669
Highlighted
CME Router firmware update No more root directory entries available
Hi,All
I am using cisco 2911SR router try to upgrade phone firmware in ip phone 8945 sires  through TFTP  but the tftp erroe for uploading time please see the bellow ...
CME Router#copy tftp flash
Address or name of remote host [192.168.20.144]?
Source filename [SIP8941_8945.9-3-2-12.loads]?
Destination filename [SIP8941_8945.9-3-2-12.loadsl]?
Accessing tftp://192.168.20.144/acctfixedpin.tcl...
Loading SIP8941_8945.9-3-2-12.loads from 192.168.20.144 (via GigabitEthernet0/2): !
%Error opening flash0:/SIP8941_8945.9-3-2-12.loads (No more root directory entries available)
Please replay for ASNP
Thank you
3 REPLIES 3
Highlighted
Hi.Can you please send the
Hi.
Can you please send the output of a show flash: and show flash0: ?
Also send a show inventory and a show run | i tftp
Carlo
Please rate all helpful posts "The more you help the more you learn"
Highlighted
HiThanks for Replay Tharawat
Thanks for Replay
Tharawat-CME#sh flash
-#- --length-- -----date/time------ path
1     82174080 Nov 30 1983 03:00:00 +03:00 c2900-universalk9-mz.SPA.153-1.T.bin
2         4118 Mar 24 2014 10:11:26 +03:00 admin_user.html
3       677820 Mar 24 2014 10:11:28 +03:00 admin_user.js
4         1029 Mar 24 2014 10:11:28 +03:00 CiscoLogo.gif
5         1019 Mar 24 2014 10:11:30 +03:00 CME_GUI_README.TXT
6          953 Mar 24 2014 10:11:30 +03:00 Delete.gif
7        16344 Mar 24 2014 10:11:30 +03:00 dom.js
8          864 Mar 24 2014 10:11:30 +03:00 downarrow.gif
9         6315 Mar 24 2014 10:11:32 +03:00 ephone_admin.html
10        4558 Mar 24 2014 10:11:32 +03:00 logohome.gif
11        2814 Jan 29 2013 23:55:54 +03:00 cpconfig-29xx.cfg
12      203820 Mar 24 2014 02:07:20 +03:00 crashinfo_20140324-020721-UTC
13      415956 Jan 29 2013 23:56:50 +03:00 sslclient-win-1.1.4.176.pkg
14        1038 Jan 29 2013 23:57:18 +03:00 home.shtml
15           0 Jan 29 2013 23:58:00 +03:00 cpexpress
16       29703 Jan 29 2013 23:58:00 +03:00 cpexpress/es_splash.jpg
17        1239 Jan 29 2013 23:58:00 +03:00 cpexpress/loading.gif
18       13690 Jan 29 2013 23:58:00 +03:00 cpexpress/runAPP.shtml
19         829 Jan 29 2013 23:58:02 +03:00 cpexpress/localized_msgs6.js
20         703 Jan 29 2013 23:58:02 +03:00 cpexpress/localized_msgs3.js
21         430 Jan 29 2013 23:58:02 +03:00 cpexpress/localized_msgs1.js
22          86 Jan 29 2013 23:58:02 +03:00 cpexpress/blank.html
23        1690 Jan 29 2013 23:58:04 +03:00 cpexpress/appsupport.js
24        6958 Jan 29 2013 23:58:04 +03:00 cpexpress/common.js
25          43 Jan 29 2013 23:58:04 +03:00 cpexpress/blank.gif
26        2534 Jan 29 2013 23:58:04 +03:00 cpexpress/launcher.html
