CME VM Not showing running conf
santorini
Hi everyone,
I am really hoping that someone can help me, if not, then no worries, if yes, I am grateful!
We had a power outage and the router which is 2811 running VM is no longer showing all of the configuration and it has a different hostname and doesn't accept any of the sh commands, the sh run only shows default conf but everything works just fine.I was trying to save the config and transfer them to a different server.
Please help!
6 Replies 6
using show version, see the value of the config-register.
Thank you for taking the time.
To add to what Mohammed said, issue the command "show version" and look at the configuration register. It should be 0x2102. If it is another value (such as 0x2101) that may be the cause of your issue.
Also, issue the command "show startup-config". This will tell you if the original configuration is still on the router.
What is the current hostname? Is it "rommon 1" or something similar? If so, issue the following command to change the config register back to 0x2102:
rommon 1 >confreg 0x2102
Then reboot or power-cycle the router.
Let us know how it goes.
Maren
VM_AA_System#sh startup-config
Using 2583 out of 245752 bytes
! Last configuration change at 11:33:43 DST Tue Jun 25 2019
version 15.1
hostname VM_AA_System
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone CST -6 0
clock summer-time DST recurring
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.20.1 192.168.20.20
ip name-server 8.8.8.8
no ipv6 cef
voice service voip
ip address trusted list
ipv4 192.168.20.1
ipv4 192.168.20.0 255.255.255.0
allow-connections sip to sip
supplementary-service h450.12
sip
voice-card 0
license udi pid CISCO2811 sn FTX0919A19Q
redundancy
interface FastEthernet0/0
ip address 192.168.20.6 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.201.35 255.255.240.0
duplex auto
speed auto
interface Service-Engine1/0
ip unnumbered FastEthernet0/0
service-module ip address 192.168.20.5 255.255.255.0
service-module ip default-gateway 192.168.20.1
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:
ip route 0.0.0.0 0.0.0.0 192.168.20.1
ip route 192.168.20.5 255.255.255.255 Service-Engine1/0
tftp-server flash:CUE-20
control-plane
mgcp profile default
dial-peer voice 11 voip
destination-pattern 1...
b2bua
session protocol sipv2
session target ipv4:192.168.20.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 20 voip
destination-pattern 2[012]00
b2bua
session target ipv4:192.168.20.5
codec g711ulaw
no vad
sip-ua
mwi-server ipv4:192.168.20.5 expires 3600 port 5060 transport udp
telephony-service
max-ephones 30
max-dn 32
ip source-address 192.168.20.6 port 2000
calling-number initiator
cnf-file location flash:
voicemail 2000
mwi relay
max-conferences 4 gain -6
call-forward pattern .T
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp Jan 01 2002 00:00:00
line con 0
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
login local
transport input telnet
scheduler allocate 20000 1000
ntp peer 192.168.20.1
ntp peer 192.168.20.6
end
Is this startup-config the same or not the same as your current running-config?
If it is the same as your current running-config, then it seems your former running-config was not saved prior to the power outage. If that is the case, your old config is lost and you'll have to recreate it.
If the current startup-config is not the same as your current running-config, you can place the startup config into your running-config with the command copy startup-config running-config
Also, if the current startup-config is not the same as the current running-config, then there may be a serious problem with your router as the config-reg of 0x2102 should have caused the startup-config to be loaded into the running-config at boot. As this did not happen, it could be an anomaly but it could also indicate an issue. If this is the case, I would suggest performing a reload and see if the startup-config is loaded into the running-config. If it does not, you will want to contact TAC.
Maren
You are truly a kind soul for taking the time, I really appreciate all that
but unfortunately, I was told by Cisco TAC that the router is too old and
no longer serviceable or eligible for support otherwise I would have gladly
gone through them.
Both running and startup conf are the same.
