CME VG224 Information
HollTel.com
Beginner
Beginner
I just started to manage a site that is several states away and I've never been to. (Please hold your applause for later on that one)
My question is they have many VG224's hooked up to there ISR CME. Is there a clean way for me to inventory the VG's and determine what is on each one? Also I was told that one was recently removed so that some of the MAC address are still built but not existent anymore. I've got the IP address to the VG's and can ping from the CME but that's all I've been able to do thus far.
Thank you for all your help I will leave positive feedback for anyone that helps out! Happy Fathers Day!
2 Accepted Solutions
Deepak Mehta
Rising star
Rising star
Hey Matt,
Good luck with new assigement.I beleive if you do a telnet from your CME to one of them see if you can access the VG224 or if you have a telnet or SSH client you can try access them directly.
and run sh inventory and sh version and sh diag command to list all the specs.I believe that should do it.thanks
You can try accessing the Vg224 via same PC , if telnet or SSH is enabled for that it should work(Vg224 is on same network).Also if both CME and VG are in same network then you can just try to telnet from CME using below.
telnet X.X.X.X .
However if you are setting them up for first time then you will need a console cable to access the VG224 and you will have to be near the device.thanks
7 Replies 7
Deepak Mehta
Rising star
Rising star
Hey Matt,
Deepak,
Thanks for your response. So the way I'm access this CME is thru a PC onsite that I have Putty set up on. How do you Telnet from the CME to the VG? Like I said I am able to Ping from the CME but was not able to ping from the PC to the VG.
Thanks!
telnet X.X.X.X .
