07-19-2011 01:18 AM - edited 03-16-2019 06:00 AM
Hi All
I'm attempting to configure transcoding on a 2811 for the purpose of routing G729 calls from CUCM over a WAN to a CUE module. There was a time when I could do this sort of thing, but 8 months off work may have had more of an effect than I thought it would!
After beating my head against the configuration for some time on some lab kit, I upgraded it to 15.1(3)T1, and it works fine.
Any other version I try (from 12.4(15)T15, to my customer's 12.4(20)T3, 12.4(24)T5 and 15.0(1)M6) doesn't work.
My config is attached, along with debug voip ccapi inout/debug voip dialpeer inout from a failed (12.4) and a succesful (15.1) call.
Calls are from ext1201 on CUCM to ext2000 on CME, set with forward all to CUE on 2222.
Thanks in advance for any assistance!
Aaron
07-19-2011 01:41 PM
Well... got this working in the end (with assistance).
Turns out you need to remove codec flexibility (voice-class codec) from the inbound peers. I had to specifically set 'codec g729br8' on the peers as well.
And all was well.
07-19-2011 10:03 PM
It nice you;ve figured it out. Thanks for sharing
07-16-2014 04:12 PM
Dears
im searching for a way to configure this and i like ur post but i need to know what the exact solution you did i couldnt understand from your replay
im brand new on voice
thanks in advanced
