05-01-2016 10:57 PM - edited 03-17-2019 06:47 AM
we have Cisco Unity Express (8.6.11) running on an ISM Module inside a CME 10.5 router (2921 ISRG2), which is connected to the POTS via an VIC2-4FXO adapter.
We created a simple menu in CUE, which is basically about selecting a department by sending a DMTF tone; so when the caller pressed "1" CUE will transfer the call to a hunt group or a single extension.
Everything is working fine so far, but we have one problem:
If the caller hangs up after CUE has initiated the transfer to the extension, it continues to ring infinitely, until someone picks up the "call" (which of course is dead then).
Relevant configuration parts on CME:
voice-port 0/0/0
connection plar opx 1000
impedance complex1
caller-id enable
ephone-dn 1 dual-line
number 1000
label Main Number
name Main
call-forward all 6666
dial-peer voice 6666 voip
description CUE Main Menu
destination-pattern 6666
session protocol sipv2
session target ipv4:192.168.168.1
dtmf-relay sip-notify
codec g711ulaw
no vad
Anyone a hint on that?
Many thanks
Heinz
05-02-2016 12:05 AM
Hello Heinz,
Please add cptone XX under voice-port 0/0/0 as per country and test.
Suresh
05-02-2016 12:19 AM
Hi Suresh,
thanks - I already tried it, but it doesn´t have any effect.
voice-port 0/0/0
cptone ZA
impedance complex1
caller-id enable
Heinz
05-02-2016 12:37 AM
Hello Heinz, Pease add "timeouts wait-release 1" under voice port as well and try once.
Suresh
