CME TO CME, background noise on calls one WAN
rammany19
i have a CME in SiteA and another CME in SiteB, when call made across site, we experience noise and i have checked the codec used which is G.729. please what might be the problem.
5 Replies 5
acampbell
You will need to have QOS configured accross the WAN
Alex
Regards, Alex. Please rate useful posts.
Please can I see a sample config for the IP WAN qos?
Please see below QOS SRND. It has QOS for all type of WAN connection.
http://www.cisco.com/univercd/cc/td/doc/solution/esm/qossrnd.pdf
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
To back up what Ronak has sent. (+5  Ronak)
Remember if your WAN is via a Service providers network PEs,MPLS etc etc you need to
ask/buy QOS from them as well as setting up your own CE routers etc.
It is a big subject which needs to be considered before deploying any WAN based IPT/UC solution.
Alex
rammany19
Hello
i have checked the QOS SRND guide but didnt find what suit my need, please can i get an example config for the IP WAN QOS for point to point link below 768, do i need to enable cRTP on the link?
please help as this noise is getting too much, thanks.
