01-04-2015 06:29 AM - edited 03-17-2019 01:28 AM
Dear all,
i have a cme routers in 4 branches using site codes as they have common extension numbers.
Attached is the show run and debug commands for HQ branch in which a fast busy tone (unknown number) is shown when i call the branches using :
011123, 008111 or 004123 in which the first three digits is the site code.
other branches can call the HQ successfully, routing and firewall is well configured.
can you please go through the attached and help.
thanks for all.
01-04-2015 09:31 AM
What is the Inter-Sites codec being set to from HQ---Branches.
On HQ router you have dial-peer with voice class codec
Disconnect cause which in the logs is 17,57 which is probable cause of codec mismatch.
If you try testing one HQ to one branch call with G711 call with hard code on dial-peer .
Nadeem Ahmed
01-04-2015 07:08 PM
Nadeem is likely on to something here with the codec issue.
Your outbound dial peer is 9, which defines the SIP codec but uses H323 methods for DTMF. Try changing this on both ends of the call to use SIP with rtp-nte, or H323 with h245-alpha.
dial-peer voice 9 voip translation-profile outgoing To-DhAMAR destination-pattern 011... session protocol sipv2 session target ipv4:10.100.11.20 voice-class codec 5 dtmf-relay h245-alphanumeric h245-signal no vad
If you're using SIP, use these debugs and the issue should be much easier to identify:
debug ccsip messages debug ccsip error debug ccsip call debug voip ccapi
Run the debugs on both ends if you manage both devices. And make sure the CME/CUBE on the receiving end is set to allow the codecs at the inbound dial-peer and, if applicable, with the "allow-connections" commands in 'voice service voip' params.
If you're still hitting issues, paste your debugs.
01-04-2015 09:29 PM
Hi Nick and thanks for replay,
the other 3 branches uses sip & sccp phones and uses the below dial peer to dial voip call.
Branch commands:
voice class codec 5
codec preference 1 g711ulaw
codec preference 2 g729r8
for sip phone:
voice register pool 32
id mac 6C99.8985.1DBA
type 3905
number 1 dn 32
template 1
dtmf-relay rtp-nte sip-notify
voice-class codec 5
username SFD32 password SFD32
for voip dial peer:
dial-peer voice 91 voip
translation-profile outgoing To-HQ
destination-pattern 001...
session target ipv4:10.100.1.20
voice-class codec 5
no vad
01-04-2015 09:30 PM
thanks nadeem,
i`ll change the codec and i`ll inform you back.
regards,
01-04-2015 11:23 PM
yes there is a voice class command in the dial peer.
voice class codec 5
HQ dial peer
voice-class codec 5
dtmf-relay sip-notify rtp-nte
no vad
Branch dial peer
dial-peer voice 92 voip
voice-class codec 5
no vad
even i hard code the codec with G711 but still the issue there.
