cme-srst: Registered, Not In Use. each time we reboot
Hi team, as title say,
cme-srst: Registered, Not In Use. each time we reboot the router this is preventing the phones can register again when the router reboot, when we re issue the command no max-ephones and max-ephones everything works again and the state of cme-srst is Registered, In Use.
2 REPLIES 2
Highlighted
Re: cme-srst: Registered, Not In Use. each time we reboot
Is config being saved. When you reboot and phones will not register, does the configuration show the proper max-ephones command?
Brandon
Hi THanks for the replay,
Yes, we are saving the config, yes when we reboot the router and execute the command show telephony-service license, the status of cme-srst is registered, Not in use, when we execute the command no max-ephones and then max-ephones the state of cme-srst change to Registered, In Use.
we are booting the router with the tecnology-packages uck9,  please check some screen shoots. we are taking into account to save the config
Screenshot from 2019-07-18 10-27-28.pngScreenshot from 2019-07-18 10-28-03.png
Content for Community-Ad
August's Community Spotlight Awards