27        7883 Jan 29 2013 23:58:04 +03:00 cpexpress/home_ui.html
28          43 Jan 29 2013 23:58:06 +03:00 cpexpress/spacer.gif
29         763 Jan 29 2013 23:58:06 +03:00 cpexpress/Cisco_logo.gif
30        1794 Jan 29 2013 23:58:06 +03:00 cpexpress/launchTask.html
31        1932 Jan 29 2013 23:58:06 +03:00 cpexpress/moreinfo.html
32        8539 Jan 29 2013 23:58:06 +03:00 cpexpress/myhome_ui.html
33        2033 Jan 29 2013 23:58:08 +03:00 cpexpress/localized_msgs_popup.js
34         712 Jan 29 2013 23:58:08 +03:00 cpexpress/cisco-logo-clear.gif
35         990 Jan 29 2013 23:58:08 +03:00 cpexpress/error.html
36        1680 Jan 29 2013 23:58:08 +03:00 cpexpress/version.txt
37     2785461 Jan 29 2013 23:58:14 +03:00 cpexpress/cpexpress.sgz
38           0 Jan 29 2013 23:58:16 +03:00 cpexpress/com
39           0 Jan 29 2013 23:58:16 +03:00 cpexpress/com/cisco
40           0 Jan 29 2013 23:58:18 +03:00 cpexpress/com/cisco/nm
41           0 Jan 29 2013 23:58:18 +03:00 cpexpress/com/cisco/nm/util
42           0 Jan 29 2013 23:58:18 +03:00 cpexpress/com/cisco/nm/util/sgz
43         703 Jan 29 2013 23:58:18 +03:00 cpexpress/com/cisco/nm/util/sgz/Loader.class
44       41780 Jan 29 2013 23:58:18 +03:00 cpexpress/ieloader.cab
45       62843 Jan 29 2013 23:58:18 +03:00 cpexpress/jploader.jar
46           0 Jan 29 2013 23:58:40 +03:00 html
47        5085 Jan 29 2013 23:58:40 +03:00 html/appsui.js
48         831 Jan 29 2013 23:58:40 +03:00 html/common.js
49           0 Jan 29 2013 23:58:40 +03:00 html/images
50         697 Jan 29 2013 23:58:40 +03:00 html/images/logo.gif
51          43 Jan 29 2013 23:58:42 +03:00 html/images/spacer.gif
52         296 Jan 29 2013 23:58:42 +03:00 html/images/warning.gif
53         763 Jan 29 2013 23:58:42 +03:00 html/images/Cisco_logo.gif
54         737 Jan 29 2013 23:58:42 +03:00 html/images/Cisco_logo_2.gif
55          86 Jan 29 2013 23:58:42 +03:00 html/blank.html
56         316 Jan 29 2013 23:58:44 +03:00 html/MW1.html
57        1861 Jan 29 2013 23:58:44 +03:00 html/MW2.html
58       12147 Jan 29 2013 23:58:44 +03:00 html/Pkg1_Signed.cab
59       14110 Jan 29 2013 23:58:44 +03:00 html/Pkg1_Signed.jar
60         466 Jan 29 2013 23:58:46 +03:00 html/launchIPS.shtml
61       12723 Jan 29 2013 23:58:46 +03:00 html/mws.shtml
62         990 Jan 29 2013 23:58:46 +03:00 html/error.html
63        7196 Jan 29 2013 23:58:46 +03:00 html/home_ui.shtml
64         422 Jan 29 2013 23:58:46 +03:00 html/home_aux.shtml
65       20012 Jan 29 2013 23:58:48 +03:00 html/home_engine.shtml
66         430 Jan 29 2013 23:58:48 +03:00 html/localized_msgs1.js
67         210 Jan 29 2013 23:58:48 +03:00 html/localized_msgs2.js
