CME SIP issue - Cisco 7821 phone not registering
gsidhu
Level 3
Level 3
I am having issues with getting a Cisco 7821 phone to register.
Current deployment is with Cisco 6921 phones SCCP registration
SIP integration with CUE
SIP integration with Mitel system
c2951-universalk9-mz.SPA.154-3.M1.bin (CME 10.5)
In flash:
rootfs78xx.10-1-1SR1-4.sbn
kern78xx.10-1-1SR1-4.sbn
sboot78xx.10-1-1SR1-4.sbn
sip78xx.10-1-1SR1-4.loads
The 7821 phone gets IP address but fails to register. Please could somebody let me know why phone is not registering.
Configuration below (10.245.226.132 is CME address) .
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol pass-through g711ulaw
 modem passthrough nse codec g711ulaw redundancy maximum-sessions 5
 h323
 sip
  registrar server expires max 600 min 60
  options-ping 90
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
 codec preference 3 g729r8
voice register global
 mode  cme
 source-address 10.245.226.132 port 5060
 max-dn 30
 max-pool 10
 load 7821 sip78xx.10-1-1SR1-4
 authenticate register
 authenticate realm all
 timezone 22
 date-format D/M/Y
 voicemail 590
 tftp-path flash:
 create profile sync 0061443538560005
 network-locale GB
voice register dn  1
 number 1010
 name user1
 label user1
 mwi
voice register pool  1
 busy-trigger-per-button 2
 id mac F09E.636E.63F2
 type 7821
 number 1 dn 1
 presence call-list
 dtmf-relay rtp-nte
 username 1010 password 123
 codec g711ulaw
 no vad
dial-peer voice 391 voip
 description *** Auto Attendant ***
 destination-pattern 399
 session protocol sipv2
 session target ipv4:10.245.226.131
 dtmf-relay sip-notify
 codec g711ulaw
 no vad
dial-peer voice 392 voip
 description *** Administration Via Telephone ***
 destination-pattern 392
 codec g711ulaw
 no vad
dial-peer voice 393 voip
 description *** Extension Assigner ***
 service ea out-bound
 destination-pattern 393
 session target ipv4:10.245.226.132
dial-peer voice 590 voip
 description *** Voice Mail Pilot ***
 destination-pattern 590
 b2bua
 codec g711ulaw
 no vad
dial-peer voice 1 pots
 description ** Match all incoming POTS calls **
 translation-profile incoming IncomingPSTNcalls
 incoming called-number .
 direct-inward-dial
dial-peer voice 899 voip
 description Call to Mitel
 translation-profile incoming Prefix9
 translation-profile outgoing rem44
 destination-pattern [23]..
 session target ipv4:192.168.114.2
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
interface GigabitEthernet0/0
 description *** Connection to Mitel Phone System  ***
 ip address 192.168.114.5 255.255.255.248
 duplex auto
 speed auto
interface ISM0/0
 description *** Connection to Cisco Unity Express ***
 ip unnumbered GigabitEthernet0/1
 service-module ip address 10.245.226.131 255.255.255.128
 !Application: CUE Running on ISM
 service-module ip default-gateway 10.245.226.132
interface GigabitEthernet0/1
 description *** Connection to IP Phone LAN ***
 ip address 10.245.226.132 255.255.255.128
 duplex auto
 speed auto
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip route 0.0.0.0 0.0.0.0 10.245.226.129
ip route 10.245.226.131 255.255.2
tftp-server flash:apps37sccp.1-4-4-0.bin
tftp-server flash:sip78xx.10-1-1SR1-4.loads
tftp-server flash:rootfs78xx.10-1-1SR1-4.sbn
tftp-server flash:sboot78xx.10-1-1SR1-4.sbn
sip-ua
 mwi-server ipv4:10.245.226.131 expires 3600 port 5060 transport udp
 registrar ipv4:10.245.226.132 expires 600
gatekeeper
 shutdown
telephony-service
 authentication credential cmeadmin c4p1ta2012
 xml user xmladmin password xmladmin 15
 extension-assigner tag-type provision-tag
 max-ephones 104
 max-dn 299
 ip source-address 10.245.226.132 port 2000
 auto assign 101 to 105
 no service directed-pickup
 timeouts interdigit 5
 system message CFGS
 url services http://10.245.226.131/voiceview/common/login.do
 url authentication http://10.245.226.132/CCMCIP/authenticate.asp
 cnf-file location flash:
 cnf-file perphone
 load 7931 SCCP31.9-2-1S
 load 6921 SCCP69xx.9-2-1-0
 time-zone 22
 date-format dd-mm-yy
 voicemail 590
 max-conferences 8 gain -6
 call-forward pattern .T
 moh enable-g711 "music-on-hold.au"
 web admin system name cmeadmin secret 5 $1$QmIK$46fDKVSudMxzI2bRp/Ef7/
 time-webedit
 transfer-system full-consult
 transfer-pattern .T
 secondary-dialtone 9
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  298
 number 598...
 mwi on
ephone-dn  299
 number 599...
 mwi off
michael o'nan
Level 4
Level 4
What is displayed on the phone while it is booting up?
