CME ver10 issue....Incoming calls ID missing
ev1205
Level 2
Level 2
Hello everyone, I have a special situation on a CME ver 10 platform using Cisco 78XX Ip phones.
When any  user receives incoming calls from PSTN, they can see external Calling number identification, but once they put an incoming call on hold and retake it they lose Calling number information (the Ip Phone only shows users's DN ID).
This is a very hard problem for receptionist, because she is always managing more than 2 calls at the same time, and she is unable to identify the "on hold" calls.
Here I am attaching my router's config, but here you have only Receptionist's Ip Phone information:
voice register dn  1
 number 235
 call-forward b2bua busy 399
 call-forward b2bua noan 399 timeout 120
 pickup-call any-group
 pickup-group 110
 name Reception RECEPTIONIST
 label Reception RECEPTIONIST
 mwi
voice register pool  1
 busy-trigger-per-button 5
 id mac 547C.69D6.EDB6
 type 7841
 number 1 dn 1
 template 1
 dtmf-relay rtp-nte
 username cisco password @@#
 description 235
 codec g711ulaw
voice register global
 mode  cme
 source-address 10.2.50.254 port 5060
 max-dn 180
 max-pool 42
 load 7821 sip78xx.10-1-1SR1-4
 load 7841 sip78xx.10-1-1SR1-4
 load 8831 sip8831.9-3-3-5.loads
 timezone 14
 hold-alert
 mwi reg-e164
 voicemail 399
 tftp-path flash:
 create profile sync 1154114824189124
Do you know what can be missing here?
Best regards
Enrique
ramneeka
What is the call-flow? Is call is coming over  PRI/FXO/SIP trunk? do you have any debugs for this call yet collected?
Ramneeka
Hi Ramneka !
The PSTN access is through a SIP trunk ( as you can see on attached file).
I am planning to visit customer to collect proper debugs during tests call.
Best regards !
Try to enable moved-temporary and refer header in your CME config and test
