05-04-2018 07:59 AM - edited 03-17-2019 12:45 PM
Dear all,
I have cisco 2911 cme version 12.0 with IP phones model (7821 and 8841).
I have a permanet issue in which phones become unregistered in different times of the day
the command show voice register pool unregistered shows the ip phones unregistered and shows busy signal.
Below are some of the show run; I also remove the command no authenticate register, but same issue. Also i update the phone firmware, what make the ip phone go unregistered????
Please help.
Attached also show run.
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
min-se 600
registrar server expires max 36000 min 600
voice register global
mode cme
source-address 172.16.28.15 port 5060
bandwidth video tias-modifier 512000 negotiate end-to-end
max-dn 60
max-pool 30
load 7821 sip78xx.11-7-1-17.loads
load 8841 sip88xx.11-5-1-18
timezone 31
date-format D/M/Y
voicemail 667
call-feature-uri pickup http://172.16.28.15/pickup
url authentication http://172.16.28.15/CCMCIP/authenticate.asp
tftp-path flash:
file text
create profile sync 0081827327161543
conference hardware
voice register dn 1
number 6000
allow watch
pickup-group 400
name Maged Ba Hadi
shared-line max-calls 3
voice register pool 1
busy-trigger-per-button 2
id mac 00E1.6DBA.439B
type 7821
number 1 dn 1
template 1
cor incoming PRIVATELINES-6000 default
dtmf-relay rtp-nte sip-notify
username test1 password test1
regards,
05-04-2018 01:25 PM
I don't see anything jumping out at me. Is is possible for you to run a 'debug voice register events', and then collect and post a debug of the unregistration/reregistration process?
05-05-2018 08:41 AM
Dears, Today the issue shows that the phone is registered but when i call it, it shows busy signal.
This applies for the below table pool 1, 3 and 4
Forget about the unregistered phones, am focusing on the phones which are registered but with busy tone (5100, 5102 & 5103)
Please refer to attached for debug commands and show run.
Thanks...
SeiyunBR#sh voice register pool all brief
Pool ID IP Address Ln DN Number State
1 00E1.6DBA.439B 172.16.28.103 1 1 5100$ REGISTERED
2 0027.9024.399F 172.16.28.108 1 2 5101$ REGISTERED
3 CC5A.535F.E1F1 172.16.28.114 1 3 5102$ REGISTERED
4 0027.9024.37B0 172.16.28.115 1 4 5103$ REGISTERED
5 0027.9024.37C3 172.16.28.117 1 5 5104$ REGISTERED
6 0027.9024.39CD 172.16.28.119 1 6 5105$ REGISTERED
7 0027.9024.3723 1 7 5106 UNREGISTERED
8 00E1.6DBA.44FF 172.16.28.109 1 8 5107$ REGISTERED
9 BC67.1C31.009B 172.16.28.113 1 9 5108$ REGISTERED
10 0027.9024.3808 172.16.28.118 1 10 5109$ REGISTERED
11 00E1.6DBA.4638 172.16.28.116 1 11 5110$ REGISTERED
12 2C3E.CF87.D495 172.16.28.120 1 12 5115$ REGISTERED
13 00E1.6DBA.45A6 1 13 5112 UNREGISTERED
14 544A.0036.AFA7 1 14 5113 UNREGISTERED
15 00E1.6DBA.4535 1 15 5114 UNREGISTERED
05-05-2018 08:54 AM
05-05-2018 07:42 AM
Check the Gig interface for any drops etc. Do that on your switch as well. If this happens at the exact same time and everyday, see if there is a SNMP/Monitoring tool polling on your network and does a traffic burst.
You might want to setup a syslog server with SIP debugs enabled.
05-05-2018 08:56 AM
05-05-2018 09:00 AM
