02-12-2018 12:37 PM - edited 03-17-2019 12:10 PM
Hi all,
I'm facing the following problem:
When SIP-PhoneA transfer an incoming call (internal/external) to SIP-PhoneB through consult-transfer,
PhoneB sees the PhoneA internal number and not the origin-caller-id when connected with the origin-caller.
CME: 12.0
Phone: 7821, 12-0-1-11
Any ideas? Bug on CME12.0? Got the same problem with 78xx version 10.3.
Norbert
Parcial config:
voice service voip
ip address trusted list
ipv4 192.168.0.0 255.255.0.0
ipv4 10.0.0.0 255.255.255.128
media flow-around
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
no supplementary-service h450.7
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
supplementary-service ringback h225-info
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
no fax-relay sg3-to-g3
fax-relay ans-disable
modem passthrough nse codec g711alaw
h323
h245 caps mode restricted
sip
bind control source-interface GigabitEthernet0/0.115
bind media source-interface GigabitEthernet0/0.115
registrar server expires max 600 min 60
asserted-id ppi
voice register global
mode cme
source-address 192.168.115.1 port 5060
no privacy
timeouts interdigit 4
max-dn 200
max-pool 42
load 7821 sip78xx.12-0-1-11
load 8861 sip88xx.12-0-1SR1-1
authenticate register
authenticate realm all
timezone 23
time-format 24
date-format D/M/Y
hold-alert
mwi stutter
mwi reg-e164
call-forward system redirecting-expanded
voicemail 999
tftp-path flash:
file text
create profile sync 0003253876683702
network-locale CH
user-locale DE load flash:/CME-locale-de_DE-German-12.0.12.0.tar
ntp-server 192.168.115.1 mode directedbroadcast
conference hardware
voice register dn 95
translation-profile incoming TP_200
number 295
call-forward b2bua all 999
call-forward b2bua noan 252 timeout 20
call-forward b2bua unregistered 252
allow watch
pickup-call any-group
pickup-group 1
name Sitxxx
huntstop channel 1
label Sitxxx(295)
mwi
voice register template 1
button-layout 1-2 line
button-layout 24-32 speed-dial
button-layout 6-23 blf-speed-dial
button-layout 3-5 feature-button
softkeys connected Hold Park Endcall
voice register template 2
button-layout 1 line
button-layout 3-23 blf-speed-dial
button-layout 2 feature-button
voice register dn 4
number 354
call-forward b2bua noan 352 timeout 20
call-forward b2bua unregistered 352
allow watch
pickup-group 2
name Sitz
huntstop channel 1
label Sitz(354)
mwi
voice register pool 8
registration-timer max 120 min 60
busy-trigger-per-button 2
id mac CC98.914E.1EB9
feature-button 1 PickUp
type 7821
number 1 dn 95
template 2
cor incoming COR-GEM default
presence call-list
username 295 password xxxx
no call-waiting
description 0xxxxxxxxx
codec g711alaw
no vad
after-hour exempt
voice register pool 13
id mac 50F7.222C.B929
type 7821
number 1 dn 4
template 2
cor incoming COR-GRUND default
presence call-list
dtmf-relay rtp-nte
username 354 password xxx
no call-waiting
description xxxx
codec g711alaw
no vad
after-hour exempt
Solved! Go to Solution.
02-14-2018 02:29 PM
02-12-2018 04:33 PM
02-13-2018 12:03 AM
02-13-2018 12:09 AM
02-13-2018 07:06 AM
02-14-2018 04:21 AM
02-14-2018 08:47 AM
02-14-2018 09:02 AM
Sorry
354 -> 252 transfer -> 295
02-14-2018 09:33 AM
02-14-2018 09:52 AM
I wasn‘t able to get the blind transfer working, changed it under telephony-service but still consult.
CFA is working properly.
Is the transcoding an issue, b‘cause internal conferencing (3phones) doesn‘t work either?
02-14-2018 09:56 AM
02-14-2018 10:11 AM
02-14-2018 01:31 PM
02-14-2018 01:48 PM
02-14-2018 02:29 PM