68         714 Jan 29 2013 23:58:48 +03:00 html/localized_msgs3.js
69        1100 Jan 29 2013 23:58:48 +03:00 html/localized_msgs4.js
70         923 Jan 29 2013 23:58:50 +03:00 html/localized_msgs5.js
71        2033 Jan 29 2013 23:58:50 +03:00 html/localized_msgs_popup.js
72        1932 Jan 29 2013 23:58:50 +03:00 html/moreinfo.html
73        8539 Jan 29 2013 23:58:50 +03:00 html/myhome_ui.html
74           0 Jan 30 2013 11:06:04 +03:00 its
75          69 Sep 13 2015 12:20:38 +03:00 its/syncinfo.xml
76        2003 Sep 13 2015 12:20:40 +03:00 its/SIPDefault.cnf
77        4748 Sep 13 2015 12:20:40 +03:00 its/softkeyDefault_kpml.xml
78        4782 Sep 13 2015 12:20:40 +03:00 its/softkeyDefault.xml
79         824 Sep 13 2015 12:20:40 +03:00 its/featurePolicyDefault.xml
80        5169 Sep 13 2015 12:20:42 +03:00 its/SEPC40ACBE063A2.cnf.xml
81        5171 Sep 13 2015 12:20:42 +03:00 its/SEPC40ACBE1D0BD.cnf.xml
82        4664 Sep 13 2015 12:20:42 +03:00 its/SEP04C5A4B0D1FF.cnf.xml
83        6148 Sep 13 2015 12:20:42 +03:00 its/SEP1CAA07100BFC.cnf.xml
84        6150 Sep 13 2015 12:20:44 +03:00 its/SEP54781AE1CBBA.cnf.xml
85        5752 Sep 13 2015 12:20:44 +03:00 its/SEPE84040A31A13.cnf.xml
86        4789 Sep 13 2015 12:20:44 +03:00 its/SEPC40ACB4C4ECD.cnf.xml
87        4640 Sep 13 2015 12:20:44 +03:00 its/SEPC40ACBE137EC.cnf.xml
88        3725 Sep 13 2015 12:20:44 +03:00 its/ATAB4E9B08D833F.cnf.xml
89        3733 Sep 13 2015 12:20:46 +03:00 its/ATAB4E9B08D82E4.cnf.xml
90        3731 Sep 13 2015 12:20:46 +03:00 its/ATAB4E9B08D8335.cnf.xml
91        3978 Mar 24 2014 10:11:32 +03:00 normal_user.html
92       78428 Mar 24 2014 10:11:32 +03:00 normal_user.js
93        1347 Mar 24 2014 10:11:34 +03:00 Plus.gif
94         843 Mar 24 2014 10:11:34 +03:00 sxiconad.gif
95         174 Mar 24 2014 10:11:34 +03:00 Tab.gif
96         870 Mar 24 2014 10:11:34 +03:00 uparrow.gif
97       32178 Jun 3 2013 13:03:58 +03:00 cdrbib.Tharawat-CME.06_03_2013_12_38_20.056
98           0 Aug 31 2013 12:21:46 +03:00 Desktops
99           0 Aug 31 2013 12:22:50 +03:00 Desktops/640x480x24
100        490 Apr 24 2014 11:53:06 +03:00 Desktops/640x480x24/List.xml
101      16744 Apr 24 2014 11:53:32 +03:00 Desktops/640x480x24/tharawat1.png
102      58934 Apr 24 2014 11:53:50 +03:00 Desktops/640x480x24/tharawat2.png
103     386808 Apr 24 2014 11:54:08 +03:00 Desktops/640x480x24/tharawat3.png
104      17236 Apr 24 2014 11:54:26 +03:00 Desktops/640x480x24/tharawat4.png
105          0 Feb 19 2013 19:05:14 +03:00 CME 9.1.0 GUI
106          0 Oct 14 2015 09:39:12 +03:00 ORPHAN1
107       8192 Oct 14 2015 09:39:12 +03:00 ORPHAN1/orphan_1
108         24 Jun 21 2013 09:40:48 +03:00 cdrbib.Tharawat-CME.06_21_2013_08_38_19.879
