CME upgrade firmware ip phones 6921
ivan aguilar
Hiii!
One question, is possible to upgrade the firmware of cisco IPPhones 6921 in a cme 8.6?
I have red some users said not, but others said yes.
Does anybody got upgrade to 9.3.3 sccp version? and if is possible how are steps to reach it?
Regards!!
ronpatel
Level 8
Level 8
Yes it is possible to upgrade firmware using CME
The firmware is set the same way as any other 79xx ip phone. For example
1.    Go to telephony-service
  load 6921 SCCP69xx.8-5-3-0.loads               //specify the firmware you want to use
In Cisco Unified CME 7.0(1) and later versions, use the complete filename, including the
file suffix, when you configure the load command for phone firmware versions later than
version 8-2-2 for all phone types.
2.    Upload the firmware files to the flash memory  (SCCP69xx.8-5-3-0.loads*,
SCCP69xx.8-5-3-0.zz, BOOT69xx.0-0-0-14.zz, DSP69xx.0-0-0-3.zz)and specify the path.
tftp-server flash: SCCP69xx.8-5-3-0.loads alias SCCP69xx.8-5-3-0.loads
tftp-server flash: SCCP69xx.8-5-3-0.zz alias SCCP69xx.8-5-3-0.zz
tftp-server flash: BOOT69xx.0-0-0-14.zz alias BOOT69xx.0-0-0-14.zz
tftp-server flash: DSP69xx.0-0-0-3.zz alias DSP69xx.0-0-0-3.zz
3. Finally make a create cnf-files under telephony-services
Ronak Patel
Rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
ronpatel
Level 8
Level 8
Ronak Patel
Thanks a lot!
