3494C,legID:458
May 29 14:36:53.730 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_call_proceeding:
   Interface=0x49D2F938, Progress Indication=NULL(0)
May 29 14:36:53.746 CAT: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8  callre      f = 0x8127
May 29 14:36:57.166 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_call_cut_progress:
   Interface=0x49D2F938, Progress Indication=INBAND(8), Signal Indication=INTERC      EPT(2),
   Cause Value=0
May 29 14:36:57.166 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
May 29 14:36:57.166 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_get_called_ccm_detecte      d:
   CallInfo(ccm detected=0)
May 29 14:36:57.166 CAT: //1110/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x4C6304FC, callID1=0x456, callID2=0x458, tag=0x0)
   (confID=0x4C6304FC, callID1=0x456, gcid=0-0-0-0, tag=0x0)
May 29 14:36:57.166 CAT: //1112/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x4C6304FC, callID2=0x458, gcid=0-0-0-0, tag=0x0)
May 29 14:36:57.166 CAT: //1110/C6AD63E6B95F/CCAPI/ccConferenceCreate:
   Conference Id=0x4C6304FC, Call Id1=1110, Call Id2=1112, Tag=0x0
May 29 14:36:57.166 CAT: //1110/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
May 29 14:36:57.166 CAT: cc_api_get_xcode_stream : 4534
May 29 14:36:57.166 CAT: //1110/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0xDE, Source Interface=0x490E7B00, Source Call Id=1110,
   Destination Call Id=1112, Disposition=0x0, Tag=0x0
May 29 14:36:57.170 CAT: //1112/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0xDE, Source Interface=0x49D2F938, Source Call Id=1112,
   Destination Call Id=1110, Disposition=0x0, Tag=0xFFFFFFFF
May 29 14:36:57.170 CAT: //1110/C6AD63E6B95F/CCAPI/cc_generic_bridge_done:
May 29 14:36:57.170 CAT: //1110/C6AD63E6B95F/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xDE, Destination Call Id=1112)
May 29 14:36:57.170 CAT: //1112/C6AD63E6B95F/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xDE, Destination Call Id=1110)
May 29 14:36:57.170 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_caps_ind:
   Destination Interface=0x490E7B00, Destination Call Id=1110, Source Call Id=11      12,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
May 29 14:36:57.170 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_caps_ind:
   Destination Interface=0x49D2F938, Destination Call Id=1112, Source Call Id=11      10,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
May 29 14:36:57.170 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=9610)
May 29 14:36:57.170 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_caps_ack:
May 29 14:36:57.174 CAT: //1110/C6AD63E6B95F/CCAPI/cc_process_notify_bridge_done      :
   Conference Id=0xDE, Call Id1=1110, Call Id2=1112
May 29 14:36:57.174 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_voice_mode_event:
   Call Id=1112
   Call Entry(Context=0x4C536310)
May 29 14:36:57.174 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_call_connected:
   Interface=0x49D2F938, Data Bitmask=0x1, Progress Indication=DESTINATION IS NO      N ISDN(2),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
May 29 14:36:57.178 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=1110
May 29 14:36:57.178 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_get_called_ccm_detecte      d:
May 29 14:36:57.178 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallConnect:
   Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
May 29 14:36:57.182 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_get_called_ccm_detecte      d:
May 29 14:36:57.182 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallConnect:
   Call Entry(Connected=TRUE, Responsed=TRUE)
May 29 14:36:57.182 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallNotify:
May 29 14:36:58.498 CAT: %RADIUS-4-RADIUS_DEAD: RADIUS server 10.50.18.123:1645,      1813 is not responding.
May 29 14:36:58.498 CAT: %RADIUS-4-RADIUS_ALIVE: RADIUS server 10.50.18.123:1645      ,1813 is being marked alive.
May 29 14:37:01.838 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x490E7B00, Call Id=1110
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
May 29 14:37:01.838 CAT: //1110/C6AD63E6B95F/CCAPI/ccConferenceDestroy:
   Conference Id=0xDE, Tag=0x0
May 29 14:37:01.838 CAT: //1110/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
May 29 14:37:01.838 CAT: //1112/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=1110, Disposition=0x0, Tag=0x0
May 29 14:37:01.838 CAT: //1110/C6AD63E6B95F/CCAPI/cc_generic_bridge_done:
May 29 14:37:01.842 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C      ause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
May 29 14:37:01.842 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_get_transfer_info:
May 29 14:37:01.842 CAT: //1112/C6AD63E6B95F/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C      ause=0)
May 29 14:37:01.842 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_get_transfer_info:
May 29 14:37:01.846 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_get_transfer_info:
May 29 14:37:01.850 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x490E7B00, Tag=0x0, Call Id=1110,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
May 29 14:37:01.850 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 29 14:37:01.850 CAT: :cc_free_feature_vsa freeing 4C6C9150
May 29 14:37:01.850 CAT:  vsacount in free is 1
May 29 14:37:01.862 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49D2F938, Tag=0x0, Call Id=1112,
   tg for this call is FXO success/fail is 1
May 29 14:37:01.862 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 29 14:37:01.862 CAT: :cc_free_feature_vsa freeing 4C6C9070
May 29 14:37:01.862 CAT:  vsacount in free is 0un all
All possible debugging has been turned off
PEMrt1#
Pls rate all useful posts!
Please rate all useful posts
10 Replies 10
BILLY NUGIER
Here are the cme dial-peer configs
CME (PEMrt4) with Phones
dial-peer voice 208 voip
description "Dial Peer for PRI Access"
preference 1
destination-pattern T
session target ipv4:10.101.85.1
voice-class codec 1
CME (PEMrt1) with PRI
dial-peer voice 3005 voip
description Dial-Peer to PEMrt4
destination-pattern 331[0-4].
session target ipv4:10.255.101.106
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 3006 voip
destination-pattern 332..
codec g711ulaw
dial-peer voice 107 pots
translation-profile outgoing TranslateOutgoingMain
preference 1
destination-pattern 9T
port 0/1/1:15
dial-peer voice 101 pots
translation-profile incoming TranslateIncoming
incoming called-number .
direct-inward-dial
The call is matching dial-peer 10 and 107 on router 1...What is in thos dial-peers?
I don’t have a dial-peer 10 configured. Here are all the dial-peers I have configured at this time on that router.
dial-peer voice 3000 voip
description Dial-Peer to Maputo
destination-pattern 331[5-9].
session target ipv4:10.101.254.1
direct-inward-dial
dial-peer voice 208 pots
preference 1
destination-pattern 8T
port 0/1/1:15
preference 1
port 0/1/1:15
dial-peer voice 999030 pots
destination-pattern 33199
port 0/3/0
codec g711ulaw
codec g711ulaw
dial-peer voice 108 pots
trunkgroup FXO
preference 2
dial-peer voice 207 pots
trunkgroup FXO
description "FXO Backup Dial-Peer for PSTN Access"
preference 2
Oh, that is not dial-peer 10, that is a space in the copy and paste I did. It is 107.
Ayodeji Okanlawon
Can you send a sh run of both routers? Which router did you take this log from?
I took the debug from the CME with the PRI.  I will send you a message with the sh run of each router.
Ok,
Billy this is what is going on..
The call goes out first through dial-peer 107 which is your PRI port, it goes to the PSTN and the telco disconnects the call
Then it comes back and tries the second dial-peer 108 and it connects..
So you need to talk to your provider and find out why they are disconeecting the call
Ok, thanks.
Ok, when this issue is resolved I will. Thanks.