You might try this to see if it helps:
no load 7821 sip78xx.10-1-1SR1-4
no create profile
create profile
Then power cycle the phone
46 Replies 46
michael o'nan
Level 4
Level 4
no create profile
create profile
Nice one Michael
This worked and phone registered..
However when I applied the changes I got the following error message....any ideas?
CENTFS-CME-GTWY(config)#voice register global
CENTFS-CME-GTWY(config-register-global)#
CENTFS-CME-GTWY(config-register-global)#$1 sip78xx.10-1-1SR1-4
CENTFS-CME-GTWY(config-register-global)#no create profile
%Error deleting flash:/its/jabber-config.xml (File not found)
%Error deleting flash:/its/SEPF09E636E63F2.cnf.xml (File not found)
CENTFS-CME-GTWY(config-register-global)#create profile
It's nothing to worry about. It thinks there should be a configuration file for a phone that it didn't find when it was trying to delete it. Any time you make any changes with SIP phones on CME make sure you go to voice register global and do no create profile/create profile. I would try to add the load command back in and see if that may be the issue or if you just needed to reissue the create profile.
Thank you for your help Michael
I had left the customer site shortly before your last two posts. I have given you a well deserved 5 points.
I will add the command back when I am back onsite tomorrow and let you know how I get on
Hi! There
I am facing the same problem with cisco 7821
Current configuration : 5666 bytes
version 15.4
hostname Router_CMR
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
clock timezone Maputo 2 0
ip dhcp excluded-address 192.168.4.1 192.168.4.20
ip dhcp excluded-address 192.168.8.1 192.168.8.20
ip dhcp pool DATA
network 192.168.4.0 255.255.255.0
option 150 ip 192.168.8.1
default-router 192.168.4.1
ip dhcp pool VOICE
network 192.168.8.0 255.255.255.0
default-router 192.168.8.1
no ip domain lookup
ip cef
no ipv6 cef
voice-card 0
voice service voip
ip address trusted list
ipv4 192.168.8.0 255.255.255.0
no supplementary-service h450.7
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/1
bind media source-interface GigabitEthernet0/1
options-ping 90
voice class codec 1
voice register pool-type 7821
xml-config maxNumCalls 6
xml-config busyTrigger 6
xml-config custom sshAccess 0
num-lines 2
description Cisco IP Phone 7821
reference-pooltype 6921
no fac refer
mode cme
source-address 192.168.8.1 port 5060
max-dn 100
max-pool 50
timezone 29
time-format 24
url directory http://192.168.8.1/localdirectory
tftp-path flash:
create profile sync 0025024553454705
network-locale PT
user-locale PT
camera
video
voice register dn 1
number 1
pickup-call any-group
name John
label Gildo Sibunde
voice register dn 2
number 2
name Augusto Sousa
label Augusto Sousa
busy-trigger-per-button 1
id mac 204C.9EB2.2F77
session-transport tcp
type 7821
number 1 dn 1
dtmf-relay rtp-nte
username cisco password cisco
description GildoSibunde
codec g711ulaw
voice register pool 2
id mac 204C.9EB2.2F31
type 7821
number 1 dn 2
dtmf-relay rtp-nte
username test password test
description AugustoSousa
codec g711ulaw
license udi pid CISCO2911/K9 sn FJC1923A38Y
hw-module pvdm 0/0
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
description TO_PROVIDER
ip address 10.10.10.1 255.255.255.0
duplex auto
speed auto
description TO_LAN
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.4
description DATA
encapsulation dot1Q 4
ip address 192.168.4.1 255.255.255.0
interface GigabitEthernet0/1.8
description VOICE
encapsulation dot1Q 8
ip address 192.168.8.1 255.255.255.0
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
snmp-server community RO RO
snmp-server enable traps license
snmp-server enable traps energywise level-change
snmp-server enable traps memory bufferpeak
snmp-server enable traps config-copy
snmp-server enable traps syslog
snmp-server enable traps dial
snmp-server enable traps voice
tftp-server flash:cmterm-78xx.10-3-1-12
tftp-server flash:kern2.78xx.10-3-1-12.sbn
tftp-server flash:kern78xx.10-3-1-12.sbn
tftp-server flash:rootfs2.78xx.10-3-1-12.sbn
tftp-server flash:rootfs78xx.10-3-1-12.sbn
tftp-server flash:sboot2.78xx.10-3-1-12.sbn
tftp-server flash:sboot78xx.10-3-1-12.sbn
tftp-server flash:sip78xx.10-3-1-12.loads
