CME User/Extension Has Lost Dial Tone
dhopkins8181
I have an extension that has lost dial-tone.  This phone has been in service for over two years and has been working properly until now.  Other buttons configured on the same phone work fine and the user can dial out, but not if using his extension.  I have tried the following with no success:
-Checked the speakerphone and cabling
-Tried dialing out using the same extension on another phone (no dial-tone for the same extension on the other phones)
-Resetting the phone to factory defaults
-Removing the phone and configuring a brand new phone
Incoming calls to the extension work fine and everything looks correct on the display.  The environment is Cisco CME 7 and the phone in question is a 7962.
aateek singh
You have a user/extension which has lost Dial tone i.e of IP phone 7962.It may be because of the following factors :
1.You are not connected to Extension mobility services.
2.the system requires a Client matter code (CMC) or Forced authorization code(FAC) after dialing a number.(SCCP phones only).
3.Change the time-of-day restrictions that prevent you from using some features during certain hours of the day.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7962g_7961g_7961g-ge_7942g_7941g_7941g-ge/8_0/english/user/guide/62enu80/62614241trb.html
Aateek Singh
Network Engineer
Spooster IT Services