109       3053 Jun 22 2013 10:05:00 +03:00 cdrbib.Tharawat-CME.06_21_2013_11_12_31.891
110      27491 Jun 23 2013 10:05:02 +03:00 cdrbib.Tharawat-CME.06_22_2013_11_10_02.105
111      37067 Jun 24 2013 10:05:02 +03:00 cdrbib.Tharawat-CME.06_23_2013_11_10_02.327
112       2496 Mar 24 2014 10:11:34 +03:00 telephony_service.html
113      10230 Mar 24 2014 10:11:36 +03:00 xml-test.html
114       3412 Mar 24 2014 10:11:36 +03:00 xml.template
115      25042 Jul 3 2014 17:50:14 +03:00 cdrbib.Tharawat-CME.07_03_2014_16_43_23.268
116       1655 Jul 26 2014 19:16:04 +03:00 cdrbib.Tharawat-CME.07_25_2014_20_23_35.939
117       6074 Jul 27 2014 19:16:06 +03:00 cdrbib.Tharawat-CME.07_26_2014_20_21_06.153
118       6032 Jul 28 2014 19:16:06 +03:00 cdrbib.Tharawat-CME.07_27_2014_20_21_06.367
119      37205 Jun 24 2013 13:28:58 +03:00 cdrbib.Tharawat-CME.06_24_2013_11_10_02.557
120     301665 Jul 29 2013 20:05:32 +03:00 cdrbib.Tharawat-CME.07_28_2013_21_13_03.960
121      28247 Jul 30 2013 20:05:34 +03:00 cdrbib.Tharawat-CME.07_29_2013_21_10_34.222
122      93061 Jul 31 2013 20:05:34 +03:00 cdrbib.Tharawat-CME.07_30_2013_21_10_34.445
123      75812 Aug 1 2013 20:05:34 +03:00 cdrbib.Tharawat-CME.07_31_2013_21_10_34.659
124        276 Aug 2 2013 20:05:34 +03:00 cdrbib.Tharawat-CME.08_01_2013_21_10_34.877
125       1016 Aug 3 2013 20:05:34 +03:00 cdrbib.Tharawat-CME.08_02_2013_21_10_35.091
126        276 Aug 4 2013 20:05:34 +03:00 cdrbib.Tharawat-CME.08_03_2013_21_10_35.305
127        276 Aug 5 2013 20:05:34 +03:00 cdrbib.Tharawat-CME.08_04_2013_21_10_35.519
128       9760 Aug 6 2013 20:05:34 +03:00 cdrbib.Tharawat-CME.08_05_2013_21_10_35.733
129        276 Aug 7 2013 20:05:34 +03:00 cdrbib.Tharawat-CME.08_06_2013_21_10_35.947
130        276 Aug 8 2013 20:05:36 +03:00 cdrbib.Tharawat-CME.08_07_2013_21_10_36.141
131       1003 Aug 9 2013 20:05:36 +03:00 cdrbib.Tharawat-CME.08_08_2013_21_10_36.335
132        276 Aug 10 2013 20:05:36 +03:00 cdrbib.Tharawat-CME.08_09_2013_21_10_36.529
133       1008 Aug 11 2013 20:05:36 +03:00 cdrbib.Tharawat-CME.08_10_2013_21_10_36.723
134        276 Aug 12 2013 20:05:36 +03:00 cdrbib.Tharawat-CME.08_11_2013_21_10_36.917
135      57730 Aug 13 2013 20:05:36 +03:00 cdrbib.Tharawat-CME.08_12_2013_21_10_37.131
136      14222 Aug 14 2013 11:33:38 +03:00 cdrbib.Tharawat-CME.08_13_2013_21_10_37.361
137       7315 Aug 25 2013 10:11:02 +03:00 cdrbib.Tharawat-CME.08_24_2013_11_18_32.061
138     107924 Aug 26 2013 10:11:02 +03:00 cdrbib.Tharawat-CME.08_25_2013_11_16_02.283
139     118739 Aug 27 2013 10:11:02 +03:00 cdrbib.Tharawat-CME.08_26_2013_11_16_02.529
140     102618 Aug 28 2013 10:11:02 +03:00 cdrbib.Tharawat-CME.08_27_2013_11_16_02.779