tftp-server flash:kern78xx.10-1-1SR1-4.sbn
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
max-ephones 50
max-dn 100
ip source-address 192.168.8.1 port 2000
max-redirect 5
auto assign 1 to 50
cnf-file perphone
time-zone 29
time-format 24
ephone-template 1
network-locale 1
user-locale 1
ephone-dn 1
number 01
label Peter
description Peter
name Peter
ephone-dn 2
number 02
label John
description John
name John
ephone 1
mac-address 204C.9EB2.2F77
ephone-template 1
max-calls-per-button 2
username "Peter"
button 1:1
ephone 2
mac-address 204C.9EB2.2F31
username "John"
button 1:2
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
logging synchronous
login local
transport input all
scheduler allocate 20000 1000
end
Hi Alcido,
Options-ping is not needed for phones. You could remove this in SIP configutaion:
sip
no options-ping 90
What do you see in debug ccsip messages when the phone tries to register. If you see "unauthorized" error, then try the following:
no authenticate register
no create profile
create profile
Finally power cycle the phone.
If the issue persists, provide the below debugs when the phone tries to register:
debug tftp events
HTH,
Rajan
Please rate useful posts
Dear Rajan
Thank you for your support, now I can registe the IP Phone but I am facing new issue:  I'm not able to make calls from one phone to another.
See bellow the debug output:
*Nov 2 09:47:32.567: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:2@192.168.8.1;user=phone SIP/2.0
Via: SIP/2.0/TCP 192.168.8.22:51080;branch=z9hG4bK396a471d
From: "Gildo Sibunde" <sip:1@192.168.8.1>;tag=204c9eb22f77000c6a44f6dc-0edbce95
To: <sip:2@192.168.8.1>
Call-ID: 204c9eb2-2f770009-3a67e4b1-3a89a5d7@192.168.8.22
Max-Forwards: 70
Date: Mon, 02 Nov 2015 09:47:31 GMT
CSeq: 101 INVITE
User-Agent: Cisco-CP7821/10.1.1
Contact: <sip:3A3304-170E@192.168.8.22:51080;transport=tcp>
Expires: 180
Accept: application/sdp
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "John" <sip:1@192.168.8.1>;party=calling;id-type=subscriber;privacy=off;screen=yes
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-6.0.2,X-cisco-xsi-8.5.1
Allow-Events: kpml,dialog
Content-Length: 352
Content-Type: application/sdp
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 21169 0 IN IP4 192.168.8.22
s=SIP Call
t=0 0
m=audio 27082 RTP/AVP 0 8 18 102 116 101
c=IN IP4 192.168.8.22
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:102 L16/16000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
*Nov 2 09:47:32.579: //20/92BB299B8037/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
From: "John" <sip:1@192.168.8.1>;tag=204c9eb22f77000c6a44f6dc-0edbce95
Date: Mon, 02 Nov 2015 09:47:32 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.4.1.T3
Content-Length: 0
*Nov 2 09:47:32.583: //20/92BB299B8037/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
To: <sip:2@192.168.8.1>;tag=69CF08-2619
CSeq: 101 INVITE
Warning: 399 192.168.8.1 "Transcoder Not Configured"
Reason: Q.850;cause=47
Content-Length: 0
*Nov 2 09:47:32.587: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:2@192.168.8.1;user=phone SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Nov 2 09:48:49.747: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.8.1 SIP/2.0
Via: SIP/2.0/TCP 192.168.8.22:51080;branch=z9hG4bK59fdde00
From: <sip:1@192.168.8.1>;tag=204c9eb22f77000e45c00fcc-737762a1
To: <sip:1@192.168.8.1>
Call-ID: 204c9eb2-2f770002-18ad3fc2-76dcc1fa@192.168.8.22
Max-Forwards: 70
Date: Mon, 02 Nov 2015 09:48:48 GMT
CSeq: 103 REGISTER
Contact: <sip:3A3304-170E@192.168.8.22:51080;transport=tcp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-204c9eb22f77>";+u.sip!devicename.ccm.cisco.com="SEP204C9EB22F77";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
Sent:
SIP/2.0 200 OK
To: <sip:1@192.168.8.1>;tag=6AFC74-4F9
Date: Mon, 02 Nov 2015 09:48:49 GMT
CSeq: 103 REGISTER
Supported: X-cisco-cme-sis-1.0.0
Supported: X-cisco-srtp-fallback
Contact: <sip:1@192.168.8.22:51080;transport=tcp>;expires=300
Expires: 300
Content-Length: 0
Best Regards
Alcidio Tembe
Hi Alcidio,
It looks we have issues with the codec as the call fails with cause=47 (resource unavailable). Also we could see "Transcoder Not Configured" message.
