CME SRST version for CallManager
Fabio Funaki
I have an CallManager 4.1(3)sr5b and I want to use an CallManager Express as SRST to provide some sites with more features in fallback mode.
Someone knows, if I can use version 4.0 or what version is more recommended to me?
I look through the CallManager compatibility matrix, and I cannot found this information.
Best Regards.
testeven
Probably you can check the CME compatibility matrix.
This one is for 4.0:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme40spc.html
It's compatible with CCM 4.1.3, so you can use it.
In this link you will find all the CME's compatibility info in case you want to check a later CME version:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_device_support_tables_list.html
Hope this helps! :)
Regards, Tere. If you find this post helpful, please rate! :)
testeven
Hope this helps! :)
Rob Huffman
Hi Fabio,
Just to add a note to the good info from Tere (+5 points for this Tere :)
The four (listed) supported versions for CCM 4.1 are;
SRST 3.4
SRST 4.0
SRST 4.1
SRST 4.2
Check out Table 125 of this excellent doc;
Cisco Unified Communications Manager Software Compatibility Matrix
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp1607786
Hope this helps!
Rob
Hi Rob,
I already saw this document, my doubt was if the SRST compatibility and the CME compatibility was the same, once CME have no SRST integration until version 3.4.
Best Regards,
Fabio
