CME - SNR Issue
Nathan Hardman
HI
I am trying to setup SNR on in my CME lad i have found the configuration on the www but the commands it wants me to use are
mobility
snr 1004 delay 5 timeout 15 cfwd-noan 1001
neither mobility or snr are options under the ephone-dn
I am using the full 8.0 cme.
Any help would be appreciative
Nathan
Nathan
Version 3.4(0)
Cisco CallManager Express
Yes you need to upgrade to at least CME Ver 7.1 to enable SNR-Mobility
Use this site to find the IOS etc you need
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
6 Replies 6
acampbell
Nathan,
My lab CME is 7.1 on an 1861.
SNR commands are all good.
Yours is CME 8.0
What IOS are you using.
Alex
HI,
Im using
flash:c3845-ipvoicek9-mz.124-6.XT2.bin"
Nathan
Nathan,
Can you post thye output from
show telephony
Alex
Router#sho telephony
CONFIG [Version=3.4(0)]
Version 3.4(0)
For on-line documentation please see:
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
ip source-address 3.3.3.1 port 2000
load 7905 SCCP70.8-5-3S.loads
load 7912 SCCP70.8-5-3S.loads
max-ephones 30
max-dn 30
max-conferences 12 gain -6
dspfarm units 0
dspfarm transcode sessions 0
hunt-group report delay 1 hours
max-redirect 5
time-format 12
date-format mm-dd-yy
timezone 0 Greenwich Standard Time
keepalive 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
caller-id name-only: enable
web admin system name Admin
web admin customer name Customer
edit DN through Web:  disabled.
edit TIME through web:  disabled.
Log (table parameters):
     max-size: 150
     retain-timer: 15
local directory service: enabled.
I think this is using cme 3.4 but using the cme 8.0 files, but im not too sure.
Nathan
Version 3.4(0)
Alex
Do you know what i think this is, I started using ccp just to see if this was any good and i enabled cucmbe but it only enabled 3.4 but this was after i uploaded all the cme 8.0.
Is this IOS ok for cme and snr then?
Note to self - Don't use CCP again, stick with cli
Thanks for all your help
