12-18-2014 06:31 AM - edited 03-17-2019 01:22 AM
I am having issues with getting a Cisco 7821 phone to register.
Current deployment is with Cisco 6921 phones SCCP registration
SIP integration with CUE
SIP integration with Mitel system
c2951-universalk9-mz.SPA.154-3.M1.bin (CME 10.5)
In flash:
rootfs78xx.10-1-1SR1-4.sbn
kern78xx.10-1-1SR1-4.sbn
sboot78xx.10-1-1SR1-4.sbn
sip78xx.10-1-1SR1-4.loads
The 7821 phone gets IP address but fails to register. Please could somebody let me know why phone is not registering.
Configuration below (10.245.226.132 is CME address) .
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw redundancy maximum-sessions 5
h323
sip
registrar server expires max 600 min 60
options-ping 90
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice register global
mode cme
source-address 10.245.226.132 port 5060
max-dn 30
max-pool 10
load 7821 sip78xx.10-1-1SR1-4
authenticate register
authenticate realm all
timezone 22
date-format D/M/Y
voicemail 590
tftp-path flash:
create profile sync 0061443538560005
network-locale GB
voice register dn 1
number 1010
name user1
label user1
mwi
voice register pool 1
busy-trigger-per-button 2
id mac F09E.636E.63F2
type 7821
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
username 1010 password 123
codec g711ulaw
no vad
dial-peer voice 391 voip
description *** Auto Attendant ***
destination-pattern 399
session protocol sipv2
session target ipv4:10.245.226.131
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 392 voip
description *** Administration Via Telephone ***
destination-pattern 392
codec g711ulaw
no vad
dial-peer voice 393 voip
description *** Extension Assigner ***
service ea out-bound
destination-pattern 393
session target ipv4:10.245.226.132
dial-peer voice 590 voip
description *** Voice Mail Pilot ***
destination-pattern 590
b2bua
codec g711ulaw
no vad
dial-peer voice 1 pots
description ** Match all incoming POTS calls **
translation-profile incoming IncomingPSTNcalls
incoming called-number .
direct-inward-dial
dial-peer voice 899 voip
description Call to Mitel
translation-profile incoming Prefix9
translation-profile outgoing rem44
destination-pattern [23]..
session target ipv4:192.168.114.2
voice-class codec 1
dtmf-relay rtp-nte
no vad
interface GigabitEthernet0/0
description *** Connection to Mitel Phone System ***
ip address 192.168.114.5 255.255.255.248
duplex auto
speed auto
interface ISM0/0
description *** Connection to Cisco Unity Express ***
ip unnumbered GigabitEthernet0/1
service-module ip address 10.245.226.131 255.255.255.128
!Application: CUE Running on ISM
service-module ip default-gateway 10.245.226.132
interface GigabitEthernet0/1
description *** Connection to IP Phone LAN ***
ip address 10.245.226.132 255.255.255.128
duplex auto
speed auto
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip route 0.0.0.0 0.0.0.0 10.245.226.129
ip route 10.245.226.131 255.255.2
tftp-server flash:apps37sccp.1-4-4-0.bin
tftp-server flash:sip78xx.10-1-1SR1-4.loads
tftp-server flash:rootfs78xx.10-1-1SR1-4.sbn
tftp-server flash:sboot78xx.10-1-1SR1-4.sbn
sip-ua
mwi-server ipv4:10.245.226.131 expires 3600 port 5060 transport udp
registrar ipv4:10.245.226.132 expires 600
gatekeeper
shutdown
telephony-service
authentication credential cmeadmin c4p1ta2012
xml user xmladmin password xmladmin 15
extension-assigner tag-type provision-tag
max-ephones 104
max-dn 299
ip source-address 10.245.226.132 port 2000
auto assign 101 to 105
no service directed-pickup
timeouts interdigit 5
system message CFGS
url services http://10.245.226.131/voiceview/common/login.do
url authentication http://10.245.226.132/CCMCIP/authenticate.asp
cnf-file location flash:
cnf-file perphone
load 7931 SCCP31.9-2-1S
load 6921 SCCP69xx.9-2-1-0
time-zone 22
date-format dd-mm-yy
voicemail 590
max-conferences 8 gain -6
call-forward pattern .T
moh enable-g711 "music-on-hold.au"
web admin system name cmeadmin secret 5 $1$QmIK$46fDKVSudMxzI2bRp/Ef7/
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 298
number 598...
mwi on
ephone-dn 299
number 599...
mwi off
Solved! Go to Solution.
04-06-2015 02:58 AM
I was having the same issue with 7821 and 8945 phones but after referring this blogs, I can able to solve, now both of my phones are registered and working
01-24-2016 10:24 PM