Which endpoint you are calling? try to match the codec on both ends to avoid the requirement of a transcoder or if you want to keep the codecs and want the endpoints to communicate with different codecs, configure a transcoder.
Rajan
Check the minimum memory requirements. You may need to increase DRAM
Current deployment is with Cisco 6921 phones and 7945 ip phones both are working...in my router 2921 as a CME
plz assist me step by step
right now m using frimware in router 2921 9.1 version and cisco unity express using 8.6.6
and problem is 7821 ip phone is not registerd and it is getting ip address also from dhcp
Dear zaidysharib
The configuration for IP Phone 6921 and 7821 are different because its doesnt use the same protocol (SIP & SCCP), so could you please share your configuration so that we can discuss more about.
Best Regards
Alcidio Tembe
Current configuration : 26915 bytes
! Last configuration change at 09:26:14 AST Wed Dec 2 2015 by admin
! NVRAM config last updated at 15:58:02 AST Tue Dec 1 2015 by admin
version 15.2
hostname H-AlSAMAH-RTR01
boot-start-marker
boot-end-marker
logging buffered 20000000
no aaa new-model
clock timezone AST 3 0
ip cef
ip dhcp excluded-address 192.168.2.1 192.168.2.15
ip dhcp excluded-address 192.168.2.200 192.168.2.254
ip dhcp pool VOICE
network 192.168.2.0 255.255.255.0
default-router 192.168.2.254
option 150 ip 192.168.2.254
no ip domain lookup
no ipv6 cef
trunk group Outside
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
no ip address trusted authenticate
sip
bind control source-interface GigabitEthernet0/0.2
bind media source-interface GigabitEthernet0/0.2
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice class custom-cptone ALSAMAH
dualtone disconnect
frequency 450
cadence 350 350
voice translation-rule 1
rule 1 /^9/ /19/
voice translation-profile Phone1
translate called 1
license udi pid CISCO2921/K9 sn FTX1829AJAF
hw-module ism 0
hw-module pvdm 0/0
file privilege 0
username admin privilege 15 secret 4 26r/NcJCbYYVHy6LhpdiCv7ZfrupUzbzqTDeDsUqEy.
username cisco privilege 15 secret 4 KNCw4nsewspqtB38RFbeA3eyBehd./L6QsNcJcBxdik
redundancy
no ip address
shutdown
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 192.168.1.254 255.255.255.0
encapsulation dot1Q 2
ip address 192.168.2.254 255.255.255.0
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.2.254
interface ISM0/0
ip unnumbered GigabitEthernet0/0.2
service-module ip address 192.168.2.249 255.255.255.0
service-module ip default-gateway 192.168.2.254
no ip address
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0/1.1221
description ***** GO L3VPN *****
encapsulation dot1Q 1221
ip address 10.129.4.242 255.255.255.252
no ip route-cache
interface GigabitEthernet0/1.1222
encapsulation dot1Q 1222
no ip route-cache
shutdown
no ip address
shutdown
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Vlan1
no ip address
router bgp 65480
bgp log-neighbor-changes
redistribute connected
redistribute static route-map DEFAULT_ROUTE
neighbor 10.129.4.241 remote-as 48695
neighbor 10.129.4.241 password go@admin.go.com.sa
neighbor 10.129.4.245 remote-as 48695
neighbor 10.129.4.245 password go@admin.go.com.sa
default-information originate
ip http server
ip http path flash:/GUI
ip route 0.0.0.0 0.0.0.0 192.168.1.253
ip route 192.168.2.249 255.255.255.255 ISM0/0
ip route 192.168.4.0 255.255.255.0 10.129.4.231
ip route 192.168.5.0 255.255.255.0 10.129.4.235
ip route 192.168.6.0 255.255.255.0 10.129.4.242
ip prefix-list DEFAULT_ONLY seq 5 permit 0.0.0.0/0
route-map DEFAULT_ROUTE permit 10
match ip address prefix-list DEFAULT_ONLY
tftp-server flash:apps45.9-2-1TH1-13.sbn
tftp-server flash:cnu45.9-2-1TH1-13.sbn
tftp-server flash:cvm45sccp.9-2-1TH1-13.sbn
