AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
1450
Beginner
CME web interface GUI loading problems, Voice mail on CME & IVR on CME
CME web GUI loading problemHello everyone!
I am having sort of problems with loading CME web GUI on a 2811 router.
I have done everything according to the available instruction on the cisco website or other sites as well, but nothing works out for me.
Problem which I am facing is that when I enter the ip/ccme.html it asks for admin credentials so when I am passed through it the CME page is loading up but not completely. as you can see the attached photo links, taps, menus and other things are not working and fully loaded. I tried to enable compatibility mode of IE for the router IP address but it just helps a bit. Still no links and menu are working.
The IOS version is 15.1(4)M1 and so according to the matrix table provided by cisco I think I have to install the "cme-gui-8.6.0.tar" in the directory of /GUI if I am not mistaking.
I didn't use TFTP to copy the files into the GUI directory but instead I used a compact flash reader as I am closed to the router.
these are the files inside the .tar file:
Admin-user.html
Admin_user.js
dom.js
ephone_admin.html
normal_user.html
normal_user.js
Telephony_service.html
xml.template
xml-test.html
I would appreciate any kind help/support on this problem beside giving an advice on below too:
I also have these questions too:
a) How can I enable the voicemail in the CME which is installed on this router? (you know I am new to cisco telephony solution)
b) How can I set an IVR in the CME which is installed on this router? (you know I am new to cisco telephony solution)
Cheers!
MT
15 REPLIES 15
Rising star
Did you try other browsers
Did you try other browsers like chrome or firefox etc.?
Beginner
Kevin, thanks for your
Kevin, thanks for your suggestion,, but I did mention that I even did add the IP address to the IE compatible mode but nothing works out.
Deepak Mehta, I tried whatever you think. Chrome, Firefox, Opera, IE,,.....
I am worried maybe the CME version or files have got problem. The folder name is (GUI) all in capital letters so could you confirm if this is correct? or it shall be in small letter? like (gui)
I am also worried maybe it is due to file permission too.!!!!
Any words on :
MT
Beginner
Hi Guys,
Hi Guys, is there any other comment on how to get this damn problem with CME GUI solved? Appreciate it MT
Beginner
I've got this problem solved.
I've got this problem solved. :)
Compatibility view was only a small none important issue.
but the main problem is that the GUI original files "cme-gui-8.6.0.tar" was included some JS and some GIF file format with totally capital letters which it was preventing the gui from calling and decoding them correctly. just changed it to small letters and now everything works fine.
I am wonder actually how such thing is possible!!!
Anyway...
cheers!
MT
Beginner
Re: I've got this problem solved.
IM using version 8.5 of CME with a similar issue. Page partially loaded but no links active. For any file under /GUI which had a capital letter in it, I created a copy of that file in /GUI but all lower case. Browser fully loads now with all links operational.
Participant
Hi MT,
Hi MT,
Use IE (Internet Explorer) in compatible mode. It should work.
Rate the post accordingly.
-Kevin Monteiro
Participant
Hi MT,
Hi MT,
Attach the "show tech" of CME.Secondo you can configure Unity express via CLI or web using IP of the CUE on the web browser.
Here is a link for your reference:
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unity-express/62609-tdcmecue.html
-Kevin Monteiro
Beginner
Hi Kevin,
Hi Kevin,
Thank for the link. That was useful. Just could you please tell me what HW or modules or requirements should I have for purpose of IVR and voicemail?
I've seen something about CUE Cisco Unity Expr. so is that a must? or not we can setup the available and integrated CME voice mail and auto attendant?
MT
Rising star
+5 to Samiulla for his inputs
+5 to Samiulla for his inputs.
Check the below link for HW requirements for 2811 and min IOS requirements .
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/rel8_6/rel_notes/rel_notes86.html#pgfId-296920
were you able to get the GUI working?
Beginner
Well, not yet! :(
Well, not yet! :(
quietly get beyond what I expect....
any other solution? I mean except things available in this forum and cisco website,... coz I check everywhere and every thing...
MT
Highlighted
Beginner
Looking at the screen capture, it looks like IE compatibility issue. As Deepak and Kevin have already pointed that out
For Voicemail, you can use CUE modules available, which are compatible with 28xx series routers.
Only, AIM and NME modules are compatible with 28xx series routers for voicemail.
Under telephony service configure voicemail pilot and consider your integration method with CME before configuring further.
Also, call-forward noan and busy must be configured under ephones to forward calls to CUE.
Refer to this document, skip steps based on your network readiness.
https://supportforums.cisco.com/sites/default/files/attachments/discussion/10steptoconfigurecme.pdf
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmegui.html
Beginner
Hi Samiulla
Hi Samiulla
thanks for the information.
About the GUI I mentioned in my first post that I have enabled the compatibility mode of IE.
to be honest I have tried and checked everything within the links you just sent, and with in whatever I found on the net. but still nothing works out. :( :( :( :(
I have attached couple of more snapshots for your review and to see if these aren't strange:
1. please check the snapshot 'without compatibility mode.png' this is how it'll load without enabling the compatibility mode of ie.
2. please see the snapshot 'debugger-compaitibility.png' to see the warning in debugger mode and more compatibility testing features. as recommended by Microsoft on how to enable compatibility. there are sort of warnings like unable to decode 'image http://IP/logohome.gif' and 'image http://IP/sxiconad.gif' . these files are available in the GUI directory but neither IE automatically nor me manually can open it up in the internet explorer by even entering images url: http://IP/logohome.gif ; but nothing is showing up. just an unload image icon.
3. please check the snapshot 'Flash files.png' which is taken from the CCP and seems like there are 2 folders named 'ITS' & 'its' ?!!!!! is  this really strange?!!!! have you seen such thing before!!! I have also attached a snapshot of each directory to check more. those shots are "ITS-.png"&"its.png"
4. I also attached the GUI directory files snapshot please check the shot "GUI files.png"
Currently this problem becomes a headache for me and I'd appreciate your focus on this damn issue.
Thanks a lot!
MT
Beginner
I remember having similar problem accessing unity connection on IE10. However, I do not remember how it was fixed. It was something to do with Document mode (press F10>Document Mode) Try changing it to Default.
Also, post Sh tech from the router.
Sami
Beginner
Hi Sami,
Hi Sami,
Could you please check more on that to see what was the solution exactly?
I'll go through the F10 or document mode and will return feedback here.
I didn't get this part!!! : "Also, post Sh tech from the router."
BTW_ any words on Flash directory contents? I mean those 2 'ITS' and 'its' folder name? isn't it a problem?!!!
cheers!
MT
Content for Community-Ad
August's Community Spotlight Awards
