11-28-2011 06:10 AM - edited 03-16-2019 08:16 AM
I can not understand where is problem
i've CME and SIP-trunk to SP. Incoming calls from SP don't received by ip-phone registered on CME.
Here config-
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
voice class codec 1
codec preference 1 g711ulaw
voice translation-rule 1
rule 1 /310817/ /1412/
rule 2 /310816/ /1412/
rule 3 /310814/ /1412/
voice translation-profile FROM_SIP
translate called 1
dial-peer voice 1 voip
description **Incoming Call from SIP Trunk**
translation-profile incoming FROM_SIP
session protocol sipv2
session target sip-server
incoming called-number .
voice-class codec 1
telephony-service
max-ephones 2
max-dn 2
ip source-address 172.30.0.73 port 2000
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Nov 28 2011 17:09:42
ephone-dn 1
number 1412
ephone 1
mac-address 0018.B956.26A6
type 7940
button 1:1
Here logs-
Nov 28 14:06:30.855: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:310814@10.225.73.142:5060;user=phone SIP/2.0
Accept: application/sdp;q=0.3
Accept: application/ISUP;q=0.2
Accept: multipart/mixed;q=0.1
Allow: INVITE,ACK,CANCEL,BYE,INFO,PRACK,UPDATE,OPTIONS,REGISTER,REFER,SUBSCRIBE
Call-ID: 41bdd18rhx0n3ad9j@10.225.65.10
Contact: "88123326563" <sip:88123326563@10.225.65.10:5060;user=phone>
CSeq: 195 INVITE
Expires: 3600
From: "88123326563" <sip:88123326563@10.225.65.10:5060;user=phone>;tag=7nuqb9vo60
To: "310814" <sip:310814@10.225.73.142:5060;user=phone>
Organization: IskraTel
Supported: 100rel
User-Agent: SI3000
Via: SIP/2.0/UDP 10.225.65.10:5060;branch=z9hG4bK-eu09i-y9dus
Max-Forwards: 69
Subject: Call from CS6111
Content-Length: 243
Content-Type: application/sdp
Content-Disposition: session;handling=required
v=0
o=- 1381660 7688784 IN IP4 10.225.65.111
s=-
c=IN IP4 10.225.65.111
b=AS:64
t=0 0
m=audio 24802 RTP/AVP 8 0 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
Nov 28 14:06:30.859: //42/017E7BA28057/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 28 Nov 2011 14:06:30 GMT
CSeq: 195 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Sent:
SIP/2.0 403 Forbidden
To: "310814" <sip:310814@10.225.73.142:5060;user=phone>;tag=1FA29624-172
CSeq: 195 INVITE
Reason: Q.850;cause=21
Content-Length: 0
Nov 28 14:06:30.859: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:310814@10.225.73.142:5060;user=phone SIP/2.0
CSeq: 195 ACK
Max-Forwards: 70
Content-Length: 0
Solved! Go to Solution.
11-28-2011 12:11 PM
Looking at your debug closly I see the following:
Do you have SIP trunk authentication proerply set? This would be under sip-ua config, or under the dial-peer pointing to SIP trunk.
Also, if this IOS is 15+ make sure your default toll-fraud security feature is properly showing expected allowed connections. For test you can add the IP addresses this way:
Router(config)#voice service voip
Router(conf-voi-serv)#ip address trusted list
Router(cfg-iptrust-list)#ipv4 x.x.x.x 255.255.255.255
Chris
11-28-2011 06:24 AM
Can you post "debug voice translation" and "debug voice dialpeer"?
Chris
11-28-2011 10:26 AM
Hi!
Thank you for reply!
I see "No Outgoing Dial-peer Is Matched"
Do I need outgoing dial-peer if I have registered phone on CME?