tftp-server flash:dsp45.9-2-1TH1-13.sbn
tftp-server flash:jar45sccp.9-2-1TH1-13.sbn
tftp-server flash:SCCP45.9-2-1S.loads
tftp-server flash:term45.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:SCCP69xx.9-2-4-3.loads
tftp-server flash:BOOT69xx.0-0-0-14.zz.sgn
tftp-server flash:DSP69xx.0-0-0-11-124120.zz.sgn
tftp-server flash:SCCP69xx.9-2-4-3.zz.sgn
control-plane
voice-port 0/1/0
trunk-group Outside
supervisory disconnect dualtone mid-call
supervisory custom-cptone ALSAMAH
input gain 12
timeouts call-disconnect 1
timeouts wait-release 1
connection plar opx 4444
description *** Phone Line: ***
caller-id enable
caller-id alerting dsp-pre-allocate
voice-port 0/1/1
trunk-group Outside
input gain 12
caller-id enable
voice-port 0/1/2
trunk-group Outside
input gain 12
connection plar opx 4422
caller-id enable
voice-port 0/1/3
trunk-group Outside
input gain 12
caller-id enable
sccp local GigabitEthernet0/0.2
sccp ccm 192.168.2.254 identifier 1 version 7.0
sccp ip precedence 3
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register conference
associate profile 1 register transcode
dspfarm profile 1 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729r8
maximum sessions 4
associate application SCCP
dspfarm profile 2 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 2
dial-peer cor custom
name INTERNATIONAL
name NATIONAL
name MOBILE
name LOCAL
name TOLLFREE
name VOIP
name EMERGENCY
dial-peer cor list CALL-INTERNATIONAL
member INTERNATIONAL
dial-peer cor list CALL-NATIONAL
member NATIONAL
dial-peer cor list CALL-MOBILE
member MOBILE
dial-peer cor list CALL-LOCAL
member LOCAL
dial-peer cor list CALL-TOLLFREE
member TOLLFREE
dial-peer cor list CALL-VOIP
member VOIP
dial-peer cor list CALL-EMERGENCY
member EMERGENCY
dial-peer cor list GROUP-1
member LOCAL
member TOLLFREE
member VOIP
member EMERGENCY
dial-peer cor list GROUP-2
member NATIONAL
member LOCAL
member TOLLFREE
member VOIP
member EMERGENCY
dial-peer cor list GROUP-3
member MOBILE
member LOCAL
member TOLLFREE
member VOIP
member EMERGENCY
dial-peer cor list GROUP-4
member NATIONAL
member MOBILE
member LOCAL
member TOLLFREE
member VOIP
member EMERGENCY
dial-peer cor list GROUP-5
member NATIONAL
member MOBILE
member LOCAL
member TOLLFREE
member VOIP
member EMERGENCY
dial-peer voice 101 pots
trunkgroup Outside
description *** Toll-Free-Number ***
destination-pattern 9800.......
forward-digits 10
dial-peer voice 102 pots
trunkgroup Outside
destination-pattern 992.......
forward-digits 9
dial-peer voice 103 pots
trunkgroup Outside
corlist outgoing CALL-MOBILE
description ** For Mobile Calls**
destination-pattern 905........
forward-digits 10
dial-peer voice 105 pots
trunkgroup Outside
corlist outgoing CALL-NATIONAL
description ** National Calls**
destination-pattern 901[1-9].......
forward-digits 10
dial-peer voice 107 pots
trunkgroup Outside
corlist outgoing CALL-INTERNATIONAL
description *** International Calls ***
destination-pattern 900T
prefix 00
dial-peer voice 4444 voip
description *** Unity Auto Attendant ***
destination-pattern 4444
session target ipv4:192.168.2.249
codec g711ulaw
no vad
dial-peer voice 4499 voip
description *** Unity Voice Mail ***
destination-pattern 4499
codec g711ulaw
no vad
dial-peer voice 4498 voip
description *** Unity Administration ***
destination-pattern 4498
codec g711ulaw
no vad
dial-peer voice 4422 voip
translation-profile incoming Phone1
answer-address 4422
dial-peer voice 19 pots
shutdown
destination-pattern 19T
port 0/1/0
dial-peer voice 104 pots
trunkgroup Outside
corlist outgoing CALL-LOCAL
description ** Local Calls**
destination-pattern 9[68]......
dial-peer voice 106 pots
trunkgroup Outside
description ** Emergency Numbers **
destination-pattern 9[9][901].
