CME SIP Phone to SCCP phone call transfer issue
Hi All
The incoming call transfer  I cannot possible to Sip to Sccp phone sccp to sccp is transfer is working .
Sip phone 8961
sccp phone 7945,6921
please check configuration
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service h450.2
 no supplementary-service h450.3
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
 sip
  registrar server expires max 300 min 60
oice register dn  1
 number 0
 call-forward b2bua noan 999 timeout 20
 allow watch
 name Operator
 label Operator
voice register pool  1
 id mac 1CAA.0710.0AC1
 type 8961 addon 1 CKEM
 number 1 dn 1
 template 1
 dtmf-relay rtp-nte sip-kpml sip-notify
 username cisco password cisco
 codec g711ulaw
 no vad
 camera
 video
telephony-service
 sdspfarm units 3
 sdspfarm tag 1 conference
 conference hardware
 conference transfer-pattern
 video
 no auto-reg-ephone
 max-ephones 100
 max-dn 250
 ip source-address 192.1.1.111 port 2000
 system message LCC_SIPOREX
 time-zone 31
 date-format dd-mm-yy
 voicemail 999
 mwi reg-e164
 max-conferences 8 gain -6
 web admin system name admin secret 5 $1$qHe3$xblvRD1ouV4jr8RcGUiMM.
 dn-webedit
 time-webedit
 transfer-system full-consult
 create cnf-files version-stamp Jan 01 2002 00:00:00
Thank you
8 Replies 8
Martin Moran
Level 3
Level 3
Hi @,
Try this config under the telephony-service globa configuration:
telephony-service
 call-park system application
After this, re-create both configuration files (in voice register global and telephony-service):
 no create profile
 create profile
telephony-service
 no create cnf-files
 create cnf-files
And restart the phones.
HTH.
Rgrds,
Martin, IT Specialist
Hi Martin
Thanks your replay i will check and update u .
Its problem solved thanks all
Good to hear that!
Did you use the commands that I provided you or did you fix it in other way? If so, please share it.
Don't forget to rate.
Rgrds,
Martin, IT Specialist.
Hi all
i used this command its working well
telephony-service
 no create profile
 create profile
telephony-service
 no create cnf-files
 create cnf-files
Thank you
Genius post, Martin!
What do you get when you press transfer? Fast busy tone? Can you configure the DN assigned to SIP as dual-line.
Rgds,
Wilmer
