CME-------------UCM-------MGCP GW with PRI
renji joy
Hello Team,
Here is our scenario ,
Here we want make the call from cme to outside organisation(PSTN),which should use the same PRI in HQ.
we  have configured the VoIP dial peer and pointed to call manager but call is not going to outside.
if we are missing something and please suggest the same.
Thanks in Advance
9 Replies 9
EmilTaghiyev
Please check version of IOS on your router.If it is above than 15.x may be it is Tall-Fraud prevention (security feature)
You should permit ip address from which calls are coming (Your CME VOIP interface) on router. Configuration as
Voice service voip
Ip address trusted list
ipv4 x.x.x.x
Otherwise U can configure settings so that CME will call via UCM (in my opinion it so more clear and secure)
Please note that we can able to make the call from CME to UCM as well as UCM to CME ,
internal calls are working perfectly.
It is good but .....
Please check version of IOS on your router with E1 interface.If it is above than 15.x may be it is Tall-Fraud prevention (security feature)
Voice service voip
ipv4 x.x.x.x
I have configured ip trusted list in MGCP gateway which is running PRI(HO)
but after dialing 4 Digits getting message from the IP phone.
attaching the running configuration of cme
Voice service voip
allow-connections sip to sip
also please debug
debug ccsip calls
Hello Emil,
Still the same issue after dialing 4 Digits getting message from the IP phone.
Also not showing any ccsip calls in system
Hello ,
Issue got resolved ,there was preference issue with dial-peer ..
I mean You can configure UCM and CME so, that CME IP Phone call to outside it works so
CME - UCM - E1 on another router