dial-peer voice 108 pots
trunkgroup Outside
description *** Ministry of Labor ***
destination-pattern 919911
forward-digits 5
gatekeeper
shutdown
telephony-service
sdspfarm units 10
sdspfarm transcode sessions 14
sdspfarm tag 1 transcode
sdspfarm tag 2 conference
conference hardware
no auto-reg-ephone
authentication credential admin cisco
max-ephones 50
max-dn 60
ip source-address 192.168.2.254 port 2000
url services http://192.168.2.249/voiceview/common/login.do
url authentication http://192.168.2.254/CCMCIP/authenticate.asp
load 7945 term45.default.loads
load 6921 SCCP69xx.9-2-4-3.loads
voicemail 4499
web admin system name admin secret 5 $1$lO2B$O1xfVBfeVHrHvR.VotCVt1
dn-webedit
time-webedit
create cnf-files version-stamp 7960 Aug 25 2015 18:58:26
ephone-template 1
softkeys hold Resume Newcall Join Select
softkeys idle Redial Newcall Pickup Cfwdall Dnd Login ConfList RmLstC
softkeys seized Redial Endcall Meetme Cfwdall
softkeys connected Hold Endcall Trnsfer Confrn Join ConfList LiveRcd
ephone-dn 1 dual-line
number 4422
description Dr. Mazen
name Dr. Mazen
call-forward busy 199
call-forward noan 199 timeout 30
corlist incoming GROUP-5
hold-alert 30 originator
ephone-dn 2 dual-line
number 4411
description Hamoud Samah
name Hamoud Samah
ephone-dn 4 dual-line
number 4455
description Mohamed Hadad
name Mohamed Hadad
corlist incoming GROUP-1
ephone-dn 5 dual-line
number 4410
description IT-Hussein
name IT-Hussein
call-forward busy 4499
call-forward noan 4499 timeout 20
ephone-dn 6 dual-line
number 4400
description Operator
name Operator
call-forward noan 4499 timeout 30
ephone-dn 7 dual-line
number 4466
description Mr. Saad
name Mr. Saad
ephone-dn 8 dual-line
number 4477
description Maged
name Maged
ephone-dn 9 dual-line
number 4488
description Mr. Hassan
name Mr. Hassan
ephone-dn 10 dual-line
number 4490
description ROMUALDO
name ROMUALDO
ephone-dn 11 dual-line
number 4412
description Shetty
name Shetty
ephone-dn 12 dual-line
number 4413
description Mohammad Aziz
name Mohammad Aziz
ephone-dn 13 dual-line
number 4414
description Mohammad Amin
name Mohammad Amin
ephone-dn 14 dual-line
number 4415
description Amr
name Amr
ephone-dn 15 dual-line
number 4416
description Rajesh
name Rajesh
ephone-dn 16 dual-line
number 4417
description RH HR
name RH HR
ephone-dn 17 dual-line
number 4418
description Dinesh
name Dinesh
ephone-dn 18 dual-line
number 4419
description Engineer Henry
name Engineer Henry
ephone-dn 19 dual-line
number 4420
description Abou Gaffar
name Abou Gaffar
ephone-dn 20 dual-line
number 4421
description Bashair-S
name Bashair-S
ephone-dn 24 dual-line
number 4424
description Feda
name Feda
ephone-dn 25 dual-line
number 4425
description Atif
name Atif
ephone-dn 26 dual-line
number 4426
description Fadelah
name Fadelah
ephone-dn 27 dual-line
number 4427
description Wigdan
name Wigdan
ephone-dn 28 dual-line
number 4428
description Maha
name Maha
ephone-dn 29 dual-line
number 4429
description Ahmed
name Ahmed
ephone-dn 30 dual-line
number 4430
description Aqeelah
name Aqeelah
ephone-dn 31 dual-line
number 4431
description ASSEM
name ASSEM
ephone-dn 32 dual-line
number 4432
description Showpash
name Showpash
ephone-dn 34 dual-line
number 4434
description Ayman
name Ayman
ephone-dn 35 dual-line
number 4435
description Ali-H
name Ali-H
ephone-dn 36 dual-line
number 4436
description Mobark
name Mobark
ephone-dn 37 dual-line
number 4437
description Gest Services
name Gest Services
ephone-dn 41 dual-line
number 4441
description Abrar
name Abrar
ephone-dn 42 dual-line
number 4442
description Bashaer-A
name Bashaer-A
ephone-dn 43 dual-line
number 4443
description Rh Soltan
name RH Soltan
ephone-dn 44
ephone-dn 45 dual-line
number 4445
description Amani
name Amani
ephone-dn 46 dual-line
number 4446
description RH Abdul Bagi
name RH Abdul Bagi
ephone-dn 47 dual-line
number 4447
description Mona
name Mona
ephone-dn 48 dual-line
