07-07-2017 03:47 PM - edited 03-17-2019 10:44 AM
When ever I reboot a phone it comes up as 5:00 December 31 1981. I am not sure why it is not getting the time from the NTP as it should be setup.
07-09-2017 01:11 PM
There are two settings you should check. Under voice register global, set the values ntp-server and timezone. These two settings should allow your phones to get the right time.
James
07-10-2017 04:31 PM
Hi James,
Thanks for the response. I do currently have both these commands listed in my voice register global pool. As for the ntp-server it is setup for unicast. Should it be setup with directedbroadcast?
07-26-2017 10:50 AM
Looks like I was hitting a bug
07-21-2017 04:21 PM
Here is my voice register global output.
mode cme
source-address 10.1.200.10 port 5060
bandwidth video tias-modifier 384000 negotiate end-to-end
max-dn 200
max-pool 42
load 9971 sip9971.9-2-2SR1-9
timezone 6
voicemail 1190
tftp-path flash:
create profile sync 0010103524982229
ntp-server 208.73.56.29 mode directedbroadcast
camera
video
auto-register
Also my gateway is showing the correct time
Calgary2901#sh clock
17:21:41.268 MDT Fri Jul 21 2017
07-15-2017 03:55 PM
Cameron, What is the phone model and CME version and IOS router model and version.
