CME transfer - not working
iptuser55
Level 6
Level 6
I have a customer that if you call extension 1 externally and it forwards ot extension 2 - they can not answer the call - it rings but on picking up the handset nothing however if you do a consultive transfer it does work . Ive asked them to retest it using an internal calls to see if it is the same- it seems to me at first thoughts codec issue?
thanks
Manish Gogna
Codec issues would generally end up with fast busy as soon as the call is answered. Checking it internally is a good test to begin with. If even that fails you may post the running config and debug ccsip messages for a failed transfer.
Manish