number 4448
description RH AlAhmari
name RH AlAhmari
ephone-dn 49 dual-line
number 4449
description RH Reception
name RH Reception
ephone-dn 50 dual-line
number 4450
description Dr-Walid
name Dr.Walid
corlist incoming GROUP-4
ephone-dn 51 dual-line
number 4451
description RH Ladies Dept
name RH Ladies Dept
ephone-dn 52 dual-line
number 4452
description Fadia
name Fadia
ephone-dn 53 dual-line
number 4453
description alaa
name alaa
ephone-dn 55 dual-line
number 4456
description Vishith
name Vishith
ephone-dn 59 octo-line
number 4494 no-reg primary
conference meetme
ephone-dn 60 octo-line
number 4495 no-reg both
conference ad-hoc
ephone 1
device-security-mode none
description Mazen
video
mac-address BC16.F516.3D24
ephone-template 1
username "T4422" password 123456
type 7945
button 1:1
ephone 2
video
mac-address BC16.F516.3FC4
ephone-template 1
username "T4411" password 123456
type 7945
button 1:2
ephone 4
video
mac-address BC16.F516.39C0
ephone-template 1
username "T4455"
type 7945
button 1:4
ephone 5
video
mac-address 44AD.D9BC.01AC
ephone-template 1
username "T4410" password 123456
type 6921
button 1:5
ephone 6
video
mac-address C40A.CBE0.1AC4
ephone-template 1
username "T4400"
blf-speed-dial 1 4411 label "Mr. Mamoud AlSamah"
blf-speed-dial 2 4422 label "Dr. Mazen"
blf-speed-dial 3 4433 label "Amer Khrafsha"
blf-speed-dial 4 4455 label "Mr. Hdad"
blf-speed-dial 5 4410 label "Mohamed Elhaj"
type 7962
button 1:6
ephone 7
video
mac-address 44AD.D9BC.0E45
ephone-template 1
username "T4466" password 123456
type 6921
button 1:7
ephone 8
description Maged
video
mac-address 44AD.D9BC.0E84
ephone-template 1
username "T4477"
type 6921
button 1:8
ephone 9
video
mac-address 44AD.D9BC.0DE5
ephone-template 1
username "T4488"
type 6921
button 1:9
ephone 10
video
mac-address 44AD.D9BC.07D1
ephone-template 1
username "T4490"
type 6921
button 1:10
ephone 11
description Shetty
video
mac-address 44AD.D9BC.0B55
ephone-template 1
username "T4412"
type 6921
button 1:11
ephone 12
video
mac-address 44AD.D9BC.0B68
ephone-template 1
username "T4413"
type 6921
button 1:12
ephone 13
video
mac-address 44AD.D9BC.0E08
ephone-template 1
username "T4414"
type 6921
button 1:13
ephone 14
description Amr
video
mac-address 44AD.D9BC.0B69
ephone-template 1
username "T4415"
type 6921
button 1:14
ephone 15
description Rajesh
video
mac-address 44AD.D9BC.0E06
ephone-template 1
username "T4416"
type 6921
button 1:15
ephone 16
description RH HR
video
mac-address 44AD.D9BC.0AB8
ephone-template 1
username "T4417"
type 6921
button 1:16
ephone 17
description Dinesh
video
mac-address 44AD.D9BC.0E7C
ephone-template 1
username "T4418"
type 6921
button 1:17
ephone 18
video
mac-address 44AD.D9BC.0BA9
ephone-template 1
username "T4419"
type 6921
button 1:18
ephone 19
description Nagam
video
mac-address 44AD.D9BC.0916
ephone-template 1
username "T4420"
type 6921
button 1:19
ephone 20
video
mac-address 44AD.D9BC.0AD9
ephone-template 1
username "T4421"
type 6921
button 1:20
ephone 24
description Omer
video
mac-address 44AD.D9BC.084B
ephone-template 1
username "T4424"
type 6921
button 1:24
ephone 25
description Engineer Room
video
mac-address 44AD.D9BC.0BD8
ephone-template 1
username "T4425"
type 6921
button 1:25
ephone 26
description Fadelah
video
mac-address 44AD.D9BC.0DD7
ephone-template 1
username "T4426"
type 6921
button 1:26
ephone 27
description Widgan
video
mac-address 44AD.D9BC.0E50
ephone-template 1
username "T4427"
type 6921
button 1:27
ephone 28
description Maha
video
mac-address 44AD.D9BC.0E0E
ephone-template 1
username "T4428"
type 6921
button 1:28
ephone 29
description Ahmad
video
mac-address 44AD.D9BC.0E7E
ephone-template 1
username "T4429"
type 6921
button 1:29
ephone 30
description Aqeelah
video
mac-address F029.295B.6C18
ephone-template 1
username "T4430" password 123456
type 6921
button 1:30
ephone 31
description ASSEM
video
mac-address 44AD.D9BC.0E64
ephone-template 1
