08-08-2022 02:45 AM
Hi everyone,
Does anyone encounter call routing issue on CME CISCO2911/K9?
Need help on our CME were using CISCO2911/K9. We've already setup the local DN and on our IP Phone. All of them are working internally. But when we've try to call outbound and inbound on our number we can't go through.
Do we need to add other configuration so we can call outbound and inbound?
Thanksss.
08-09-2022 12:55 AM
If you need help with your config, why don't you post the complete config (without sensitive info like username, password, ...). Nobody can help, you if you just through around pieces of information.
Also: Always post a debug output of a call. These are basics of troubleshooting. Nobody can read your mind or see what you see in the router. Because obviously, nobody else than you has access to the router.
And as I can probably read the question, which you have, after reading this post: "which debugs to use?"
debug ccsip messages
debug voice ccapi ind 1
debug voice ccapi ind 2
debug voice ccapi ind 74
08-09-2022 04:50 AM
From what you provided we cannot help you. Provide us the debugs @b.winter mentioned. Also is you can share the configuration removing sensitive informations will be helpful.