141     164033 Aug 29 2013 10:11:02 +03:00 cdrbib.Tharawat-CME.08_28_2013_11_16_03.109
142     182252 Aug 30 2013 10:11:02 +03:00 cdrbib.Tharawat-CME.08_29_2013_11_16_03.451
143        276 Aug 31 2013 10:11:02 +03:00 cdrbib.Tharawat-CME.08_30_2013_11_16_03.681
144      31021 Aug 31 2013 12:21:02 +03:00 cdrbib.Tharawat-CME.08_31_2013_11_16_03.895
145       7100 Aug 31 2013 14:17:14 +03:00 cdrbib.Tharawat-CME.08_31_2013_14_17_15.483
146     100055 Sep 1 2013 14:20:18 +03:00 cdrbib.Tharawat-CME.08_31_2013_14_32_03.331
147     174014 Sep 2 2013 14:20:18 +03:00 cdrbib.Tharawat-CME.09_01_2013_14_56_47.157
148     221967 Sep 3 2013 14:20:18 +03:00 cdrbib.Tharawat-CME.09_02_2013_15_24_05.175
149     246362 Sep 4 2013 14:20:18 +03:00 cdrbib.Tharawat-CME.09_03_2013_14_34_50.946
150     150790 Sep 5 2013 14:20:18 +03:00 cdrbib.Tharawat-CME.09_04_2013_14_54_35.072
151      91057 Sep 6 2013 14:20:18 +03:00 cdrbib.Tharawat-CME.09_05_2013_15_15_13.401
152        276 Sep 7 2013 14:20:18 +03:00 cdrbib.Tharawat-CME.09_06_2013_15_25_19.960
153      32510 Sep 8 2013 14:20:20 +03:00 cdrbib.Tharawat-CME.09_07_2013_15_25_20.174
154     208832 Sep 9 2013 14:20:20 +03:00 cdrbib.Tharawat-CME.09_08_2013_15_25_20.412
155     241404 Sep 10 2013 14:20:20 +03:00 cdrbib.Tharawat-CME.09_09_2013_14_54_48.078
156     217204 Sep 11 2013 14:20:20 +03:00 cdrbib.Tharawat-CME.09_10_2013_14_56_20.324
157     199753 Sep 12 2013 14:20:20 +03:00 cdrbib.Tharawat-CME.09_11_2013_14_44_27.446
158      90418 Sep 13 2013 14:20:20 +03:00 cdrbib.Tharawat-CME.09_12_2013_15_25_21.504
159       1794 Sep 14 2013 14:20:20 +03:00 cdrbib.Tharawat-CME.09_13_2013_15_25_21.726
160     179185 Sep 15 2013 14:20:20 +03:00 cdrbib.Tharawat-CME.09_14_2013_15_25_21.944
161     247375 Sep 16 2013 14:20:22 +03:00 cdrbib.Tharawat-CME.09_15_2013_15_01_33.930
162     418836 Sep 17 2013 14:20:22 +03:00 cdrbib.Tharawat-CME.09_16_2013_14_59_33.196
163     336128 Sep 18 2013 14:20:22 +03:00 cdrbib.Tharawat-CME.09_17_2013_14_49_00.826
164     132529 Sep 19 2013 07:40:22 +03:00 cdrbib.Tharawat-CME.09_18_2013_14_49_42.536
165     282152 Sep 20 2013 08:05:36 +03:00 cdrbib.Tharawat-CME.09_19_2013_09_13_07.319
166        276 Sep 21 2013 08:05:36 +03:00 cdrbib.Tharawat-CME.09_20_2013_09_10_37.537
167         72 Sep 21 2013 14:35:36 +03:00 cdrbib.Tharawat-CME.09_21_2013_09_10_37.755
168       8356 Sep 21 2013 14:34:28 +03:00 TN-Tharawat.png
169    2118056 Sep 21 2013 14:58:14 +03:00 APPATA187.9-2-3-1.img.sgn
170        491 Sep 21 2013 14:58:40 +03:00 ATA187.9-2-3-1.loads
171    2818472 Sep 21 2013 14:59:12 +03:00 BFSATA187.9-2-3-1.img.sgn
172     624124 Sep 21 2013 14:59:32 +03:00 KNLATA187.9-2-3-1.bin.sgn