username "T4431"
type 6921
button 1:31
ephone 32
video
mac-address 44AD.D9BC.0E6D
ephone-template 1
username "T4432"
type 6921
button 1:32
ephone 34
description Ali Awami
video
mac-address 44AD.D9BC.0DD4
ephone-template 1
username "T4434"
type 6921
button 1:34
ephone 35
description Ali-H
video
mac-address 44AD.D9BC.09D3
ephone-template 1
username "T4435"
type 6921
button 1:35
ephone 36
description Mobark
video
mac-address 44AD.D9BC.0E6E
ephone-template 1
username "T4436"
type 6921
button 1:36
ephone 37
description Giest Services
video
mac-address 44AD.D9BC.0515
ephone-template 1
username "T4437"
type 6921
button 1:37
ephone 41
description Abrar
video
mac-address 44AD.D9BC.0E40
ephone-template 1
username "T4441"
type 6921
button 1:41
ephone 42
video
mac-address 44AD.D9BC.0AEC
ephone-template 1
username "T4442"
type 6921
button 1:42
ephone 43
description RH Soltan
video
mac-address 44AD.D9BC.0E8E
ephone-template 1
username "T4443"
type 6921
button 1:43
ephone 45
description Amani
video
mac-address 44AD.D9BC.0E5B
ephone-template 1
username "T4445"
type 6921
button 1:45
ephone 46
video
mac-address 44AD.D9BC.0B71
ephone-template 1
username "T4446"
type 6921
button 1:46
ephone 47
description HR-Assistant.1
video
mac-address 44AD.D9BC.0E52
ephone-template 1
username "T4447"
type 6921
button 1:47
ephone 48
video
mac-address 44AD.D9BC.0AB7
ephone-template 1
username "T4448"
type 6921
button 1:48
ephone 49
video
mac-address 44AD.D9BC.0E5A
ephone-template 1
username "T4449"
type 6921
button 1:49
ephone 50
description HR-Assistant.4
video
mac-address F09E.630F.CADF
ephone-template 1
username "T4450"
type 7945
button 1:50
ephone 51
video
mac-address 44AD.D9BC.0DCE
ephone-template 1
username "T4451"
type 6921
button 1:51
ephone 52
description Fadia
video
mac-address 44AD.D9BC.0CB1
ephone-template 1
username "T4452"
type 6921
button 1:52
ephone 53
description alaa
video
mac-address 44AD.D9BC.0E67
ephone-template 1
username "T4453"
type 6921
button 1:53
ephone 55
description Vishith
video
mac-address 44AD.D9BC.03B2
ephone-template 1
username "T4456"
type 6921
button 1:55
line con 0
line aux 0
line 2
no exec
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 131
no exec
transport input all
stopbits 1
line vty 0 4
privilege level 15
login local
transport input all
ntp master 3
end
CONFIG (Version=9.1)
Version 9.1
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
no auto-reg-ephone
max-ephones 50
max-dn 60
dspfarm units 10
dspfarm 1 transcode
dspfarm 2 conference
dspfarm 3
dspfarm 4
dspfarm 5
dspfarm 6
dspfarm 7
dspfarm 8
dspfarm 9
dspfarm 10
conference hardware
privacy
no privacy-on-hold
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 10
voicemail 4499
cnf-file location: flash:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
time-format 12
date-format mm-dd-yy
timezone 0 Greenwich Standard Time
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
keepalive 30 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
web admin customer name Customer
edit DN through Web: enabled.
edit TIME through web: enabled.
background save interval 10 minutes
Log (table parameters):
max-size: 150
retain-timer: 15
transfer-digit-collect new-call
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
Dear zaidysharib
On CME Router you have to do theses steps:
voice service voip
ipv4 192.168.X.0 255.255.255.0 =====> IP of DHCP of the Phone
sip
voice class codec 1
num-lines 2
no fac refer
mode cme
max-dn 100
max-pool 50
tftp-path flash:
create profile
camera
video
voice register dn 1
number 10
name John
label John
voice register dn 2
number 11
name Peter
label Peter
id mac 584C.xxxx.cccc.bbbb
type 7821
number 1 dn 1
dtmf-relay rtp-nte
username john password cisco
codec g711alaw
id mac 584C.xxxx.cccc.kkkk
type 7821
number 1 dn 2
dtmf-relay rtp-nte
username peter password cisco
codec g711alaw
After that feedback
Best Regards
Alcidio Tembe