Here my debug-
Log Buffer (5120 bytes):
o Type=DIALPEER_INFO_SPEECH
Nov 28 18:09:28.090: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
љљ Match Rule=DP_MATCH_DEST; Called Number=310817
љљ No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Nov 28 18:09:28.090: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
љљ dialstring=310817, saf_enabled=1, saf_dndb_lookup=1, dp_result=-1
Nov 28 18:09:28.090: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
љљ Result=NO_MATCH(-1)
Nov 28 18:09:28.090: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
љљ Calling Number=89653815299, Called Number=, Voice-Interface=0x0,
љљ Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
љљ Peer Info Type=DIALPEER_INFO_SPEECH
љљ Result=NO_MATCH(-1) After All Match Rules Attempt
љљ dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Nov 28 18:09:28.090: //-1/F234076480D5/DPM/dpAssociateIncomingPeerCore:
љљ Calling Number=89653815299, Called Number=310817, Voice-Interface=0x0,
љљ Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1
Nov 28 18:09:28.090: //-1/F234076480D5/DPM/dpMatchSafModulePlugin:
љљ dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Nov 28 18:09:28.094: //-1/F234076480D5/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x3111A7B8; count=1
Nov 28 18:09:28.094: //-1/F234076480D5/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x3114CF60
Nov 28 18:09:28.094: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
љљ Calling Number=, Called Number=310817, Peer Info Type=DIALPEER_INFO_SPEECH
Nov 28 18:09:28.094: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
љљ dialstring=310817, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
Nov 28 18:09:28.094: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Nov 28 18:09:28.094: //-1/F234076480D5/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x3111A7B8; count=1
Nov 28 18:09:28.094: //-1/F234076480D5/RXRULE/regxrule_profile_translate_internal: number=89653815299 type=unknown plan=unknown numbertype=calling
Nov 28 18:09:28.094: //-1/F234076480D5/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
Nov 28 18:09:28.094: //-1/F234076480D5/RXRULE/regxrule_profile_match_internal: Error: ruleset for calling number not found
Nov 28 18:09:28.094: //-1/F234076480D5/RXRULE/regxrule_profile_translate_internal: No match: number=89653815299 type=unknown plan=unknown
Nov 28 18:09:28.094: //-1/F234076480D5/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-called
Nov 28 18:09:28.094: //-1/F234076480D5/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-called number not found
Nov 28 18:09:28.094: //-1/F234076480D5/RXRULE/regxrule_profile_translate_internal: No match: number= type=unknown plan=unknown
Nov 28 18:09:28.094: //-1/F234076480D5/RXRULE/regxrule_profile_translate_internal: number=310817 type=unknown plan=unknown numbertype=called
Nov 28 18:09:28.094: //-1/F234076480D5/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 1
Nov 28 18:09:28.094: //-1/F234076480D5/RXRULE/sed_subst: Successful substitution; pattern=310817 matchPattern=310817 replacePattern=1412 replaced pattern=1412
Nov 28 18:09:28.094: //-1/F234076480D5/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = unknown
Nov 28 18:09:28.094: //-1/F234076480D5/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = unknown
Nov 28 18:09:28.094: //-1/F234076480D5/RXRULE/regxrule_profile_translate_internal: xlt_number=1412 xlt_type=unknown xlt_plan=unknown
Nov 28 18:09:28.098: //-1/F234076480D5/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x3111A7B8; count=1
Nov 28 18:09:28.098: //-1/F234076480D5/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x3114CF60
11-28-2011 10:39 AM
I always build one with session target of the IP assigned as ip source-address in your case 172.30.0.73, it does not hurt to try it.
HTH,
Chris
11-28-2011 11:35 AM
I did in another way.
Is it correct?
љdescription **Incoming Call from SIP Trunk**
љsession protocol sipv2
љsession target sip-server
љincoming called-number .
љvoice-class codec 1љ
dial-peer voice 2 voip
љdestination-pattern 1...
љsession target ipv4:172.30.0.73
num-exp 310817 1412
Nov 28 19:31:26.510: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
љљ Calling Number=310817, Called Number=310817, Peer Info Type=DIALPEER_INFO_SPEECH
љљ Result=Success(0) after DP_MATCH_DEST
Nov 28 19:31:26.510: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
љљ dialstring=310817, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Nov 28 19:31:26.510: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
љљ Result=SUCCESS(0)
љљ List of Matched Outgoing Dial-peer(s):
љљљљ 1: Dial-peer Tag=20001
љљљљ 2: Dial-peer Tag=2
Nov 28 19:31:26.510: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Nov 28 19:31:26.510: //-1/65CF4E9C8117/DPM/dpAssociateIncomingPeerCore:
Nov 28 19:31:26.510: //-1/65CF4E9C8117/DPM/dpMatchSafModulePlugin:
Nov 28 19:31:26.514: //-1/65CF4E9C8117/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x3111A4A0; count=1
Nov 28 19:31:26.514: //-1/65CF4E9C8117/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x3114D1B0
Nov 28 19:31:26.514: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Nov 28 19:31:26.514: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
љљ dialstring=310817, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Nov 28 19:31:26.514: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Nov 28 19:31:26.514: //-1/65CF4E9C8117/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x3111A4A0; count=1
Nov 28 19:31:26.518: //-1/65CF4E9C8117/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x3111A4A0; count=1
Nov 28 19:31:26.518: //-1/65CF4E9C8117/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x3114D1B0
11-28-2011 11:36 AM
Forgot to add-the call is failed
11-28-2011 12:11 PM
Chris
11-28-2011 10:07 PM
Thank you!
it's hepled-
Best regards!