173      54495 Sep 22 2013 14:42:32 +03:00 cdrbib.Tharawat-CME.09_21_2013_15_43_17.763
174       9191 Sep 23 2013 14:42:32 +03:00 cdrbib.Tharawat-CME.09_22_2013_15_47_32.529
175     231248 Sep 24 2013 14:42:32 +03:00 cdrbib.Tharawat-CME.09_23_2013_15_47_32.751
176     351875 Sep 25 2013 14:42:32 +03:00 cdrbib.Tharawat-CME.09_24_2013_14_53_47.266
177     507251 Sep 26 2013 14:42:32 +03:00 cdrbib.Tharawat-CME.09_25_2013_15_23_55.052
178     143406 Sep 27 2013 14:42:32 +03:00 cdrbib.Tharawat-CME.09_26_2013_15_33_03.394
179      41976 Sep 28 2013 14:42:32 +03:00 cdrbib.Tharawat-CME.09_27_2013_15_47_33.904
180     247969 Sep 29 2013 14:42:34 +03:00 cdrbib.Tharawat-CME.09_28_2013_15_47_34.138
181     408640 Sep 30 2013 14:42:34 +03:00 cdrbib.Tharawat-CME.09_29_2013_15_17_23.304
182     247303 Oct 1 2013 14:42:34 +03:00 cdrbib.Tharawat-CME.09_30_2013_15_13_00.358
183     427926 Oct 2 2013 14:42:34 +03:00 cdrbib.Tharawat-CME.10_01_2013_15_02_02.452
184     270720 Oct 3 2013 14:42:34 +03:00 cdrbib.Tharawat-CME.10_02_2013_15_31_43.430
185     146159 Oct 4 2013 14:42:34 +03:00 cdrbib.Tharawat-CME.10_03_2013_15_26_54.540
186       6784 Oct 5 2013 14:42:34 +03:00 cdrbib.Tharawat-CME.10_04_2013_15_47_35.990
187     110352 Oct 6 2013 14:42:36 +03:00 cdrbib.Tharawat-CME.10_05_2013_15_47_36.212
188     235212 Oct 7 2013 14:42:36 +03:00 cdrbib.Tharawat-CME.10_06_2013_15_23_17.450
189     210611 Oct 8 2013 14:42:36 +03:00 cdrbib.Tharawat-CME.10_07_2013_15_14_23.264
190     326248 Oct 9 2013 14:42:36 +03:00 cdrbib.Tharawat-CME.10_08_2013_15_11_08.290
191     168997 Oct 10 2013 14:42:36 +03:00 cdrbib.Tharawat-CME.10_09_2013_15_29_38.404
192      35607 Oct 11 2013 14:42:36 +03:00 cdrbib.Tharawat-CME.10_10_2013_15_21_43.722
193      10564 Oct 12 2013 14:42:36 +03:00 cdrbib.Tharawat-CME.10_11_2013_15_47_37.984
194        276 Oct 13 2013 14:42:38 +03:00 cdrbib.Tharawat-CME.10_12_2013_15_47_38.206
195      15575 Oct 14 2013 14:42:38 +03:00 cdrbib.Tharawat-CME.10_13_2013_15_47_38.428
196      28213 Oct 15 2013 14:42:38 +03:00 cdrbib.Tharawat-CME.10_14_2013_15_47_38.654
197      12954 Oct 16 2013 14:42:38 +03:00 cdrbib.Tharawat-CME.10_15_2013_15_47_38.884
198      10608 Oct 17 2013 14:42:38 +03:00 cdrbib.Tharawat-CME.10_16_2013_15_47_39.122
199       6297 Oct 18 2013 14:42:38 +03:00 cdrbib.Tharawat-CME.10_17_2013_15_47_39.364
153948160 bytes available (102662144 bytes used)
Tharawat-CME#
Tharawat-CME#show flash0:
Tharawat-CME#
Highlighted
Hi MuhammedCreate a directory
Hi Muhammed
Create a directory with:
mkdir flash0:Firmware
Copy files into this directory with:
copy tftp flash0:/Firmware/
Try it and let me know
Carlo
Content for Community-Ad
Cisco COVID-19 Survey
