02-13-2018 12:37 AM - edited 03-17-2019 12:11 PM
Good morning,
we have CME 2901 router, no FXO module installed, we have GSM device to convert from GSM to RJ45 Huawei (B315S-936), need to configure the CME to get the incoming and out going calls to the Ethernet interface, as i know you can do dail-peer for outgoing, my intention for incoming calls.
regards
Solved! Go to Solution.
02-13-2018 06:48 AM
Assuming it can do SIP/H323, give it an IP and configure it to send calls to CME, and from CME consider it as any remote system, configure the dial plan that would be required to work with it.
Debug the connection to see if it's working or not.
02-13-2018 06:26 AM
02-13-2018 06:48 AM
02-13-2018 07:01 AM
We dont have land line infrastructure in the location so we are trying to find a solution for incoming calls
02-13-2018 07:02 AM
