08-31-2015 06:20 PM - edited 03-17-2019 04:09 AM
I have several questions in my mind
Solved! Go to Solution.
08-31-2015 11:46 PM
1. I don't see any issue with the configuration. Apply this configuration and let us know if you face any issue.
2. I didn't get your requirement. Can you elaborate bit more?
3. Preference under voice class codec depends on bandwidth availability. If you don't have bandwidth restriction, you would like to have G711ulaw as first priority.
4. If you are sure remote destination supports G711ulaw, there is no harm in putting only one codec under dial-peer. If you are not sure, you would like to offer multiple codecs to remote destination during call setup.
08-31-2015 11:46 PM
09-01-2015 10:34 AM
Under test
